Old 01-06-2015, 01:33 AM   #101
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: My 1961 crew cab- XRMYCRU
are you just using the yellow crew cab as a guide to build a new one ?
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-06-2015, 01:50 AM   #102
Captainfab
60-66 Nut
Nice progress Jon
Old 01-06-2015, 02:08 AM   #103
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
pretty much, as far as I can tell right now I will salvage the "B" pillars, some of the upper roof rails and part of the roof. Also the rear doors.
Old 01-06-2015, 08:28 AM   #104
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Looks kinda Partridge Family with all the different colored panels. lol
you must be so happy with this project. You make it look easy.
Old 01-06-2015, 08:29 AM   #105
Lokin4AReason
Lokin4AReason's Avatar
nice progress .....
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 01-06-2015, 11:02 AM   #106
piratexpress1369a
piratexpress1369a's Avatar
nice work ..rhino lining will work ..make sure you do the perp for it
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 01-06-2015, 01:12 PM   #107
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
I thought the cops got the perps?? LOL
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 01-11-2015, 01:02 AM   #108
jonzcustomshop
1961 crewcab
well, some steps forward,back, and forward again.....
next, before I set the "B" pillars I need to get the doors on and lined up.
Of course I let the driver door freeze to the ground... so I was waiting for a thaw, and then remembered that I had brought a few sets of doors home a few years back, when I was ambitiously thinking of starting my own crew build... lo and behold, the front set I have behind the shed were not frozen down, and much better than the green set I was going to use.....
so now I get the doors hung, and I see that the driver rocker is definitely not going to work...I checked it with a straight edge, and it was pulled in about a 1/4 inch where the orange , and seafoam green piece meet up., the passenger side is perfectly straight.
so, I ripped all the tack welds on the edge of the new floor panel, re-drilled my spots on the green piece and used a friction jack to push the rocker out to the right place.
now it is all straight and the door fits, so now I can get started on the "B" pillars...
Old 01-11-2015, 01:54 AM   #109
Captainfab
60-66 Nut
I hate it when that sort of thing happens. Glad to hear you got the issue fixed. Looking good Jon
Old 01-11-2015, 10:53 AM   #110
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Looking good Jon ...
I know this will turn out to be an awesome crew !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-11-2015, 01:48 PM   #111
piratexpress1369a
looking good ..stay at it
63
Old 01-13-2015, 01:34 AM   #112
jonzcustomshop
1961 crewcab
wanna see some scary sh--??
I couldn't see in there , but the camera could.. this is the spot above the driver door.
I am trying to figure out how this roof piece was made. Unfortunately it is so rusty I can't tell if it is 2 pieces, or 1.
If it is 1, then it starts (as a cross section) 12 inches from the edge of the roof, comes to the drip rail, and folds in: like a 1/4 inch tall backwards "C", then continues in as the top of the door jamb, and down, to end at the edge of the weather strip.
It seems like a rather complex piece compared to some of the others that were made. if it is 2 pieces-which would make more sense for the ease of forming, it would end at the "C", but I can't find the weld if it is there due to the rust.....
in other news, I did get a rear axle hung in there so I can roll it around. It is resting on the bump stops....
picture 3 is inside the door jamb looking forward to the seam with the factory roof skin
picture 4 is looking towards the back.
Old 01-13-2015, 01:53 AM   #113
Captainfab
60-66 Nut
I don't know for certain but I would think that the easiest, simplest way to fabricate that piece would be how it was done back then. And probably the easiest and less costly for you as well.
Old 01-16-2015, 10:35 PM   #114
awbrown
You should make some patterns of the pillar once you get to that part of the project , I am wondering what gauge metal they used for that ....
awbrown is offline   Reply With Quote
Old 01-23-2015, 07:32 PM   #115
jonzcustomshop
1961 crewcab
here is the upper portion of the "B" pillar, you can see the stock windshield pillar from a 61 that was used, and the little filler piece that they fabbed to tie it together.
Old 01-23-2015, 07:49 PM   #116
jonzcustomshop
1961 crewcab
here is the lower inside, it is all wet, because I have soaked it down with Lysol, there was another mouse nest in here about 8 inches deep at the bottom.
this shows the support plate that was used for the hinges, it also shows the "cages" that were put in for the hinge bolts to make them adjustable.
the last shot shows a cross profile of the outside edge, judging by what I can see from the inside , the rear portion of the pillar that they fabbed (front of the back door jamb) had a 90 degree bend on the outside edge. it was about a 1/2 inch in from the edge of the front portion (which is a rear door pillar), the nice curved portion that you can see is all lead.
Old 01-23-2015, 08:39 PM   #117
jonzcustomshop
1961 crewcab
1) at the bottom of the pillar , the coach builders just cut it off level with the rocker, since mine is going together a bit differently in the rocker area I was able to use the factory brace that bolts to the mount/rocker, this also solved a rust issue.
2) at the top my upper roof rail will go together a little different, so I used the orange piece, since it wraps under the gutter.
3) the white piece was used in the back to fix a rust issue, and to better mount it to the jamb- when I took this piece apart, at the top there was just lead, 1/2 inch X 1/4 inch thick molding all this together, and covering the hole!
4&5) here is the rain gutter/ upper door jamb that I had a metal shop bend up for me.
Old 01-23-2015, 08:44 PM   #118
jonzcustomshop
1961 crewcab
here it is mocked up:
pic 2: the lower rear portion is going to need a new piece fabbed, there is rust in between the inner plate and outer sheet metal, and the part that welds to the rocker must have busted loose and been re- welded several times when this truck was being used.
Old 01-23-2015, 09:56 PM   #119
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Wow...About the only thing i haven't built is a crewcab.....but your doing some good work there . Steel replacement is one of those things ya can't rush and it eats up a bunch of time....good job
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 01-23-2015, 10:08 PM   #120
awbrown
Your friend did a nice job on that upper sill plate .. how thick is the metal they used to reinforce the hinges inside the pillar ??
I guess you wont be using much of the original cab , you needed it mostly for measurements and the pillars .....
Old 01-23-2015, 10:10 PM   #121
padresag
looks good Jon. they had lots of lead in that ambulance to
ron
padresag is offline   Reply With Quote
Old 01-23-2015, 10:38 PM   #122
CHIZZLER
CHIZZLER's Avatar
your metal work is looking good.
61-crew cab D-max
Old 01-23-2015, 11:46 PM   #123
jonzcustomshop
1961 crewcab
thanks!
yeah I wasn't sure if it could be bent, but I gave him a cross section, and he whipped it up in less than a half hour!
as far as I can tell it is 1/8th inch, or maybe 1/32nd less than that, the sheet metal part is the thicker gauge, like what gm used on the pillars and braces, 16 gauge I think?
... and it killed me to cut that pillar out of the cab!! kind of a point of no return. I'll use the doors too. However just seeing how it is/was/can be done was worth it.. lot of stuff that I just couldn't figure out from the pictures I have.
ron
I pulled the door/pillar off as one piece, and I couldn't believe how heavy the unit was ! I could barely lift it.
thanks! hope some of this helps you as well, you have about 1/2 the repair I have to do
Old 01-24-2015, 04:05 PM   #124
65sub
65sub's Avatar
Great metal work. Inspiring to watch
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-24-2015, 07:53 PM   #125
clemdaddy
clemdaddy's Avatar
man oh man, just read your thread and what a project. big kudos just for undertaking this beast. your work looks good but the noodling you've done to fix stuff is beyond me.
great job... now i want a crew too...
clemdaddy is offline   Reply With Quote
