Old 03-28-2011, 11:53 PM   #101
nastyc10
nastyc10's Avatar
Re: Tre5 Customs roadster blazer project
Making good progress!
nastyc10 is offline   Reply With Quote
Old 03-29-2011, 01:20 AM   #102
VA72C10
VA72C10
VA72C10's Avatar
Awesome! Love the flush caps where the stake pocket went
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-29-2011, 06:20 PM   #103
BlueJeep
BlueJeep's Avatar
I assume those are not floating calipers if you've run hard line all the way on them?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-29-2011, 06:33 PM   #104
tre5
tre5's Avatar
No, they are floating. I have never had a problem running the hard line straight to a floating caliper. I use stainless steel annealed line, it is more flexible when annealed. The only down fall I see doing it this way is that whenever the owner goes to replace rear pads he will have to disconnect the hard lines and re bleed the brakes... Once every 40,000 miles or so, so really not that big of a deal.
Follow me on facebook and Instagram. Tre 5 Customs
My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809
Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105
Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949
tre5 is offline   Reply With Quote
Old 04-05-2011, 10:29 PM   #105
tre5
tre5's Avatar
Got the Grant Customs skin welded up and installed the 15" AVS led tail lights installed. My buddy Will came over and helped out a bit. I had to get a picture of someone other than me working on the truck, so here he is... drilled who knows how many holes in the floor piece.
Old 04-06-2011, 08:30 PM   #106
tre5
tre5's Avatar
Almost done with the tranny hump. Just one small patch panel on the drivers side to finish up.
Old 04-06-2011, 08:41 PM   #107
dnd1978
dnd1978's Avatar
Your metal work look great. I like your rear lights in your tail gate. subscribed
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 04-07-2011, 01:38 AM   #108
nastyc10
nastyc10's Avatar
looks good man!
Old 04-07-2011, 10:50 AM   #109
67cheby
67cheby
67cheby's Avatar
clean....as usual
67cheby is offline   Reply With Quote
Old 04-07-2011, 12:01 PM   #110
Cameron 1137
Cameron 1137's Avatar
Holy Fabrication! this is amazing. subbed
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 05-02-2011, 09:39 PM   #111
tre5
tre5's Avatar
ok, finally back to work on the blazer. I got the 1" narrower Porterbuilt arms on and the hood now closes.
The standard arms from them were a bit too wide for the 24's to fit under the hood. With them now 1" narrower the tires clear the roll in the hood.
I also got the Porterbuilt hood hinges on and all the front end mounted up. Now I just need to add some support in the fenders as well as a place to hide wires up underneath the fender support. Then weld up the front Grant Customs roll pan and fill all the little holes in the hood, grill, and fenders.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 05-04-2011, 12:43 AM   #112
hotrodhomi
hotrodhomi's Avatar
great build.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 05-04-2011, 12:48 AM   #113
Dinos63
chevy only
Dinos63's Avatar
nice work kat!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 05-04-2011, 10:37 PM   #114
tre5
tre5's Avatar
First time it has been out of the garage!
Does the windshield need to be laid back?
Old 05-04-2011, 10:44 PM   #115
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
I like what I see, next time you're in So.Cali bring it out
We would Love to see it up close and in person
JOHNORO is offline   Reply With Quote
Old 05-04-2011, 11:10 PM   #116
VA72C10
VA72C10
VA72C10's Avatar
looking good!!!
Old 05-05-2011, 01:05 AM   #117
nastyc10
nastyc10's Avatar
Its coming along nice!
Old 05-05-2011, 01:09 AM   #118
Dinos63
chevy only
Dinos63's Avatar
very cool , again nice work!!
Old 05-05-2011, 11:57 AM   #119
67cheby
67cheby
67cheby's Avatar
could you set something across the top of the fenders and tell me how much your tires stick up above the top of the fenders, if you dont have time that is fine but if you do it would be a good little bit of research for me
Old 05-05-2011, 12:48 PM   #120
Pop's C-10
Pop's C-10's Avatar
layin it back would look killer,,,
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-05-2011, 01:42 PM   #121
hotrodhomi
hotrodhomi's Avatar
No, it will disrupt the lines.
'66 impala ht
Old 05-05-2011, 01:46 PM   #122
lolife99
67-72 parts collector,…
lolife99's Avatar
I agree,...
Keith
Convert to disc brakes.
Old 05-05-2011, 01:51 PM   #123
ctpchevy
ctpchevy's Avatar
i would deff lay it back it will give it a sleeker look
ctpchevy is offline   Reply With Quote
Old 05-05-2011, 02:24 PM   #124
belowme51
belowme51's Avatar
IMO:lay it back to match the angle on the hood...
belowme51 is offline   Reply With Quote
Old 05-11-2011, 09:46 PM   #125
tre5
tre5's Avatar
