Old 12-27-2008, 02:39 AM   #126
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1969 Chevy CST/10 comes home [Long-term project "OrangeCrush"]
I see you are looking for 17" tires. Once you decide what you need look at Craigslist. I saw quite a few on there at decent prices.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-27-2008, 08:04 AM   #127
hotrod 80
mini truck racer
hotrod 80's Avatar
Wow , it's coming along nicely . You've made great progress . Looking good .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-28-2008, 02:37 AM   #128
texanidiot25
Eat My Rust
texanidiot25's Avatar
I'll check them out. I've also got help from a friend at a local dealership too when the time comes.
Thanks man! Got the power steering lines on the box, front suspension is done for now (sway bar coming sooner or later). Waiting on the 3inch springs in rear to come, and my CPP rotors for the front so we can start on the brakes..
Anyone think a 60-66 bumper would look good on our trucks?
http://houston.craigslist.org/pts/971663545.html
texanidiot25 is offline   Reply With Quote
Old 12-29-2008, 11:51 AM   #129
kcjones
I wish I was a cowboy
kcjones's Avatar
Originally Posted by texanidiot25 View Post
None of the brackets lined up with the stock holes. But, all but 1 bracket on each bucket are flat on the floor. I drilled the holes today, waiting on my dad to bring home some large washers to back the bolts up with. As far as the two brackets that aren't flat on the floor, they are about an inch off the floor, on the corner of the seat, closest to the door hinge (Best I can describe). And for the center console, and interlocking seat brackets, a pair of tiny studs need to be trimmed off the floor for the brackets to sit flat on the floor.
So basically, if you cut the little studs off the floor, and make a 1 inch +/- spacer, your good to go. In my case, I won't be using the bucket's seat belts, just the center seat's. One reason is because the truck we pulled the seats from was totalled (a roll over), so the seat belts were probably shot. Plus, the retracter mounts in the B-pillar of the GMT-900, and doesn't seem to have enough belt if you were to mount the retracter on the floor of our trucks. But for $150 bucks, it's the cheapest set of seats I've found junkyard hunting, and the most comfortable. Lots of side by side support, and having ridden in these seats in another Silverado for long lengths of time, don't hurt my rear either.
If any of this doesn't make sense, I'll grab pictures for you.
Thanks for the info, I'd love some pics of the brackets if you can get them easily. I already have shoulder harness belts, so I'd only want the center seat belt, and I wouldn't use the belts of the seats.. I'm hoping because of this, I wouldn't have to reinforce the cab floor if I tried to install these late model seats. Thanks for the help!
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 12-29-2008, 01:15 PM   #130
texanidiot25
Eat My Rust
I used some thick body washers for all the seat bolts. IF all else fails, drilling some thick steel plates wouldn't be hard either. The center seat is locked in under the two bucket seat brackets on either side. So if you were to run the center seat's seat belts in a wreck, it would have to pull almost every bolt out of the whole set inorder for the center seat to come out. Of course, what ever you prefer, go with it.
Here's the rear bracket:
Front bracket:
You can see how the seats' brackets bolt down over the center consol's.
This bolt, the front outer most bolt needs a spacer. My dad had two chunks of aluminum laying around so we just drilled them out and that acts as our spacer. The seats also come with plastic covers to hide all the bolt holes so all in all, it's a pretty clean setup.
Old 12-29-2008, 01:52 PM   #131
LuckyHenriksen
LuckyHenriksen's Avatar
Lookin good man! That orange beast sure cleaned up nice, and I really like your "ghetto bent" fan shroud. It looks great! What did you use to give it that "brushed" look?
Heres a toast to you and all the other young guns out there!
Salud!
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-29-2008, 02:27 PM   #132
kcjones
kcjones's Avatar
I sincerely appreciate the pics. So, up my mouse motor to 400+HP, or install seats first....
-Kris
Old 12-29-2008, 02:43 PM   #133
LuckyHenriksen
do the motor jones! you can always sit on some old milk crates
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-29-2008, 09:54 PM   #134
texanidiot25
Eat My Rust
Or no seats like I did. Just rolled around for the day while installing these seats with nothing.
Salud!
Salud amigo!
Used a scotch pad? The name of it escapes me right now. It looks good for sure.
