04-02-2012, 11:11 AM | #1 |
Packrat
Re: My version of the s10 swap
I like the barrel support!
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
04-02-2012, 09:12 PM | #2 |
BlueJeep, frame looks great. It is great when you can get it blasted instead of all that wire wheeling. Paint looks great.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
04-02-2012, 09:50 PM | #3 |
Nice update.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
07-24-2012, 10:27 AM | #4 |
Packrat
how's the AC handling the weather?
07-29-2012, 09:43 PM | #5 |
It is probably undersized for the garage, but it does take the edge off in there and makes it comfortable enough to work in, even when it's 100+ outside. It never gets cold, but that's OK.
I've been sidetracked...again...a couple of times. My dad had his Chevelle down here for Goodguys around the 4th, and I decided to help him out and had him leave it so I could finish up the Vintage A/C install. I finished it and it's heading back to his garage for some other little tweaks. I also put new gauges and a new gauge panel, and used a Classic Enterprises SkyDrive GPS speedo sending unit. Pretty cool product. Now I'm back working on another side project, but hope to have that done and gone in a couple weeks so I can finally get back to the truck. Should be cooler though when I do get back at it.... Collecting more parts and tools though. Now I have some shiny new Martin hammers and dollies!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
08-25-2012, 06:28 PM | #6 |
Back to work on the truck. Not too much progress to report yet, but I'm hoping to. Pressed out the old bushings and ball joints from the control arms and bead blasted the lowers. Ordered MOOG bushings from Rockauto cheaper than the local parts store wanted for their house brand. Once those show up I'll paint the control arms and they'll be ready to go back on the frame. Trying to decide if I should put the stock coil springs back in or go dropped springs. Anyone know if 2" drop s10 coils will kill my nice ride?
08-25-2012, 11:33 PM | #7 |
A little bit more done on the bed. Welded up the front stake pockets from where I'd shortened the bed, I'll cut them back out in the new location in a little while. More practice with the TIG, and cutting 16ga is really slick with the Beverly shear.
I've also filled in the rear corners where the original sill went across. I'll have to get a new sill made, but want to get a little closer and have a better idea of what I want before I do that. Also spent some time DA-ing the bedsides, so I can get out the shrink disc next and figure out how to use it to smooth them out a bit.
09-03-2012, 01:19 AM | #8 |
It's been a very good weekend so far. It started off with a delivery:
First order of business was to figure out how to get it out of the truck. Dad forked it in there on a pallet with a Bobcat, since I don't have one of those I had to use my cherry picker. Not wanting to hurt anything, I decided that I needed to make some brackets to lift with. I was able to find some scrap 3/8 plate in my steel rack and started drilling. Dad said I took significantly longer to get the engine out of the truck than it took to get it in there, go figure. :-) But we got 'er out! I really like wiring, so I'm looking forward to modifying the harness to work.
09-03-2012, 10:16 AM | #9 |
Everything looking good, those two young helpers look like that can get the job done...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-03-2012, 12:02 PM | #10 |
Thanks! Yes, they're getting to the age where they know where to find my tools. I saw a light last week after dark in the back yard next to the hole they've been digging. Upon further investigation it was my cordless trouble light....
09-03-2012, 10:46 AM | #11 |
BlueJeep, I don't know what your going to do for exhaust but I tried to put Camaro manifolds on my S10 and they didn't fit. I had to but a set of headers from Patriot-they really fit nice on my truck. Your helpers make me smile,I wish I had some help somedays.
Lookin good I like watching your build. |
09-03-2012, 12:00 PM | #12 | |
I was hoping to use Camaro manifolds. Did you have them in an s10-bodied truck and where was the interference? My motor will be slid back 7" or so from where it would have sat in an s10 bodied truck, with the way the frame splays out and down it should help with clearance, but I'm not far enough yet to know. I'll keep those headers in mind. I bought a set of F-body manifolds off craigslist a couple years ago but for the life of me I can't figure out what I did with them....
09-03-2012, 02:08 PM | #13 |
Yes I'm putting a 5.3 in my S10,the manifolds wouldn't clear my Aarm on passenger side and looked like the steering shaft was going to be awfull. If you can't find yours let me know I'll loan you mine to mockup. I had firewall interfence but I'm sur that won't be a problem for you,the frame need to be notched also .
