Old 01-31-2013, 08:50 PM   #101
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: The Hillbilly Deluxe dually build
I was pretty much kidding about the wife finding out. I'm a pretty grouchy bastard and she knows better than to try and mother me when it comes to my health. Whenever a woman tries to nag me about something, I tend to usually do the opposite thing to the extreme.
As far as the China deal....
We use Phoenix brand simulators on all our ambulances at work. They're the expensive ones. When you price them, they run about double what these Summit brand ones do.
The Phoenix logo...
The logo on the Summit ones...
Old 02-01-2013, 09:39 PM   #102
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good. Hope you feel better...I hate being sick...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-05-2013, 04:15 PM   #103
Tx Firefighter
I am happy to report that with the shiny new wheel simulators the truck gets better mileage, burns less oil, hauls more weight, and even some of the hail dents popped out.
Not really, but it's definitely earning it's keep like I hoped it would. I still have a long way to go before it's fixed up nice enough to please me but the truck has good bones underneath it so it's just a matter of continuing to plug away at it till it's real solid and slick.
Other than the bellhousing, I'm thinking I'll try to pick up a decent hood for the truck and shoot it white and stick it on there. The present hood has a crack in the front of it, is beat up, and obviously is paint challenged. I know the new painted hood won't match perfectly, but it can't look as bad at the hood on it now does.
Old 02-05-2013, 04:31 PM   #104
68Timber
I know the pieces fit
68Timber's Avatar
A Deweze bale grabber would be slick on your rig.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-05-2013, 04:34 PM   #105
Tx Firefighter
Lord, don't I know it. I hate having to roll those flat bottomed bastards off. The freakin animals are always up there trying to eat the stuff right off the bed and I'm pushing, shoving, and cussing trying to get it to roll off onto the ground.
Old 02-05-2013, 04:39 PM   #106
OutlawDrifter
haha, about 10mph in reverse and stand on the brakes.....
i generally run a rope around the bale to a good post/rea pole and drive out from under it.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 02-05-2013, 04:42 PM   #107
Tx Firefighter
I was just thinking of that this morning. I'm going to weld a tie down on the back edge of the bed in the center. Then I can hook a chain to it and lay it out forward so they set the bale on top of the chain. Then when it comes time to unload, just throw the chain over the top of the bale and tie it off to something and yank.
Old 02-17-2013, 01:14 AM   #108
JellyBeanDriver
just ran across this thread. LOVE your truck!
There's an 86' C30 dually crew cab (454, AT) at our Ranch that I've been working on so it's been fun watching the improvements you've made to yours.
JellyBeanDriver is offline   Reply With Quote
Old 02-17-2013, 10:36 AM   #109
Jonboy
Slots go on anything!
Kevin, I have a decent white hood, too. I had a left fender, but I think it might have walked off. Next time you are over this way, come get it.
Old 02-17-2013, 03:35 PM   #110
Tx Firefighter
I'd like to have the hood. If you keep supplying me parts I'll have to change the name to the Tx Firefighter/Jonboy build thread.
Old 02-17-2013, 08:02 PM   #111
JellyBeanDriver
Do you have an engine oil cooler setup? Our ranch truck does. Leaking rubber lines like everyone else's so I read.
Old 02-17-2013, 10:36 PM   #112
Jonboy
At least someone is getting some building done. I'm a quitter.....
The hood has been over at the warehouse I store my junk at. It's just a few minutes from the house. Let me know when you are over this way. I don't think it's going anywhere soon.
Old 02-18-2013, 11:52 AM   #113
Tx Firefighter
No oil cooler on this one. I agree about the leaks. The dually I had before this one was a 94 model with a 454 and I wound up putting some money into replacing both hoses and all of the connector ends.
I'll have to figure out how to put something together. I could nearly buy a new hood for the cost of fuel driving the dually over there. Will need to figure out an alternative transport method. Regardless, I'll give you plenty of notice beforehand.
Old 02-18-2013, 04:24 PM   #114
JellyBeanDriver
Thinking of cutting off the crimps, getting hose from a hydraulic store and putting worm gear hose clamps on. I hear even the replacement dealer or Dorman hoses leak again quickly.
Will have to review your steering gear box resealing - probably going to do that to ours in the near future.
Old 02-18-2013, 07:57 PM   #115
SCOTI
SCOTI's Avatar
Which side are you guys having issues with as far as leaks?
My CC dually had an aftermarket set-up @ the heat exchanger side & OE GM adapter @ the block. It had rubber hose w/barbed fittings & typical worm gear style clamps @ the heat exchanger side to alum lines & compression fittings @ the adapter side.
When I did the motor rebuild, I tossed the previous heat-exchanger & related parts (didn't want to worry about trash screwing up the fresh motor) & installed the same style (kit) w/new alum lines, new compression fittings, new rubber hose, & new barbed fittings (I re-used the GM adapter @ the block). For symmetry, I also did a duplicate heat-exchanger arrangement for the trans.
I didn't have leaks before & hoping I don't now....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-19-2013, 02:53 AM   #116
JellyBeanDriver
Mine are at the crimps to the rubber hose - both ends.
Seems to be a common problem. Don't know if the rubber flows out of the way over time due to hot oil contact or what.
Most replace with factory parts but I read one post where a guy cut off the crimps and used standard hose clamps to eliminate the leaks.
Old 02-19-2013, 03:06 AM   #117
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 02-19-2013, 10:11 PM   #118
Tx Firefighter
Again, this truck has no cooler, but my 94 did. It had the kind with threaded fittings into the block with quick connects rather than the sandwich adapter under the oil filter. It was all leaking so I bought two new lines for it and new quick connects to screw into the block and the trouble went away. I have since sold the truck to an oilfield welder and he puts about 5k plus miles per month on it (a 454 at 9 mpg...ouch) and it still doesn't leak.
Old 02-21-2013, 02:23 PM   #119
Tx Firefighter
Not much new to report on this truck right now. It's been too busy earning its keep.
Old 02-21-2013, 02:26 PM   #120
lolife99
67-72 parts collector,…
lolife99's Avatar
What's the plan for the step bed?
Keith
Convert to disc brakes.
Old 02-21-2013, 02:48 PM   #121
Tx Firefighter
I kind of fell into a project recently. I've been collecting a lot of parts for it. Basically I'm building a beater truck to drive that gets better mileage than this big block does. I'll start a thread when I begin to put all the parts together.
As many years as we've been on here together, I'd bet money you could basically guess my build plan. I always build them basically the same.
Posted via telepathy from my rotary dial phone
Old 02-21-2013, 02:53 PM   #122
Stoney
Farm Truck
Stoney's Avatar
What happened to the Blue one you put the new motor in?
Window tint the Hillbilly?
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 02-21-2013, 03:10 PM   #123
Tx Firefighter
I don't have that truck anymore unfortunately. It wound up being the single worst screwing I ever took in my life. It was a deal with my stepson. He took the truck and moved out, breaking a deal we had. I can't even convey the extent of how bad that one stung me. It still ruins my whole day about once a week or so.
Old 02-21-2013, 03:14 PM   #124
Stoney
Farm Truck
Stoney's Avatar
Can't go get it?
1969 CST/10
1984 K5 Blazer 4x4
Mike
Jersey Village, Tx
Old 02-21-2013, 03:37 PM   #125
Tx Firefighter
Nope. Like an idiot we shook hands an looked each other in the eye and went down to the courthouse and swapped it into his name. He left two days later.
You can't imagine the heartburn it has caused me.