I love my new powder coating gun:
Here's a good before and after story:
Start:
Sand blasted
Powdered
Toasting at 400* for 15 minutes
Done
Old 12-29-2008, 09:54 PM   #135
texanidiot25
Eat My Rust
Alternator bracket. This is the paint from a year ago.
Now:
Also the power steering pump brackets are all PC'd. Way easier than spray paint to get a good finish.
Power steering is in and done
Old 12-29-2008, 10:02 PM   #136
LuckyHenriksen
Cool powdercoat. Are you doing it in a BBQ?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-30-2008, 12:08 AM   #137
texanidiot25
Eat My Rust
An old toaster oven. Does it perfect. 400 degrees and the powder bakes for 15 minutes and the toaster oven can only count to 15 minutes on the timer. So it makes baking almost fool proof. Way faster than spray paint once you get things rolling too. Don't have to wait hours to cure 100%. After that 15 minutes of baking, and 10 minutes of cool down it's 100% cured.
Old 12-30-2008, 12:10 AM   #138
LuckyHenriksen
Awesome I want to try that! What gun setup are you using?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-30-2008, 12:19 AM   #139
texanidiot25
Eat My Rust
Killer xmas present. I'm tempted to do my wrenches in this stuff too If you get one, buy a pressure regulator (required) and a water seperator... The one that's on it is junk and blew up on me. The gun works best at about 15-20 psi.
Old 12-30-2008, 12:34 AM   #140
LuckyHenriksen
Cool thanks for the tip
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-30-2008, 12:43 AM   #141
texanidiot25
Eat My Rust
If you have a harbor freight near you, this is where my dad got it too. Think I may have a coupon for HF if you want it (email).
Old 12-31-2008, 12:14 AM   #142
texanidiot25
Eat My Rust
Check out the wheels that won't be on the truck any time soon:
Late model GM truck wheels. Need atleast 1.5 inch wheel spacers, which are retardedly expensive.
Old 12-31-2008, 01:20 AM   #143
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
Wow man, my dad just told me I could have his Olds 442 steering wheel cause I asked him about it after seeing yours. If you find what that center button is from let me know! I'm thinking about doing that same seat upgrade as yours too. It looks wicked in there! I'll get started on that rendering as soon as I can.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 12-31-2008, 02:04 AM   #144
texanidiot25
Eat My Rust
Killer, glad my truck has given some ideas for you.
If you have some time, I'd post my pics up on The H.A.M.B. and see if they know. Their a bunch of old school hot rodders, incredible knowledge but don't step out of place or they'll rip into you.
Old 12-31-2008, 02:27 AM   #145
MrBeast
high-Tech Red Neck
MrBeast's Avatar
You know I have been watching your build from afar for a while, It seems to me like you really love your old truck.
I tell you what, I am in Corpus, I am going to School to be a Machinist, Classes start up in a couple of weeks, if you want to pick up a chunk of Aluminum that I can cut those spacers out of, I will do it in class for you, and save you a fist full of pesos.
Let me know if your interested.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 12-31-2008, 02:48 AM   #146
texanidiot25
Eat My Rust
I will gladly take your offer. Let me get with my dad tomorrow and figure something out.
6061 Aluminun plenty strong? Found an online place that can supply a pair of 7x1.5in round blocks for about 82 before shipping. Just was a quick price check.
Old 12-31-2008, 10:28 AM   #147
MrBeast
high-Tech Red Neck
MrBeast's Avatar
6061 should work mighty fine, do you need 4 spacers or 2? And how thick do they need to be?
Old 12-31-2008, 01:18 PM   #148
texanidiot25
Eat My Rust
They need to be 1.5 inches thick for the rear. But the hub sizes are different between my axle and this rim (Dana 60 hub is bigger than the rims center hole). But if you were to do custom spacers, the side that faces the axle can be machined for the axle's hub, and then a new hub "lip" can be machined on the spacer to center the rim. Atleast that's just what I thought up last night.
Just the 2 for the rear, I'll see how the wheel and tire fit on the front today
Old 12-31-2008, 01:40 PM   #149
LuckyHenriksen
lookin good!
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-31-2008, 01:53 PM   #150
kcjones
kcjones's Avatar
As long as the wheels and lugnuts are lug-centric (most are), the spacer doesn't actually have to match the wheel's hub, only has to be large enough for the axle hub.
-Kris
