Old 12-02-2011, 12:27 PM   #101
mcbassin
Still Learning
mcbassin's Avatar
Re: 68 aka "Chained in Porterbuilt Prison"
Very interested in watching how you are gonna use that sweet floor shifter!
mcbassin is offline   Reply With Quote
Old 12-02-2011, 07:21 PM   #102
jtp67-72
jtp67-72's Avatar
Glad u brought that up cause I want yours and others opinions--this shifter originally came with the plate like this--
http://www.ebay.com/itm/330577808927...84.m1423.l2649
But the six speed shifter plate has a rubber boot in the round area U see in the plate above--I think would be totally cooler using the 6 speed boot and the auto shifter rather than the kind of MECHANICAL LOOKING plate above--Make every one go--"Is it 6 sp or auto"???
The console is in pics in post 45...here is a pic of complete with 6 spd shifter but ot a real good pic of plate........jim
http://www.ebay.com/itm/03-06-CHEVY-...item3f013f9ea2
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 12-03-2011, 01:54 AM   #103
jbclassix
Junk Yartist
jbclassix's Avatar
Agree. The six speed boot looks way better, and less "late 90's early 2000's" design.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-05-2011, 07:49 PM   #104
ccracin
CCTek
ccracin's Avatar
Jim,
I can't believe I didn't see this over here! Awesome work man! I love the dash. I agree with you, the stock dash is what I like least about these trucks. The stock one was cut out of ours long ago! I'm subscribed. Keep it coming!
Chad
68 swb Project
http://67-72chevytrucks.com/vboard/s...d.php?t=262840
72 swb Project SOLD
http://67-72chevytrucks.com/vboard/s...=1#post3993641
THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com)
ccracin is offline   Reply With Quote
Old 12-05-2011, 08:00 PM   #105
jtp67-72
jtp67-72's Avatar
I'll let the cat of the bag-sort of----Instead of shaved handles-think of Ring Brothers Gen 1 handles !!!!!!!!!!!!!
Old 12-10-2011, 09:22 PM   #106
jtp67-72
jtp67-72's Avatar
Ok guys a little wkend report--2 cold to finish body work on dash so I took bed apart last week and finish 1 bedside today--Floor will be raised 10 inches-I am not a fan of notch covers so I will raise complete floor --Started on dr. side panel--Reverse mini tub-wood will set on top of angle-Little trick here-always plug weld angle to wall before cutting out below-that way no flexing on the side panel-That's 1x2 tubing between bedside and inner panel-all pieces touching outer bedside are done with 3m panel bond --Tub bolts in-will be 6-7 " wider than pic-That's one half-The tub will have a 1 1/4 flat bar welded all the way around lip INWARD so the bolts will be hidden.............jim
Old 12-10-2011, 09:27 PM   #107
jtp67-72
jtp67-72's Avatar
More pics-Original look on pass side--how much tub reduced-Floor will look close to this................jim
Old 12-10-2011, 09:31 PM   #108
VA72C10
VA72C10
VA72C10's Avatar
Looking good! Like the inspiration picture
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-10-2011, 09:42 PM   #109
jtp67-72
jtp67-72's Avatar
Last truck---something's always give me a burr in my saddle about that pic and I want your opinion--Look at the center 2 boards and tell me it would not look better with a centered bed strip and then run the wide boards all the way out!! I've done the math and it still would look right at the outer edges--I know --I'm anal but it has always bothered me..............jim
Old 12-10-2011, 11:09 PM   #110
jlaird
jlaird's Avatar
question for ya...I had previously thought the inner bedsides didn't need to be cut to clear the tires. So I guess my question is why are you doing what you're doing?LOL!
