Old 03-05-2013, 04:55 PM   #1401
6lcummins
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by Vintage Windmills View Post
Why do you want to box the frame? the longhorn frame has a high modulus (resistant to bending) to begin with. Its a one ton frame.
700HP/1400LBS FT of torque is a good start to why its getting boxed.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 03-05-2013, 05:17 PM   #1402
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Wow, thats crazy power. makes sense given that
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-05-2013, 05:26 PM   #1403
watahyahknow
watahyahknow's Avatar
im kindah wondering if boxing the frame will cause it to crack near the crossbraces where you need to work the plating and welding around ,
wat might work is to get a second frame take both the original and the extra apart so you only have the framerails make one of those thinner cut them towart the bended part so they shut straight ontoo the other original rail and swap left to right and vice versa , cut and shut the crossmembers so they fit ontoo the inside out and thinned framerail and you still can use the original bodymounts on the outside part on the original framerails and can still fit the front suspention parts after you remount those , put the original framerails on the outside and weld them together to get a boxsection out of one piece , only the part near the front suspension needs sumting made as it bends in more than one direction
its hard to explane but basicly you make the boxplates out of one piece using the extra frame and change the crossbraces to fit and be mounted to the inside plates so they dont go through the plates to the other frame and keep the original frame as is exept for the crossbraces everything mounted on the outside of those rails need to stay at the original location and at the original width
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-05-2013, 06:05 PM   #1404
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I highly doubt the frame will crack. It's already a pretty heavy duty frame. Plus I'll be redoing some cross members and the GN hitch will be sitting on 2"x4" 1/4" tube. I'm sure it'll be rigid as all get out. This isn't a trail truck, so I won't be trying to twist it up either.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-05-2013, 06:09 PM   #1405
Dieselwrencher
Originally Posted by ryanroo View Post
you should find out, i might be convinced to make a set of offset zero rates...
i am pretty sure i can make them out of 1/2" so it doesnt alter the height much
Ryan
Of course, after I ordered mine already. Thanks buddy!
Because if I don't, I'll never hear the end of it from a couple of net thugs.
Originally Posted by MrBeast View Post
The older dodges also had a ton of problems with cracked frames.
The biggest problem were their front frame horns. It was a really chitty design. They also had steering box frame area cracking issues too. It also couldn't have helped that those frames were started in the early 70's and just modified clear up until the early 90's.
Ryan
Old 03-05-2013, 06:11 PM   #1406
Dieselwrencher
It's amazing that I've lost the little bracket that holds up the steering column against the brake pedal bracket twice during this build. Man, it'll be nice when this thing has all it's parts bolted on it.
Ryan
Old 03-05-2013, 10:04 PM   #1407
ryanroo
ryanroo's Avatar
peer pressure...
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-05-2013, 11:08 PM   #1408
jbclassix
Junk Yartist
jbclassix's Avatar
thats... wow. i deleted my complement cuz it wasn't big enough.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-05-2013, 11:55 PM   #1409
Dieselwrencher
It definitely has the fuel and air for 700hp, it just needs all the little stuff to make it fire, and put it to the ground.
Ryan
Old 03-05-2013, 11:57 PM   #1410
Dieselwrencher
peer pressure...
Tick, tock, tick, tock.
Ryan
Old 03-06-2013, 12:20 AM   #1411
MrBeast
high-Tech Red Neck
MrBeast's Avatar
https://www.youtube.com/watch?v=rTyN-vvFIkE
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 03-06-2013, 01:02 AM   #1412
ryanroo
ryanroo's Avatar
was that my kick in the junk?
72 K20 12v build
Old 03-06-2013, 01:37 AM   #1413
Mattman2010
Mattman2010's Avatar
You convinced me to box mine, so its only right if you box yours too right?
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 03-06-2013, 04:14 PM   #1414
Dieselwrencher
You got me there.
Ryan
Old 03-06-2013, 05:22 PM   #1415
Dieselwrencher
Ok, here's what I have to finish before I can work on the Longhorn a lot. I'm porting and polishing a 24v head for a 2002 Dodge. We had this head milled and o-ringed. The o-ring provides more force to help keep the head gasket's fire ring in place and not blow causing a blown head gasket. I'm still in the porting stage. These heads are very hard and can be really hard to port.
This is what the stock ports look like. Intake side is on the left of the picture.
Non ported on the RH, ported on the LH.
Exhaust side. I will gasket match each port and feather it in to the exhaust ports. The smaller ones are stock size. I will flip the head over and do the lower portion of the runners later.
Stock Exhaust ports.
Stock, not ported yet.
These are ported.
Ryan
Old 03-07-2013, 02:48 PM   #1416
cAlvis165
cAlvis165's Avatar
You guys seen these?
Going to make them for the 12v first and then on to the 24v.
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 03-07-2013, 04:25 PM   #1417
Dieselwrencher
Yes I have. They are still trying to get the braking power side of it to work better. They sound cool, but I guess don't brake well yet.
Ryan
Old 03-07-2013, 04:38 PM   #1418
watahyahknow
i think a retarder / magnetbrake would work better ,
i have seen motorbrake stuff but i think it works by smothering the intake air while cutting the injectors the vacuum makes the engine resist reving when running downhill in gear , prolly whont work with turbo's as they get hurt when you cut the air intoo them ... sucks the oil right trough the seals
Old 03-07-2013, 05:05 PM   #1419
Dieselwrencher
I bet a magnet brake isn't cheap either.
Ryan
Old 03-07-2013, 05:15 PM   #1420
Dieselwrencher
More porting pics. Man, this is a lot of work and hard on a guy's back.
It's hard to capture some of the angles and such with the lighting.
Ryan
Old 03-07-2013, 05:43 PM   #1421
Dieselwrencher
Oh yeah, a couple of days ago I put on the LH door handle. That's progress. Right?
My ORD zero rates came today and I plan on putting them in this weekend.
Ryan
Old 03-07-2013, 05:49 PM   #1422
watahyahknow
definetely not , i was looking intoo using a set of those for a dynomometer-rerthingamajig and there way up there pricewize , they dont wear out though as here no parts touching it kindah works like a dynamo creating its own power to create the magnetic field
the cast iron disk usually isnt coated verry whell and there sitting behind the transmission in the open air so they look like a big ball of rust when you do find them at a truck wreckingyard
there was a show on discovery some time back that incolved a landspeed record attempt using some jetfighter turned intoo a car , they used a thick aluminium disk that turned with the wheels and another one that was stationairy next to it on the axle with permanent magnets in them
to brake they put the plates with the magnets closer to the rotating disk and the magnetic field caused the disk to resist rotating , it worked harder if the wheels where spining fast and redused in drag when the wheels started spinning slower , it allso didnt create heat
Old 03-07-2013, 10:05 PM   #1423
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nice job on the head porting, you can really tell the difference on those exhaust ports!
Now show us your weapon of choice for all that!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-07-2013, 11:00 PM   #1424
jbclassix
Junk Yartist
jbclassix's Avatar
Ok, I am guessing that zero rates relocate your axle off the center pin with no degree change correct? I am not getting the 2-hole, 3-hole thing. I have never used them before. Educate me.
-Jeremy
Rebuilding an NP205
Old 03-07-2013, 11:30 PM   #1425
ryanroo
ryanroo's Avatar
They are called zero rate add-a-leaf. they can recenter the axle or not. they are called add a leaves because they become a part of the springpack when you bolt them on with the center pin but do nothing to change the springrate like a normal add-a-leaf. the 2 hole three hole is the choices for moving the axle forward or back
Ryan
72 K20 12v build