I also heard the trailblazer manifolds would be a better fit but I don't have any experience in them. |
09-03-2012, 03:56 PM | #14 |
BlueJeep, It is great seeing that you get the little helpers in the garage too. And is great seeing the 3 generations also. I will find out where my buddy got the headers on the truck that I am working on. If I remember right they were for a S10 with a LS motor or that type. I will let you know. If you need pictures or measurements let me know. Keep up the great work.
Shannon
09-03-2012, 10:04 PM | #15 | |
09-03-2012, 10:19 PM | #16 |
Here's how mine sits right now,I can take better pictures tommorrow. My Truck oil pan hangs down about 1.5 inchs below crossmember. I don't know if it's going to be a problem yet as I have dropped spindles.
09-04-2012, 10:12 PM | #17 |
BlueJeep, My buddy bought the stuff from S10V8.com. He bought the headers, motor mounts and the oil pan from them. I could not get a good side picture of the pan but I can this weekend. As you can see from the front it does not set lower than the front cross member. He made his own frame pieces that the mounts set on. The headers have great clearance and should be not problem hooking up the steering. Hope the pictures help and if you need any others let me know.
Shannon
09-05-2012, 09:00 PM | #18 |
Thanks for the pics! Yes, if you could get a side picture of the pan that would be great!
09-06-2012, 06:16 PM | #19 |
BlueJeep, I will tomorrow. I will take a wheel off to get some pictures.
Shannon
09-09-2012, 10:22 PM | #20 |
Today I spent some more time cleaning and painting parts for the motor. The goal is not super fancy, but clean and respectable. I've given my dad lots of crap over the past 5 years about all the money he spent on billet this and that on the motor of his Chevelle, so this is my chance to show him my way.
Before: And after... really all I did was de-grease it, then hit the casting seams with a file really quick to knock off the sharp edges, and then clean it up in the blast cabinet. Now it's painted like the rest of the motor. So since I needed something to do in between coats of primer and paint, I continued work on my control arms. The sway bar holes had seen a lack of maintenance, so I TIG'ed them up and drilled them back out. I also pressed in my ball joints and bushings. I filled the void around the lower ball joints with silicone to prevent dirt from filling them up. This is something I've done on my builds for years, and keeps it from ever looking like it did when I took it apart! And the end of the night with my helper. He was telling me to "move this" and "move that" so he could get in and sweep, so of course I did what he wanted! His brother decided he'd rather watch TV tonight.
09-13-2012, 10:25 PM | #21 |
No,I'm using the stock pan from GM. It hangs down about 1 1/2 inchs below crossmember. I won't know untill I get my sheetmetal back on to see with my dropped spindles if I'm in trouble. If it is too low I'll buy the H3 pan as it's shorter. I already notched my crossmember for the original so I know I'll have clearence.
09-13-2012, 10:34 PM | #22 | |
I'm thinking you'll be fine on clearance. Here's a picture of the 49 on the s10 frame with stock springs, 2" drop spindles, stock s10 wheels and 235/75R15 tires on it. Plenty of clearance. FYI I just also looked up the s10v8.com pan that Shannon posted pictures of, and that's the H3 pan that comes with their kit so now we know what that looks like in an s10 frame as well.
09-14-2012, 03:45 PM | #23 |
BlueJeep,I found a place that has the H3 oil pan kit on sale right now for $141.15 + shipping. I can't wait to see if my truck is going to clear the truck pan. There is a set of Stainless Steel Ls1 Headers o E-bay for $199.00 at the moment too.
09-16-2012, 11:29 PM | #24 |
Not much progress to report this weekend. Ordered the H3 oil pan, some misc. gaskets, a tranny filter, and some relays and other wiring stuff. Picked up a spare wiring harness and ECM tonight off craigslist, this is the one I'll start playing with and cutting up.
Also got the remaining bushings pressed into my lower control arms and started to paint them chassis black. Painted and re-installed the water pump. Cleaned the intake with my toothbrush, the plastic cleans up very nicely as compared to the aluminum parts.
09-16-2012, 11:30 PM | #25 |
I found that too, but by the time you add the shipping it's the same price as JEGS so I ordered it there. It will ship out tomorrow!
