Old 02-03-2014, 12:33 AM   #126
lynnfield
The Waco Kid
lynnfield's Avatar
Re: First Steps LS Swap......
The last thing was underneath, the bracket at the transmission needed to be raised so the cable would clear the crossmember. There was a little trimming to the bracket to get it to clear the lip of the pan. I was able to get it hooked up and it worked without moving any of it, but there was a kink almost right at the bracket and the cable was rubbing the crossmember pretty hard. Greg
lynnfield is offline   Reply With Quote
Old 02-03-2014, 04:38 PM   #127
faribran
Greg. this is some good info... thank you... i may have some questions about the fuel lines you put together.......... Rich
faribran is offline   Reply With Quote
Old 02-03-2014, 06:24 PM   #128
lynnfield
The Waco Kid
lynnfield's Avatar
Sure, NP. Greg
Old 02-03-2014, 06:28 PM   #129
lynnfield
The Waco Kid
lynnfield's Avatar
Swapped the fittings and hooked up the power steering lines. The check valve came from the donor truck, it has the larger port connection for the hose and fits into the old brake booster. Greg
Old 02-03-2014, 06:29 PM   #130
lynnfield
The Waco Kid
lynnfield's Avatar
Off to the exhaust shop!!
Old 02-03-2014, 10:56 PM   #131
nuke1
nuke1's Avatar
Nice work so far!! Can't wait to see more
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-05-2014, 07:00 PM   #132
aggie91
I'm just glad to be here!
aggie91's Avatar
Gret Ideas using the many extra parts from the donor truck. I like the shift cable idea...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-08-2014, 03:14 PM   #133
blazer crazy
Justin wants to know what's taking so long....
blazer crazy is offline   Reply With Quote
Old 03-12-2014, 02:58 AM   #134
Motoxrrar
Originally Posted by lynnfield View Post
rawraw67, probably not til the end of summer, unless someone is looking for something specific.
dkauffman05, I never mentioned using a SD7 compressor?? I only stated I really didn't want to cut the frame. Probably be a while before I get to that tho.
I have a 4.8 ly2 and it fits just fine. No cutting.
Motoxrrar is offline   Reply With Quote
Old 09-07-2014, 01:14 PM   #135
lynnfield
The Waco Kid
lynnfield's Avatar
Ok, the truck is back from the body shop after about 4 months. It took a while but I finally have it back, now its time to get this on the road.
Old 09-07-2014, 01:24 PM   #136
lynnfield
The Waco Kid
lynnfield's Avatar
Here's what I've been working on as of late. Moving the battery to the drivers side, and the ECM mount. I was able to locate an original aux battery mount, and modify that using the 06' battery tray. The side brackets are pretty stout and the bottom is usually what rusts out anyway, so now it all bolts together and the bottom can be replaced when needed.
Old 09-07-2014, 01:30 PM   #137
lynnfield
The Waco Kid
lynnfield's Avatar
Battery box installed, working on ECM mount
Old 09-07-2014, 01:34 PM   #138
lynnfield
The Waco Kid
lynnfield's Avatar
Trimming down the ECM mount……….
Old 09-07-2014, 01:38 PM   #139
lynnfield
The Waco Kid
lynnfield's Avatar
I started with a cardboard template, once that was right, I made the bracket out of aluminum, the bend is right at 75*. The inner fender had to be worked a small amount to provide a flat mounting surface.
Old 09-07-2014, 07:35 PM   #140
lynnfield
The Waco Kid
lynnfield's Avatar
I had a local shop fabricate this cover (based on the one for my blazer) for the inside of the bed. It's about an inch wider and the top tab is folded in and welded.
Old 09-07-2014, 07:43 PM   #141
lynnfield
The Waco Kid
lynnfield's Avatar
Craigslist score! I found these fans for $200 and they fit my radiator like they were made for it. If you look at the measurements on summit's web site, it looks to me like all the dual fan setups from flex-a-lite are the same as their universal set, they just use different brackets for specific vehicles. I had the bottom bracket fabricated, and I'll work on the top one later. Not sure if I will do it the same, or bring it all the way across the top of the core support.
Old 09-07-2014, 07:49 PM   #142
ls1nova71
ls1nova71's Avatar
Those fans do look like they fit nice! You got lucky on that one. Any pics of the rest of the truck? What color is that?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-07-2014, 08:12 PM   #143
lynnfield
The Waco Kid
lynnfield's Avatar
Couple more of the fit of the fans on radiator.
LS1Nova, paint color is the original olive green, the new paint was blended in with the old as best they could. They just did the body work on the fuel fillers and painted the back door jam and the bed side. The tail gate was also painted (it was powder blue and white). I'll paint the whole truck later down the road, right now just trying to make it a driver. I'll probably be needing one of your cruise levers eventually. Thanks, Greg
Old 09-08-2014, 12:19 AM   #144
littlevictories
lookin good. my kinda build. clean, sturdy but not over the top gaudy.
littlevictories is offline   Reply With Quote
Old 10-04-2014, 07:28 PM   #145
lynnfield
The Waco Kid
lynnfield's Avatar
Updates, the local tube and hose place welded these fittings on and made my hoses for me, the fuel system is almost completely done.
Old 10-04-2014, 07:35 PM   #146
lynnfield
The Waco Kid
lynnfield's Avatar
The tac module is mounted, along with the wire harness for the pedal. I opened the original speedo cable hole and used the grommet that was on the harness from the 06' truck. Also, the left hole on the tac module was opened up to fit the top hole on the booster bracket, right side had some trimming to fit round the grommet, and a spacer to take up the gap to the fire wall. Greg
Old 10-04-2014, 07:40 PM   #147
lynnfield
The Waco Kid
lynnfield's Avatar
I've decided to run the wires inside the top channel of the core support, instead of in the wire holder behind it. Pretty easy, just have to trim the tops of the ribs, and none of it is seen afterward, including the wires.
Old 10-04-2014, 07:44 PM   #148
lynnfield
The Waco Kid
lynnfield's Avatar
Starting on the bracket for the electrical box, fuse holder, relays, etc…….
Old 10-04-2014, 07:49 PM   #149
lynnfield
The Waco Kid
lynnfield's Avatar
First pic in the last post was how I connected the main power wire for the dash, lights, etc. The wires for the fuse block will be run thru the bracket and under the inner fender. Last couple pics here gives an idea what it will look like when it's all done. Greg
Old 10-06-2014, 10:29 AM   #150
Low Elco
Lots of nice sano work here! Good Stuff!
Low Elco is offline   Reply With Quote
