Old 08-04-2013, 07:33 PM   #101
mooseknuckles
mooseknuckles's Avatar
Re: 1968 C10 5.3 swap, the easy way.
very nice.
mooseknuckles is offline   Reply With Quote
Old 08-15-2013, 01:59 PM   #102
Ronald29609
This retired guy says thanks for this post. I am going to do the same for my 67 Short bed. Since I had not a clue where to begin you can imaging how helpful this is.
Ronald29609 is offline   Reply With Quote
Old 08-15-2013, 02:48 PM   #103
solidaxel
solidaxel's Avatar
Thanks for sharing all your information with us, nice work!
Tell me about, the I think you said 4 wires from the relays to the "Truck" where and what are these wires connected too?
What are you using for a speedometer?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-02-2013, 05:34 PM   #104
kd360
Awesome build. I can't wait to start mine after seeing this. I am swapping mine out of an 02 silverado so I am hoping to use most of the factory parts.
kd360 is offline   Reply With Quote
Old 11-05-2013, 12:03 AM   #105
vannatta20
vannatta20's Avatar
LQ4 dyno at 311 hp and 380 tq. The truck intake killed power and wouldnt make anything passed 5100 rpm.
Update.. The truck intakes are fine. The camshaft holds the power way back. Installed a new cam and I have so much more power and so far the gas mileage is the same. Actually got a few mpgs better.
vannatta20 is offline   Reply With Quote
Old 11-05-2013, 12:48 PM   #106
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
not sure that was your problem as lots of guys are making power past that point with the truck intake...could have been your cam.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-05-2013, 03:27 PM   #107
vannatta20
vannatta20's Avatar
Yea I agree. Im trying to find a stock lq4 dyno graph to compare it. Its either the cam and/ or valve springs.
Old 11-05-2013, 07:45 PM   #108
68Stepbed
68Stepbed's Avatar
It's the cam and valvesprings. I didn't read the whole thread. Is the valvetrain all stock stuff?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-05-2013, 09:16 PM   #109
vannatta20
vannatta20's Avatar
I just put in a 6.0 lq4 with 799 heads with yellow springs.
Old 11-05-2013, 10:22 PM   #110
68GMCCustom
ahhh.......cam is stock then. That would be a limiting factor. That said...your dyno numbers are good. Wouldn't think you'd be getting valve float with those springs in the low 5000rpm range but I'm not familiar with their specs.
put a .550 to .600 lift cam in it with duration in 210-220/220-230@.050 range...along with a nice set of .650 lift dual springs and some c-moly p-rods to keep it together and watch it wake up!
Kurt -
Old 11-06-2013, 09:27 AM   #111
68Stepbed
68Stepbed's Avatar
Yep, a TSP sleeper 220 cam with dual springs and hardenend pushrods will wake that baby up to about 380 hp.
Matt
Old 11-26-2013, 05:27 PM   #112
JP238
JP238's Avatar
Very nice truck!
Where did you get the LED gear indicator?
JP238 is offline   Reply With Quote
Old 11-26-2013, 09:17 PM   #113
vannatta20
vannatta20's Avatar
I bought a LED at radio shack and rigged a mount for it.
Old 11-26-2013, 09:27 PM   #114
JP238
JP238's Avatar
Just soldered to the factory wire?
Old 11-26-2013, 09:27 PM   #115
vannatta20
vannatta20's Avatar
Gas mileage update! The 6.0 is getting MUCH worse gas mileage than the 5.3. I didnt think it would be a big difference but it sure is. getting like 14mpg . Its been tuned by two of the top tuners in the US as well. I baby it as well. I wish i never put it in. My 5.3 got at least 18 in town. Also I thought i would notice the torque increase around driving around town but its not that huge of a increase.
Update. The factory 6.0 needs a bigger cam in it. I did this and I enjoy the 6.0 now.
Old 11-26-2013, 09:53 PM   #116
vannatta20
vannatta20's Avatar
I just ran it to ignition hot wires behind the dash.
Old 11-26-2013, 09:56 PM   #117
JP238
JP238's Avatar
Gives it a nice little touch. I like it.
Old 11-26-2013, 10:38 PM   #118
solidaxel
solidaxel's Avatar
I cut the front legs off and welded brackets on i found at a hardware store. Ill post some pics tomorrow. I need to get them recovered and looking at options now. I have cruise switch installed on the orgianal turn signal stalk. Ill post some pics and a how too on that.
I am at that stage now so I am waiting for pic.
LS 3 4L70E
Old 04-15-2014, 11:31 PM   #119
vannatta20
vannatta20's Avatar
Did my first autocross run this weekend! Felt strange pushing the ol truck around on the course. Truck held together!
http://youtu.be/LgogK_FevgM
Old 04-15-2014, 11:47 PM   #120
littlevictories
thats rad
littlevictories is offline   Reply With Quote
Old 04-16-2014, 07:30 AM   #121
BigCountryx
BigCountryx's Avatar
Looks pretty frisky when you got the chance to put your foot in it and was pretty flat through the twists. Bet it was fun. Nice job.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 04-16-2014, 07:58 PM   #122
vannatta20
vannatta20's Avatar
Thanks! For suspension I just have a large sway bar in front with airlift bags inside all 4 coil springs. I was shocked it handle so nice. I was just worried something would break if I pushed it hard. It also has a new cam in it which gave it so much more power.
Old 04-28-2014, 12:52 PM   #123
ChevyJr
Junior Member
ChevyJr's Avatar
Subscribed!
ChevyJr is offline   Reply With Quote
Old 05-21-2014, 02:16 AM   #124
mcmlxix
Collector of Projects
mcmlxix's Avatar
I just noticed you're in Vegas... You should come by the weekly car show/meet on Sundays. There are a couple 67/72 trucks that show up, one is a member here and has an LS1 swap.
Rich
1972 K5 Blazer CST Click HERE
Old 05-23-2014, 02:59 PM   #125
bryce1010
Talking Re: 1968 C10 5.3 swap, the easy way.
I left the original wiring under the hood alone and just added the engine harness wiring that came with junyard engine. Its all plug and play. The downside is you have to use the factory fuse box for the LS engine which is bulky and ugly but who cares if its just a daily driver. I am using the factory a/c compressor that came with the engine and hopefully by Monday it will be blowing cold air. Have less than 300$ in the a/c system.
I just found your post. I have a 1971 c10 and thinking about doing the conversion . I can get the engine and transmission and all acc. and harness and computer . all i would need to do is give the fuse box from the donar engine 12v and everything should work. Ware are the speedo and tach taken from?
bryce1010 is offline   Reply With Quote
