Old 03-10-2016, 03:31 PM   #126
donandal
Re: Plus Five
installed the skid plate,
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 03-11-2016, 02:55 PM   #127
donandal
Re: Plus Five
I read in my instructions that they included bolts that go into
the transmission housing to hold heat shields.
The heat shields protect the transmission pan area from heat
coming off the cat. converters.
My kit didn't come with any heat shields, so I browsed the web
then made up some of my own.
.060 aluminum shields and stainless steel brackets riveted together
with solid round head aluminum rivets.
53 Chevy Pickup
Old 03-12-2016, 10:42 PM   #128
Advanced Design
Advanced Design's Avatar
Re: Plus Five
Inspiring work donandal. Many good ideas well executed including the skid plate. How did you do the dimples? Guessing made a press die like you did with the stake pocket extensions?
Advanced Design is offline   Reply With Quote
Old 03-13-2016, 12:36 PM   #129
donandal
Re: Plus Five
Thanks,
Yeah, I made a simple dimple die for that skid plate.
I just drill a 1/4 inch hole where you need it, the press it in.
I pressed them in on a cheap harbor freight H-frame press.
53 Chevy Pickup
Old 03-18-2016, 03:19 PM   #130
donandal
Re: Plus Five
I am going to finish up the fuel and emissions lines next,
then on to the brakes. I bent up some 3/8 inch poly armor
for the fuel line. I'll have braided fuel hose for each end.
I made up the clamps from 1/2 x 1 inch aluminum bar stock.
The hard line bends pretty easy and flares easy too. I'll
paint it black before final installation.
53 Chevy Pickup
Old 04-06-2016, 03:29 PM   #131
donandal
Re: Plus Five
So I am back at it.
I made a distribution block for the Tee on the rear axle. I know you can buy those brass Tee fittings, but I've never been happy with the depth of threads that the have. Hopefully these steel AN fittings will be more secure.
This is 6061 aluminum with 1/8 pipe tape to AN-3 and AN-4 fittings. The AN-4 is the feed line from the front and uses 1/4 inch steel tubing and the two side fittings are AN-3 and 3/16 tube.
The block also supports the parking brake cable. I need to finish the front hard lines and then order the flex lines.
53 Chevy Pickup
Old 04-06-2016, 03:38 PM   #132
donandal
Re: Plus Five
I also finished mounting the parking brake cables.
I made a center console frame that holds the parking brake handle and a bell crank setup that drops thru the floor. I threaded a stainless steel rod that connects to this pivot yoke that pulls both parking brake cables.
I'll post up the bell crank setup as the interior goes back in.
53 Chevy Pickup
Old 04-15-2016, 07:20 PM   #133
donandal
Re: Plus Five
I finished the brackets for the front brakes and installed the flex lines.
I used two holes in the original frame and put rivnuts in there to hold
the brackets. They are made from stainless steel 1/8th thick.
Next I need to mount the inner fenders and brake pedal, booster and
master cylinder so I can make up the last brake lines.
53 Chevy Pickup
Old 04-16-2016, 05:28 PM   #134
donandal
Re: Plus Five
I made a custom console that mounts below the dash that will hold the A/C duct work and some switches. Because that console runs full width, it interfered with the lever that opens the cowl vent.
I took an old power window motor and mechanism and powered the cowl vent.
I'll post pictures of the console later, but for now here's the cowl mechanism.
53 Chevy Pickup
Old 04-16-2016, 07:37 PM   #135
tiddlar
Re: Plus Five
o man o man,.... you took my idea and brought it to life.. I want to do the same with mine except make a duct connected to firewall,. press the button the cowl opens and instead of sending that air into the cab send it to the engine bay.. very awesome build!
Purgatorio
tiddlar is offline   Reply With Quote
Old 04-16-2016, 07:56 PM   #136
solidaxel
solidaxel's Avatar
Re: Plus Five
WOW you have nothing on Rocky Hinge Co for there cowl vent motors!!
Hot rodding at its best!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-16-2016, 08:27 PM   #137
Advanced Design
Re: Plus Five
Nice details! That is a very creative solution for cowl vent power. Great execution.
