Old 07-01-2013, 07:47 PM   #1701
6lcummins
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by woodwright View Post
You're not gonna put a stack on it are you?
Don't have a choice.
Originally Posted by brimc View Post
I thought so . I have always had trouble miggin pipe. Once I learned tig it is much better. Problem is I don't have a tig at home.
That pipe work looks awesome!
Lower heat and slowed down the wire speed and take our time.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 07-01-2013, 08:53 PM   #1702
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Thanks guys. Yep, for now it's getting a stack until I can come up with a good way to get at least 4" exhaust through the back. A stack is the least bit of work right now. Plus I like stacks. I didn't want one on this truck, but I really want to be able to dump my rear suspension for hooking up to trailers. That's a nice feature. My only other option was to dump the exhaust in front of the rear axle, and I felt that looked dumb and it will have my rear axle black...................
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-01-2013, 11:26 PM   #1703
Dewey72
Holy smokes the four link bars look great. Looking good man!. Did I miss any pics of the clutch master cylinder. Trying to figure out how to do mine.
Dewey72 is offline   Reply With Quote
Old 07-01-2013, 11:46 PM   #1704
woodwright
Enjoying left field
woodwright's Avatar
I forgot about all the stuff you've got to get around in the back. I'm gonna run 4" back to the front of the rear axle, and then split to duel 3" out the back. I don't care for the huge coffee can tips that some guys have. And I want people to be really confused when they see my truck roll by.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 07-02-2013, 03:29 PM   #1705
Dieselwrencher
Thanks! You can see it in the RH corner of this pic below. There was one hole in the fire wall from the factory, and I still need to add one and finish mounting it.
Yeah, I think a 5" tip on a 4" system, and a 6" tip on a 5" system looks good. Anything bigger and it looks dumb. On stacks, it definitely has to fit the truck.
Here is a pic of the suspension aired up.
Aired out
I wanted to put the tail pipe over the pan hard bar on the RH side. This was a good idea until I aired it out. Not going to work. So then I thought about putting it over the LH side of the pan hard bar and t it to duals. My issue with that is that I think all the 90's and 45's will restrict flow. It'll have to wait for now.
Ryan
Old 07-02-2013, 10:58 PM   #1706
gerfunken
gerfunken's Avatar
Any chance of running it down the outside of the frame, and over the top of the air bag on the right hand side?
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 07-02-2013, 11:22 PM   #1707
doubleb's69
doubleb's69's Avatar
Looking good fellas.
Bud
doubleb's69 is offline   Reply With Quote
Old 07-03-2013, 12:03 AM   #1708
ryanroo
ryanroo's Avatar
if you give me time, i will find out. i am going to try to avoid a stack, so i am going to try that route. i think i can get it weaseled through the wheel well in a way that wont hurt my feelings. if not, 4" stack.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 07-03-2013, 02:36 AM   #1709
watahyahknow
watahyahknow's Avatar
maibe double the pipe up and make it 2 x 2,5 "
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-03-2013, 12:17 PM   #1710
Str8-6-68
Str8-6-68's Avatar
Right on Ryan, This build is really looking good now and its come a long way. Sweetest cummins conversion on this site!
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 07-03-2013, 12:22 PM   #1711
Ackattack
Ackattack's Avatar
I was thinking the same thing. Or run it on the outside of the frame and dump it in front of the right, rear tire if you don't want to go over the bag bracket.
Ackattack is offline   Reply With Quote
Old 07-03-2013, 02:45 PM   #1712
Dieselwrencher
My problem in doing this is my primary turbo is so low that getting over the frame is nearly impossible due to the cab floor board. When I put the turbos on, I had no intentions of going with this air ride set up. Whoops, another change in plans.
Thanks! See ya soon.
I'm sure you can get it through there with where you put your primary.
Rectangle tubing doesn't flow nearly the same as round.
Thanks, how's yours coming?
I don't want it dumping in front of the rear anything. Everything will be black if I drive it like I stole it. Which may make me feel better for it being such a PITA going back together.
Ryan
Old 07-03-2013, 05:33 PM   #1713
watahyahknow
sorry meant two round pipes of 2.5 "
i seen y pipes for sale that go from 4 to 2 x 2.5 inch , you could run those down both sides of the frame with a lot more clearance
Old 07-06-2013, 11:26 PM   #1714
mknittle
mknittle's Avatar
Ryan, remember that indecision is the key to flexibility! At least that's my story.
Truck is lookin good!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-09-2013, 03:07 PM   #1715
Mattman2010
Mattman2010's Avatar
Here are some pictures of the longhorn that I took when I was up there hanging out with Ryan. I have more but I will have to resize them.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 07-09-2013, 05:32 PM   #1716
watahyahknow
it has the look of one of those sledpullers
all it needs are some tractorweights in front
Old 07-09-2013, 07:07 PM   #1717
Dieselwrencher
Well, it's been a long few weeks. We did manage to get the truck down to Good Guys for 2 days so people could perform double takes. I had a few people join me in the thrash fest to get it ready. Thanks to my Dad, brothers nick and Scott, and to Mattman2010. They all helped do something so the truck would get put back together fast. It is really nice to jump in this thing after all this time and drive it under it's own power. There is still a lot left to be done to drive it, and IDK when it all will get done. We shall see. Here are some pics and I will add more as I resize them.
Ryan
Old 07-09-2013, 09:06 PM   #1718
gerfunken
gerfunken's Avatar
Ryan, the truck is absolutely beautiful. I hope that mine will turn out near what yours is. (Probably not, but here's to big dreaming...)
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 07-09-2013, 09:47 PM   #1719
ryanroo
ryanroo's Avatar
Looks GREAT!
where on earth did you get that BA suspension? hahaha
72 K20 12v build
Old 07-09-2013, 10:19 PM   #1720
6lcummins
Looks GREAT!
Only took a few MONTHS after it was ordered... Just waiting on the front now....
"STOCK"
ASSEMBLY THREAD
Old 07-09-2013, 10:23 PM   #1721
Mustard72
Mustard72's Avatar
Now that's a truck!!!
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 07-09-2013, 10:45 PM   #1722
6lcummins
Sorry for the blurriness on the left side, my galaxy died so I had to use my old G2.
"STOCK"
ASSEMBLY THREAD
Old 07-09-2013, 11:48 PM   #1723
ryanroo
ryanroo's Avatar
fabricators are a notoriously unreliable lot...
but i am guessing you meant a few months after you got it to install it? RIGHT??
72 K20 12v build
Old 07-10-2013, 12:45 AM   #1724
Mattman2010
That rear suspension rides pretty good. Will ride a lot better when the front is bagged. It looked sweet in person!
Build Thread
Build Thread
Thread
Old 07-10-2013, 11:52 AM   #1725
Dova
Dova's Avatar
That looks awesome congrats!
Dova is offline   Reply With Quote
