Old 07-03-2011, 02:44 PM   #126
Pop's C-10
Pop's C-10's Avatar
Re: Nobaddaze's 82 C10 Cruiser Build
Originally Posted by Nobaddaze View Post
That is a good idea, however im trying to do a complete bolt on (no welding to frame) because i have already powdercoated my frame
Oh yea...that would pose a problem..lol...in that case that concept looks like it will work fine
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-06-2011, 02:27 PM   #127
bmfpeterson
bmfpeterson's Avatar
damn! your rear looks way cool! keep on it!
I like the idea of your cross-member, but it needs to be able to be installed if someone has the cab still on the truck, IMO. (cant drill the holes for the top of the frame rail with the cab on it) what if you measured the overall width inside of frame to inside of frame and then backed off about an inch. then you could finagle it in there with some gap and then use some kind of spacer on each side????? if that make sense???
if it is the same width as the frame rails im pretty sure you would end up beating it in and out?????
bmfpeterson is offline   Reply With Quote
Old 07-06-2011, 04:22 PM   #128
Nobaddaze
Nobaddaze's Avatar
Originally Posted by mooseknuckles View Post
looks good...but I would paint it all one colour! lol.
you dont like my color scheme im going for the "over the top" look
Hard work has a future payoff. Laziness pays off now.
My Build
Nobaddaze is offline   Reply With Quote
Old 07-06-2011, 04:31 PM   #129
Nobaddaze
Nobaddaze's Avatar
im still thinking of some other ways. ive seen a bunch of xmembers that are as wide as the inside on the framerails and people seem to love em.
I just want it to be super easy to remove, thats all...
i think its funny that im responding to you on here and texting you about tires at the same time lol
My Build
Old 07-08-2011, 01:01 PM   #130
bmfpeterson
^^^^^ thats funny!
Old 07-18-2011, 10:10 PM   #131
Nobaddaze
Nobaddaze's Avatar
Small Update Today....Got some parts back from my waterjet guy, Bent em up on the CNC press brake, Tacked em together, and Uh oh the parts dont fit
Measured wrong on the shape of the leafspring pad. Ok, simple fix. get out the grinder and make it work. Problem solved. Rear end in place and working.
Front: Fat fingered the bolt dole dimension and made it an inch too big, Thats just gonna get recut because its pretty much screwed.
But that aside it looks badass so far, got a little tweakin to do and some material to get but it will be 4-linkin in no time
My Build
Old 07-19-2011, 12:38 AM   #132
Nobaddaze
Nobaddaze's Avatar
couple more, loosly mounted Yup-Im Stoked!
My Build
Old 07-19-2011, 12:39 AM   #133
Nobaddaze
Nobaddaze's Avatar
If anyone wants a freshly powered set of leaf sprigs with new bushings just installed...Hit me up!
My Build
Old 07-19-2011, 12:56 AM   #134
luifer76
luifer76's Avatar
Very nice set up you got there bro....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 07-19-2011, 12:58 AM   #135
luifer76
luifer76's Avatar
are you going with a bigger notch on the rear? if so how big?....
Old 07-19-2011, 01:07 AM   #136
Nobaddaze
Nobaddaze's Avatar
yea, new notch is 8.5" total notch.
My Build
Old 07-19-2011, 01:10 AM   #137
Nobaddaze
Nobaddaze's Avatar
My Build
Old 07-19-2011, 02:51 PM   #138
Pro Performance
Pro Performance's Avatar
Looking good. How come not just weld the axle bracket right to the axle, and get rid of the u-bolts and spring plate?
Pro Performance is offline   Reply With Quote
Old 07-19-2011, 03:58 PM   #139
Nobaddaze
Nobaddaze's Avatar
I just wanted to do total bolt on incase I change my mind later.
My Build
Old 07-19-2011, 05:27 PM   #140
mcboomport
mcboomport's Avatar
Looking good man! I'm psyched on you designing your own bolt in kit.
mcboomport is offline   Reply With Quote
Old 07-19-2011, 06:10 PM   #141
mooseknuckles
mooseknuckles's Avatar
nobody changes their mind!....lol.
mooseknuckles is offline   Reply With Quote
Old 07-19-2011, 07:02 PM   #142
Nobaddaze
Nobaddaze's Avatar
LOL! When I bought the truck I was just gonna throw some rims on it and static drop it, maybe drive to work every once and a while.
Now Im into a Frame off Build, and when im done im sure its not gonna be low enough or not have enough power and im gonna start over again
My Build
Old 07-19-2011, 08:50 PM   #143
bbbc10
Diggin The SquareLife
damn bro! lookin nice!! u ever think bout makin some extras to sell?? im lookin into buyin some if u do!!
bbbc10 is offline   Reply With Quote
Old 07-19-2011, 09:43 PM   #144
Nobaddaze
Nobaddaze's Avatar
Thats kinda the idea, but I wanna road test it first. I thought your truck is already setup?
My Build
Old 07-19-2011, 09:58 PM   #145
Nobaddaze
Nobaddaze's Avatar
ok guys,
I need your thoughts...Panhard vs. Watts?
Panhard bar:
Simple, cheap, easy to install, minimal parts, side to side movement throughout travel
Watts Link:
Strong, minimal side to side movement, "cool factor"
More moving parts, More expense
any thoughts?
My Build
Old 07-19-2011, 11:29 PM   #146
bbbc10
no its not setup...i been searching an checkin stuff out first....
Old 07-19-2011, 11:30 PM   #147
bbbc10
ur makin everything else...jus make watts setup!!!
Old 07-20-2011, 12:34 AM   #148
Nobaddaze
Nobaddaze's Avatar
Trial Run
My Build
Old 07-20-2011, 02:31 AM   #149
bbbc10
see nice!!!! jus make 2 of everything!! lol are u gona make the the middle bar curve?
Old 07-20-2011, 02:47 AM   #150
bbbc10
like this?
