Old 11-06-2010, 10:44 PM   #126
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 1958 Apache 38 Dually Dump Project
Are you still planning on getting a D60 for the front?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-07-2010, 12:27 AM   #127
RockTonka
RockTonka's Avatar
Already got it. Picked up a dually D60 about a month and a half ago, got it tore down and am still in the process of cleaning and rebuilding it.
It's pretty rough but certainly salvageable, gonna need calipers, seals, and inner axles on both sides (inner seals wore pretty deep grooves), but the R&P and bearings look good.
Thought we'd need new rotors, but they cleaned up at 1.35".
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 11-07-2010, 12:34 AM   #128
RockTonka
RockTonka's Avatar
Originally Posted by JohnC View Post
That should be a real nice setup for the truck.
We think so...it can't come quick enough though.
As much as we enjoy putting along with the original, now smoky, 235 (gallon of oil to every tank of gas)...it was wheezing pretty hard with this relatively light load!
My build thread
Old 11-07-2010, 01:01 AM   #129
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Sweet!
Tony
Old 11-16-2010, 12:08 AM   #130
RockTonka
RockTonka's Avatar
Started cleaning, painting, and gathering parts for, the front D60.
My build thread
Old 11-16-2010, 12:36 AM   #131
vk_chevy
vk_chevy's Avatar
that is a fine looking pile of parts you got there
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 11-16-2010, 02:14 AM   #132
jbclassix
Junk Yartist
jbclassix's Avatar
very nice
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 11-16-2010, 05:56 PM   #133
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice! This will be a killer rig! Now, I have a couple questions for you.
Did you build the diff covers?
What kind of paint did you use on the front axle? I've been using Krylon lately, and for the money it sucks. I switched over to VHT and it seems to be a better product for spray bomb.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-16-2010, 09:57 PM   #134
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Looks great! Id also like to know what kind of paint you used. Ive had good luck with rustoleum gloss black out of the can(gallon).
Tony
Old 11-17-2010, 12:42 AM   #135
RockTonka
RockTonka's Avatar
Thanks, it's starting to come together. I almost don't want to take it down for the conversion...been enjoying it quite a bit using it like it is, but it's about that time. We're really hoping that we can get it in and out this winter and be running again by early spring.
I've had good luck with Rustoleum gloss black enamel (rattle can) and tend to use that most of the time.
Diff covers and spring plates were sourced from RuffStuff...lots of good parts there.
http://www.ruffstuffspecialties.com/catalog/index.php
My build thread
Old 11-17-2010, 08:53 PM   #136
BlueJeep
BlueJeep's Avatar
Are you going to rebuild the kingpins? I don't think I've ever had one apart that didn't have rusty bearings.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 11-19-2010, 03:05 PM   #137
LONGSWHEEL
Your build is looking awesome. I have a 70 ford with a flat bed that i am fixing to start working on. I love the loke of the flat bed trucks.
LONGSWHEEL is offline   Reply With Quote
Old 11-28-2010, 01:46 AM   #138
RockTonka
RockTonka's Avatar
King pins feel smooth and tight, I'm kinda waiting to see if I'm going to go high steer on pass side with a 2wd box and cross over, or keep something close to the stock configuration. I'm leaning toward crossover and will check them out then.
My build thread
Old 11-28-2010, 01:52 AM   #139
RockTonka
RockTonka's Avatar
Got a alt. mount built in between t-day duties...
My build thread
Old 11-29-2010, 10:10 AM   #140
JohnC
JohnC's Avatar
Wow that bracket looks awesome!
JohnC is offline   Reply With Quote
Old 11-30-2010, 01:19 AM   #141
Woodbutcher
Woodbutcher's Avatar
That's a killer alternator mount, Rock. One more idea discovered on the pages of this forum. It's guys like you who make the rest of our daily driver projects become become bigger and more involved than we originally intended.
If the women don't find you handsome, they should at least find you handy... Red Green
Keep your stick on the ice, Woodbutcher
Woodbutcher is offline   Reply With Quote
Old 11-30-2010, 12:40 PM   #142
Dieselwrencher
Very nice fab work once again!
Ryan
Old 12-04-2010, 11:59 PM   #143
RockTonka
RockTonka's Avatar
Thanks for the remarks, we really appreciate it!
Been working on the power steering set-up. Originally bought a saginaw pump/res, but couldn't fit it in tight to the block because of the short water pump. Chased down a type 2 pump/pulley/remote res from PSC...lots of room to put it where I wanted.
My build thread
Old 12-15-2010, 12:49 AM   #144
RockTonka
RockTonka's Avatar
We've been struggling with which seat we would use.
The original bench had a decent back, but rotted out bottom with missing springs/padding. We were looking at least $500 to get the parts we needed and have the stock bench reupholstered/rebuilt.
We got a set of pull out 2006 chevy truck buckets (with the seat belts in the back) to try...didn't like how they fit in the cab, I wanted more room. They were in perfect condition for $600 w/ center console (no way that was fitting)...so passed on those.
Looked at a mid 80's chevy bench, but wasn't really feeling it. Thought about the Astro van seats, but finding a take out seat in decent condition with a acceptable color wasn't likely...didn't want to reupholster a donor bench to get what I wanted.
So, took some measurements and talked to Twisted Stitch about a extended/expanded version of their Cruiser seat...a low side suspension seat that we liked in our Rhino. A couple weeks later, for about the same $ as reupholstering a bench of some sort, and we have this.
The back looks a bit tall, but we will see how it falls into place.
My build thread
Old 12-15-2010, 01:14 AM   #145
Kim57
Kim57's Avatar
Nice looking seat.
Kim
Kim57 is offline   Reply With Quote
Old 12-15-2010, 10:28 AM   #146
JohnC
JohnC's Avatar
Looks good man. Seats are sometimes a hard decision to make. There are so many factors to conisder, from color, style, size.
I think it will look good in the truck.
Old 12-15-2010, 12:30 PM   #147
abebummy26
abebummy26's Avatar
Is that a tweed insert in the center?
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 12-16-2010, 03:11 AM   #148
RockTonka
RockTonka's Avatar
yep, I hope so...if not, I'll have a really nice garage bench
My build thread
Old 12-16-2010, 03:17 AM   #149
RockTonka
RockTonka's Avatar
Yes...
My build thread
Old 12-16-2010, 04:28 PM   #150
Dieselwrencher
As usual, very nice!
Ryan
