10-02-2020, 09:23 AM | #101 |
Re: 57 Truck build
ok thanks bud. did you spray it on or use roller/brush?
10-03-2020, 08:26 AM | #102 |
Re: 57 Truck build
I started out brush and the went to spray with a $9 dollar HF gun. The trick is thin coats. I’m going to use the Blacktop again on the core support and brake booster.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
10-03-2020, 06:44 PM | #103 |
Re: 57 Truck build
ok great, thanks bud... keep chipping at it!
10-14-2020, 08:04 AM | #104 |
Re: 57 Truck build
Sunday I started the tear down of the 4.8. Over all the engine looks good but 100k has made it a little dirty. I also found some light rust in the cylinders but nothing a hone wouldn’t take care of. Since I had Monday off I decided to drop it off to my friends machine shop to get freshened up. I’m just going to do new bearings, crank polish, HP cam, upgraded rod bolts, lS6 lifters, timing chain, clean and hone. The bottoms end will be taken care of. Heads will get cleaned, checked warp, lap and new ls6 springs. I also decided to service the trans and give it a new paint job. We’re slowly getting there!
10-14-2020, 08:12 AM | #105 |
Re: 57 Truck build
Looking good....Cleaning those LS motors that have been in a vehicle for 100k miles can difficult to de-gunk them...Nice work.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
10-14-2020, 08:55 AM | #106 |
Re: 57 Truck build
I was going to just clean it myself, hone and lap the valves but after looking at it was real dirty. It came out of a company fleet truck. I just wanted to make sure that the bottom end was solid for my log show trips.
10-18-2020, 02:47 PM | #107 |
Re: 57 Truck build
I started back on the cab while the engine is at the machine shop. Today I removed the front firewall panels, bad front Upper windshield piece and POR 15 the inside. I dint like they way the front panels looked with a bow in them. I also cut the filler price for the inside panel. I got the old one out nw I’m trying to figure how to install the new front panel without removing the inner one. I guess I’ll cut it in half to get it in and weld it together once it’s in place. Any advice On the front upper pice is welcome.
10-21-2020, 06:47 PM | #108 |
Re: 57 Truck build
Truck is looking great!
When I replaced that panel I cut off about 1” of the overlap at one end. Started installing on the other side and then twisted the other side into place. I then finished with a small filler on the side I cut. It’s all covered by the seal so it doesn’t have to be pretty Can’t remember if I had the inner visor panel removed when I installed it.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
10-22-2020, 07:48 PM | #109 | |
Re: 57 Truck build
10-22-2020, 07:53 PM | #110 |
Re: 57 Truck build
When I did mine I had to replace a similar length of the inside too. Made it easy.
10-24-2020, 06:02 PM | #111 |
Re: 57 Truck build
Started back on the upper windshield frame this morning. I cut about a 4in piece so I could get it all to fit back into place with the new piece. Overall it came out good. I think the hardest part was getting it welded. I had to flip the cab on the back to weld it without getting hit with sparks and slag. I still have to finish weld and grind the inner piece to get it smooth. I’m happy with the outcome.
11-22-2020, 07:05 PM | #112 |
Re: 57 Truck build
Got the engine back from the machine shop. Did a little refresh, ring, bearings and cam. Decided to keep the the vintage vibe and paint it all orange. I think it came out great! Just have to mate the engine and transmission. Now I’m debating on changing the intake and serpentine system. I’m looking at Holly intake and ICT serpentine system.
12-05-2020, 07:31 PM | #113 |
Re: 57 Truck build
Finally have the engine and transmission together and back in the frame. I only need a few more things and I need to buy and the engine update will be done. Then back on the cab again.
01-10-2021, 12:18 PM | #114 |
Re: 57 Truck build
I haven’t posted in a while. I have been doing a lot of grinding on the cab from all the metal work. So again not an exciting post. As always I find more rust that I have to repair. I also had a big dent in the roof that I managed to get out. Took me all day. I also started the mock up for the rear speakers, sub, amp and ECU mount. Thanks to Bigblock 73 for the speaker mounts. I also found some sweet ECU mounts. They are going to look great on the rear panel. I have the media blaster on for 1/30. Hopefully it doesn’t reveal anymore rust to fix. I also scored a great deal on a 60 gal compressor. Already hooked up and can’t wait to see what it does!
01-10-2021, 05:38 PM | #115 |
Re: 57 Truck build
Lookin good john, Gotta love new tools (air compressor)....If may offer a bit of advice with the media blaster... try to hit the big areas with a strip it disc, like the roof, fire wall, back of cab , it wont take that long to do and save you a bunch of aggravation with warping
01-10-2021, 06:31 PM | #116 | |
Re: 57 Truck build
01-31-2021, 07:44 PM | #117 |
Re: 57 Truck build
Went and had the truck blasted today. The wind was real bad today and blew the cab off the trailer. Luckily it just damaged the lower part of the cab. With a little hammer and Dolley I’ll have it back to normal. The cab came out good with a few of small rust spots to fix.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 Last edited by Rickysnickers; 02-01-2021 at 11:43 AM. Reason: Flipped photos |
02-01-2021, 10:22 AM | #118 | |
Re: 57 Truck build
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
02-02-2021, 01:29 AM | #119 |
Re: 57 Truck build
Nothing warped. In fact the blasting helped on some warped spots. This blaster knew what he was doing. He told me areas that could warp and he took it easy. I’m ready to get my ac mocked up and fix some bad spots that came out after blasting then I should have it in epoxy. Then the mud work come in.
02-02-2021, 09:31 AM | #120 | |
Re: 57 Truck build
Who's A/C system are you using? I want to prep my firewall for A/C before sending off to blast. I am going to use the vintage wireless kit right now. Steve
02-02-2021, 11:04 AM | #121 |
Re: 57 Truck build
It’s looking great. You’re making awesome progress!
02-02-2021, 11:37 AM | #122 | |
Re: 57 Truck build
02-02-2021, 11:38 AM | #123 |
Re: 57 Truck build
Thanks! I’m really trying to get something done before the end of the summer.
02-02-2021, 12:09 PM | #124 |
Re: 57 Truck build
looks great john, I gotta get movin on mine.... your catchin up to me... lol
02-02-2021, 02:55 PM | #125 |
Re: 57 Truck build
That’s the plan!
