Old 05-01-2009, 01:13 AM   #126
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Originally Posted by Jvsapp View Post
FF looking back through your thread, i just noticed that you have the master cylinder on it's side. are you planning to run a remote tank? and how did you calculate the brake pedal pin location? without the booster so that the brakes won't be too hard to use?
Yes it is turned 90* and I will be building/using/mod'ing a custom reservoir which will mount on top of the MC with feed tubes down to the inlet ports. Should bleed fine with the normal bench bleeding procedure.
I don't have the measurements in front of me but I moved the clevis up 1/2". That was as far as it could go and still get full stroke on the MC given the pedal/floor room. Add to that the fact that the s2000 weighs 33% more than the Minx (2800 v 2100), and I expect the pedal feel to be somewhere between power and manual brakes. Should be fine, but I can always make improvements if needed (that's my standard answer if you haven't noticed ).
Originally Posted by neto View Post
Amazing build! That thing is going to fly. I have an S2000 stock and it moves like you wouldn't believe. WOW.
That's good to hear. I've never driven or been a passenger in one, so I'm not sure what to expect. I know they're quick and the drivetrains are pretty highly respected.
Frizzle Fry is offline   Reply With Quote
Old 05-01-2009, 02:28 AM   #127
neto
neto's Avatar
You will need some wide tires in the back. I shift right below the red line 8,000. The engine really kicks in at 5-6000 rpms. 80 miles an hour in fourth at about 6500. Fun, fun fun.
neto is offline   Reply With Quote
Old 05-01-2009, 02:36 AM   #128
Frizzle Fry
Well, I went with a higher (numerically lower) rear ratio 3.73 vs. the S2000's 4.10, combined with a lighter overall package I'm hoping the 235/40/17's will be just about right (they should break loose when I want them to).
Originally posted by gomarlins3 on s2000.com:
OEM MY00-03 (AP1) wheel sizes and offsets are as follows:
Front:
16" x 6.5", +55 offset, 205 tire
Rear:
16" x 7.5", +65 offset, 225 tire
and the OEM MY04+ (AP2) wheels are as follows:
Front:
17" x 7.0", +55 offset, 215 tire
Rear:
17" x 8.5", +65 offset, 245 tire
Old 05-01-2009, 03:07 AM   #129
VA72C10
VA72C10
VA72C10's Avatar
Looking good man!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-05-2009, 01:58 PM   #130
Mister laugh
This project continues to amaze me, i cant wait to see the finished result. Get this thing done faster I want to see the result badly now.
Mister laugh is offline   Reply With Quote
Old 05-05-2009, 10:34 PM   #131
Jvsapp
Jvsapp's Avatar
that's cool FF. something for me to try later on. i was thinking now that my corolla swap is done, i can get back on my nova. i scored a set of disc brake spindles with rotors. just needs calipers and i was hoping to use the dodge power wagon disc master i got. no room for a booster in my nova as well. are you planning to use a combo valve on the minx?
Jvsapp is offline   Reply With Quote
Old 05-06-2009, 02:22 AM   #132
Frizzle Fry
Originally Posted by VA72C10 View Post
Looking good man!
Thanks x2 I'm on the last class of my degree program so I will be accelerating this build soon!
...are you planning to use a combo valve on the minx?
Proportioning valve? I'm going to use the S2000 prop-valve since I will have all the other brake components from the car.
Old 05-20-2009, 06:34 AM   #133
dh81k30
Junior Member
dh81k30's Avatar
Mike,
You have a PM.
Have fun, Don
dh81k30 is offline   Reply With Quote
Old 05-24-2009, 03:37 AM   #134
sleepertruck72
sleepertruck72's Avatar
FrizzleFry,
Awesome work ! That Honda engine should scoot that car around no problem with alot of grins ! Its that kind of creativity that keeps old cars & trucks interesting. Cant wait to see it done
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 05-25-2009, 12:42 AM   #135
Frizzle Fry
Thank you! The last day of my last class is tomorrow so I should make some real progress this week!
Old 05-30-2009, 08:19 PM   #136
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
OK, it's been a week. Where are the progess pictures? By the way, I really think this is a great project!
low'n slow is offline   Reply With Quote
Old 05-31-2009, 06:37 PM   #137
Frizzle Fry
I've been doing the mortgage broker scavenger hunt for about a week while I should have been in the shop!