Old 04-16-2016, 09:18 PM   #138
Coach529
Coach529's Avatar
Re: Plus Five
Wow.....great stuff
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 04-16-2016, 09:25 PM   #139
donandal
Re: Plus Five
Thanks everyone,
This setup took a little thinking but it works nice, the motor is easy to
replace, and it is fairly narrow.
Just this side of the cowl motor setup you can see some tabs that I added
to hold the wiper mechanism. It is a custom setup also, with a more modern
GM motor and custom linkage with late model wiper arms. I'll post that up
soon.
In the thru the dash photo, on the right is a tab welded to the tube
that runs to the firewall. That tube bracket also holds the left side of
the vintage air setup and the right side of the wiper setup. The tube has
a bend in the middle and is just thin wall conduit to help it collapse in a
wreck....heaven forbid!
All of this is just narrow enough to still have a radio in the normal spot.
53 Chevy Pickup
Old 04-18-2016, 11:27 AM   #140
RockinKees
RockinKees's Avatar
Re: Plus Five
Very nice touch!!
You get creative to overcome some problems
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 04-19-2016, 01:46 PM   #141
donandal
Re: Plus Five
OK,
working from the inside of the firewall, I want to get all of the wiper and washer parts into place.
The washer nozzles I made from stainless steel. They have a threaded base with a small o-ring to seal to the cowl. I tested the spray pattern in the sink.
53 Chevy Pickup
Old 04-19-2016, 02:05 PM   #142
donandal
Re: Plus Five
I also mounted the wiper system. I made a new transmission for the wiper rods and used new style ends that have the plastic socket and steel ball fittings.
I made some trial dimensions on paper then made new arms for the pivots. The original spline shaft seemed kind of flimsy so I got donor arms from a ford escort and used the splined shaft. I turned down the shaft to fit thru the original wiper barrels and made new bronze bushings. With a little high school math, I was able to come up with a dimension for the bellcrank on the motor that gives just the right amount of sweep.
I bought two wiper arms and modified the ends by heating and bending them. They cover the entire sweep of the window now and the 12 inch blades reach nearly top to bottom as well.
The motor is a newer chevy type that has high, low and intermittent. The whole setup just clears the cowl motor and the defrost vents and leaves room for the radio.
53 Chevy Pickup
Old 04-19-2016, 02:10 PM   #143
donandal
Re: Plus Five
some more pictures...
53 Chevy Pickup
Old 04-19-2016, 02:18 PM   #144
donandal
Re: Plus Five
all finished..
53 Chevy Pickup
Old 04-19-2016, 02:23 PM   #145
donandal
Re: Plus Five
also installed the cowl drain line, which also drains the A/C condensation.
53 Chevy Pickup
Old 04-19-2016, 05:12 PM   #146
II_Slow
II_Slow's Avatar
Re: Plus Five
It was a lot easier to read those numbers off of the VISA card to the guy at RainGear!
Good job re-engineering that suff to work on your truck.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 04-19-2016, 05:34 PM   #147
donandal
Re: Plus Five
Thanks,
It was a lot of work, but this type I enjoy.
I looked at that RainGear setup, but $500 is a lot of money. They also
say it won't work with a stock GM type column switch and it might hit on the
defroster duct on one side. Plus I didn't know if it would clear my cowl
vent motor setup, and they say it won't clear a stock radio.
I got the motor for $20 and the arms for $30 so pretty cheap.
Just too much money for something that might not work for me.
I do agree though, my visa card would have been a lot easier.
53 Chevy Pickup
Old 04-19-2016, 09:09 PM   #148
Advanced Design
Re: Plus Five
I'll also soon be getting into some areas outside my comfort level, so will be
asking for some help.
Respectfully, I don't think this is going to happen. ...from your first post in this thread.
Impressive engineering and execution! The drain idea is a good one too.
Old 04-20-2016, 05:43 PM   #149
donandal
Re: Plus Five
Thanks,
I'm not done yet...
The electric, brakes/hydro-boost/power steering,air conditioning and transmission stuff is all new to me, so we'll see.
53 Chevy Pickup
Old 04-20-2016, 05:50 PM   #150
donandal
Re: Plus Five
Today I installed the steering column, brake booster and master cylinder.
53 Chevy Pickup
