Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-12-2012, 10:35 AM   #101
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Got the C-notch done. Was hoping to get away without having to cut the frame, but it was necessary. Measure 54233 times, cut once.
Before I did the notch, I got the frame on jackstands, and shimmed so it's level in all directions.
Next task, while it's level, will be some additional frame bracing and boxing to beef this ***** up a little.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-19-2012, 11:08 AM   #102
Wasted Income
Boosted Member
Made room for my upper shock mount crossember.
Fabbed up some lower shock mounts.
This layout should work a lot better for handling purposes. Got the coilovers at a 15* tilt in.
The top all burned in
Also started working on wiring up the megasquirt. This is going to be an incredibly clean and small harness compared to the stock LS style harness.
Turbo diesel
Old 11-19-2012, 11:50 AM   #103
gringoloco
A guy with a truck
gringoloco's Avatar
Nice! Coilover mounts look good-plenty of room to run exhaust now.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-19-2012, 08:27 PM   #104
duallyjams
duallyjams's Avatar
I really like the built in storage tray on the frame
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-20-2012, 01:40 PM   #105
72Blazing
72Blazing's Avatar
Will that angle on the shocks limit your wheel backspace choices?
72Blazing is offline   Reply With Quote
Old 11-20-2012, 04:28 PM   #106
Wasted Income
Boosted Member
I already have the wheel and tire combo that I'm planning to run, and they fit fine. I'll get some pics one of these days. I don't want to disturb the chassis until the rest of the bracing/stiffening is done on the chassis, since it's all level and square right now.
Turbo diesel
Old 11-28-2012, 01:55 AM   #107
Wasted Income
Boosted Member
Took some much needed time off over the past week, and was able to let my motivation recharge.
Make the plates to box in the frame. Got everything prepped and tacked in place.
My driveshaft also showed up. It's a 4" aluminum unit with Spicer 1350 joints, rated at 1500 hp from Dynotech Engineering.
Turbo diesel
Old 12-05-2012, 08:03 PM   #108
jbclassix
Junk Yartist
jbclassix's Avatar
I need to get over to the blazer side more often!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-06-2012, 09:59 AM   #109
Wasted Income
Boosted Member
Chipping away at the work that needs to be done to the chassis.
All the factory crossmembers except for the one back behind the fuel tank, which I'm leaving in place, have been cut out. Still need to make boxing plates and a crossmember for the very front yet.
Turbo diesel
Old 12-06-2012, 11:29 PM   #110
87Jimmy4JP
wowzers! that is some great frame work
really coming along
JP
87Jimmy4JP is offline   Reply With Quote
Old 12-06-2012, 11:37 PM   #111
gringoloco
A guy with a truck
gringoloco's Avatar
Looks great. Do mine next
-Chris
Old 12-07-2012, 09:35 AM   #112
Hertzdaddy
Wow, I bet that frame is nice and stiff now. What is your plan for exhaust routing?
Hertzdaddy is offline   Reply With Quote
Old 12-07-2012, 10:58 AM   #113
Wasted Income
Boosted Member
Thanks guys. It actually is noticably stiffer just sitting on jackstands. Hopefully that will = a better handling and "tighter" truck.
I'm not done with the tube work yet. Might re-do/modify a couple things to be more structurally sound.
Exhaust will be either a 4" or 3" downpipe. I will worry about routing it when the time comes, but I can say it will not exit out the back of the truck. Probably out the side in front of the rear wheel. Might even get stoopid and do a fender dump
Turbo diesel
Old 12-07-2012, 08:50 PM   #114
Slinger60
Slinger60's Avatar
Really nice work on the frame. Looks like a lot of hours laying that out and welding it all in.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 12-08-2012, 08:48 PM   #115
Luba
Luba's Avatar
Nice!
Luba is offline   Reply With Quote
Old 12-09-2012, 12:18 AM   #116
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Wasted Income View Post
...Might even get stoopid and do a fender dump
Yes! Make sure and dump it out the pass side so you don't have to hear it
-Chris
Old 12-10-2012, 04:52 PM   #117
Wasted Income
Boosted Member
On the latest setup, I had it dumped in the inner fenderwell on my C-10 with an electric cutout. Sounded ok, but the e-cutout burnt up, lol.
Here's a vid I put together 3 years ago after the very first turbo build on my C-10. It was with the 5.3, and the downpipe was 5" dia, and about 5" long, lol. Dumped right before the firewall under the hood. It was loud, but not too bad. The open dump wastegate was WAYYY louder and more obnoxious than the DP.
Back to the build at hand.
Decided to modify my bracing a bit. Planning to tie the trailing arm x-member into the frame up near the engine as well, but ran out of DOM tube.
Now I have to put the cab back on the chassis to make sure everything will clear the floor before I burn it all in.
I'm ready to move on to something else. The chassis work has me wore out.
Turbo diesel
Old 12-11-2012, 02:27 PM   #118
Hertzdaddy
Great sound in the cab!
"Doze whistle tips, day go WOOO WOOOOO!"
Old 12-11-2012, 10:54 PM   #119
Splash4195
Wow nice build!
Splash4195 is offline   Reply With Quote
Old 12-12-2012, 11:17 AM   #120
Wasted Income
Boosted Member
For the guys that were asking, there appears to be plenty of tire clearance with the current coilover mounting location
LS3 top end goodies. Think I'm ready to start working on the engine and put the chassis on hold for a bit.
Turbo diesel
Old 12-12-2012, 04:56 PM   #121
floyd
An X in that section would be stronger and take out more chassis twist if it would fit and not create driveline fitment issues.
floyd is offline   Reply With Quote
Old 12-13-2012, 02:25 PM   #122
Wasted Income
Boosted Member
Thanks. I realize that, but I can't do an X with the driveshaft in place. There's not room.
Turbo diesel
Old 12-13-2012, 05:42 PM   #123
gringoloco
A guy with a truck
gringoloco's Avatar
Looks good! Lots o' work in that frame so far. It will be worth all your hard work and planning in the end.
-Chris
Old 12-15-2012, 09:57 AM   #124
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
Subscribed!!!
Love the build!! Never had an urge to get a K5 really, but just the idea on how this is going to turn out is giving me the itch to find one. Great work, if I can lend a hand from Tx, let me know haha.
Chris's Monte Carlo is a hell of a machine also. I'm guessing you had a hand in that as well? lol
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 12-20-2012, 03:57 PM   #125
Wasted Income
Boosted Member
Thanks Kris.
Yeah, I built and tuned the whole car in my shop in IL. My brother Dan did quite a bit on it as well. I know Chris would have been balls deep in the project had he been living closer, but he did help me build the motor.
Turbo diesel