I've been out there! I've even taken a few pics ...But nothing worth showing by themselves. I started making the initial cuts in the front frame rails for the S2000 rail sections to go in. I also removed one of the inner fender braces and jacked up the inner fender a little bit in the process ...but all is fixable. More to come.
Old 05-31-2009, 07:26 PM   #138
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hey mike I went through a guy in portland when I bought my house ill try to get his number and p.m. it to ya....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-02-2009, 12:08 PM   #139
Sillyoldman
#16876
Sillyoldman's Avatar
Love this thread.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 06-04-2009, 09:43 PM   #140
71'tahoe
71'tahoe's Avatar
Im loving it Mike!!
It reminds me of a 4 door karman gia...I say go with the daisy wheels...these days every body has 17" aluminum wheels..its still a sleeper..it has 4 doors..LOL..
Your skills are awsome! Keep up the good work.
71'tahoe is offline   Reply With Quote
Old 06-04-2009, 10:29 PM   #141
dammitmitchell
the pollock
dammitmitchell's Avatar
when i look at this thread i shake my head at myself..
seeing your welds and "it's only metal" attitude.....
grrr i need more pratice welding!.
hahaha
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-05-2009, 02:16 AM   #142
Frizzle Fry
Thanks guys I ALMOST got out there today but ended up spending another 3+ hours gathering stuff for the underwriter (it gets complicated with a recent divorce and child support involved). That's what I mean by mortgage broker scavenger hunt. They send you on one... I making it a priority to get out there tomorrow!!!
Old 06-06-2009, 02:03 AM   #143
Frizzle Fry
Well, I got one frame section removed and one S2000 section trimmed down and nearly fitting. I took pics, but the computer is tied up at the moment (I'm using my phone), so I'l post them tomorrow. It's not very pretty to look at right now. Kinda reminds me of the time I had a gaping hole in the side of my Burb : LOL:
Old 06-06-2009, 11:25 AM   #144
Frizzle Fry
Pics of carnage. The last two with the S2000 section sitting there are just that; sitting there. It will be moved outboard another couple inches.
Old 06-06-2009, 08:05 PM   #145
GRIMSS
GRIMSS's Avatar
You sure have a puzzle there. Looks like some good progress.
I need to do something like that to my VW "NOBACK", but I would like to put a flathead in the front.
Keep up the great work.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 06-07-2009, 02:06 PM   #146
Frizzle Fry
That NOBACK is cool man. I'm hoping one of my kids will get into veedubs so I'll have an excuse to play with them again.
Mine is a big puzzle right now, but it'll come together.
Old 06-09-2009, 08:37 AM   #147
Dave Reed
Dave Reed's Avatar
Arghhh! Between yours and LFD's Tahoe builds and now this I will never get any work done here at the office. I will need to hire someone to work so I can read more builds!
Dave Reed is offline   Reply With Quote
Old 06-10-2009, 03:04 AM   #148
Jvsapp
Jvsapp's Avatar
sweet FF looks like it's all coming together nicely. cant' wait for more progress pics
Old 06-11-2009, 08:58 PM   #149
original_balzer
original_balzer's Avatar
Even though I called it the clown car I do dig it. Especially now that its gunna have motivation and carving abilities.
I was curious about the shifter and what your doing there. The box part you cut off so you could shorten the shaft going back on somehow in the new forward location? or is this something you can fab up a suitable replacment?
As always your doing killer work.
I do have 1 tiny request though. Ditch that ugly black roof rack and find somting in chrome or stainless. Kinda like old VW roof racks. It would fit the car way better than that "euro trash" looking one. lol I guess the whole car is european though isnt it.
EDIT: dont worry bout the rack till after the swap LMAO
-61 c10 short step
-67 c10 short step
-71 k10 long fleet
-77 k20 long fleet (gettin all the goodies from frankentruck)
-79 c30/k30 3+3 frankentruck (cab and frame for sale)
-99 GMC yukon daily driver
original_balzer is offline   Reply With Quote
Old 06-11-2009, 09:51 PM   #150
Jvsapp
Jvsapp's Avatar
i like the roof racks. they add to the sleeper look. also they are a nice place to store the hood i am looking for roof racks for my nova too. that way i can strap 2 surfboards on the top of it and cruise the breaks here.