jlaird is offline   Reply With Quote
Old 12-10-2011, 11:17 PM   #111
jtp67-72
jtp67-72's Avatar
Good question-gaining 1 1/2 " towards fender-I didn't have 2 but wheel will sit closer to lip and improve overall look-Don't like look if wheel is inset 2 far-Just a personal choice for me-But there is plenty of room without this mod especially with inboard bridge for bags--Check 1st pic and look how I trimmed the fender lip(roll) about 5/8" all the way around-like late model fenders.........Got 2 finish pass side and then off to blaster.......jim
Old 12-10-2011, 11:19 PM   #112
VA72C10
VA72C10
VA72C10's Avatar
I am totally like you on the width of the boards bothering me... I always planned to install equal sized boards unless I was doing an original restoration (and then it would be painted anyways )
Old 12-10-2011, 11:22 PM   #113
jtp67-72
jtp67-72's Avatar
Look at that bed pic again-See how I widened tub to overreach the bed strip?? Didn't need that wide but felt it could not fall on strip--changing boards would eliminate this 2!!!..........jim
Old 12-12-2011, 11:07 AM   #114
67cheby
67cheby
67cheby's Avatar
looking GREAT !!
67cheby is offline   Reply With Quote
Old 12-12-2011, 09:48 PM   #115
jtp67-72
jtp67-72's Avatar
It's been a while^^^^^ --where U been--Notch cover I suspect?? Love yours but I will leave that labor of love with U--lol-Im not crazy about shorty(depth) bed either but it works for me...let me see the new corner pieces when your done....jim
Old 12-12-2011, 10:50 PM   #116
67cheby
67cheby
67cheby's Avatar
You nailed it Been working on hinging it. What a pain
Old 12-16-2011, 01:30 AM   #117
fishingjred73
fishingjred73's Avatar
Nice work going on.....subscribed!
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 12-18-2011, 08:28 PM   #118
jtp67-72
jtp67-72's Avatar
Ok ,before I expose these pics need to acknowledge not my original idea--Va72c10 was way ahead of me-also 67Cheby on his notch cover--------well I was between coats of epoxy today and shaZam---this is done without welds-all panel epoxy-Cut new gate(whew!!!) installed 3 by 3/16 backing metal--flush fit script--now all left is lite body work--(actually started this last nite--epoxy needs 4 hrs min to set).............jim
Old 12-18-2011, 08:31 PM   #119
jtp67-72
jtp67-72's Avatar
Don't know if I have the Kahonnees to cut a real good fender but here is another idea--Looks better in person.............jim
Old 12-18-2011, 08:38 PM   #120
jtp67-72
jtp67-72's Avatar
One more weekend project done...........I have always had a pet-peave about the area under the bedroll-always rusts-cant paint well............ssssoooooo I shave the inside lip and cap the bottom............makes a nice finished look--This will need a little body work on the roll edge to be perfect---another panel bond project-with minimal welding.............jim
Old 12-18-2011, 09:18 PM   #121
shawno72
C/10 junkie
shawno72's Avatar
That's a great idea, always feel rust in this area.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-19-2011, 01:27 AM   #122
VA72C10
VA72C10
VA72C10's Avatar
I like the bedside mod. And the gate mod is cool! Much more subtle than my original idea
Old 12-19-2011, 07:12 AM   #123
n2billet
Village Idiot....
n2billet's Avatar
I see how your tub bolts to the side of the bed (nutserts) but what are your plans for the very top?
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 12-19-2011, 10:41 AM   #124
ilovnos
ilovnos's Avatar
Hey Jim--tailgate looks great. I think the fender would look pretty cool too.
68 Chevy SWB Stepside--under construction--now Fleetside w/18's & 20's--getting ready for 350 TPI motor w/700r4
67 Camaro--17x8's and 19x12's--C5 & Airride Technologies susp. (not finished)
09 Tahoe--lowered w/20's
Superformance Cobra--347 stroker w/Weber injection--polished 17's--SOLD
08 Scion Xb w/ground effects and 19's (son's car)
ilovnos is offline   Reply With Quote
Old 12-19-2011, 10:44 AM   #125
67cheby
67cheby
67cheby's Avatar
i love the tailgate,great work on the bedsides but , think it might be to much on the fenders ?? just my opinion
