Old 11-17-2009, 08:18 PM   #151
CAL 58 GMC
CAL 58 GMC's Avatar
Re: My 57 Pro Street
Originally Posted by OrrieG View Post
I posted about that in my build thread. I could not figure out how every 55-59 I saw with the fenders off was beat in that area. My fenders had never been off and one side was hammered a little the other quite a bit. I read somewhere that the inside stamping was drawn and tooled wrong, someone had not taken into consideration interference with the fender brace (or it may have been beefed up during design). Rather than retool they just issued the fender install guys on the line a 2# adjustment tool. So if yours is beat, don't work to hard making it pretty because you will probably just get to pound down your new paint again. Look close at my cab photos and you will see the dents still there on mine.
Now that you mention it mine had those same dents, I just thought it must have be from an accident at some point in it's life. Sorry Kim for jumping in on your thread!
CAL 58 GMC is offline   Reply With Quote
Old 11-21-2009, 12:09 AM   #152
Kim57
Kim57's Avatar
It's OK. The info is welcome.
Kim
Kim57 is offline   Reply With Quote
Old 11-22-2009, 01:35 PM   #153
chevyrestoguy
chevyrestoguy's Avatar
Kim-
I'm going throught the same thing right now with aligning my doors. I thought my situation was unique. I had considered cutting my cage nuts loose on my upperhinges and relocating them more outboard so the top of the door could move outward and get the door's front edge and cowl more aligned. But, that would cause issues on everything forward of that gap. The fenders and the hood wouldn't line up, and you'd wind up having to add metal at all of your gaps in order to close them up. I'm an probably going to align the doors as best as possible, and then do bodywork to make everything look right. I did a shop tour at Boyd's years ago when he was in the old shop, and they were working on Cadzilla for Billy Gibbons of ZZ Top. They got the doors as best they could by aligning and then closing up the gaps with sheet metal and welding rods, then they did a 36" sweep of filler from top to bottom at all of the door gaps and blocked the area until the gaps were consistent and the panel intersections were flat and even. I'm a stickler about panel gaps, and that amount of work that they did gave me a real appreciation of what it takes to make it look right.
chevyrestoguy is offline   Reply With Quote
Old 11-22-2009, 09:17 PM   #154
Kim57
Kim57's Avatar
Originally Posted by chevyrestoguy View Post
Kim-
I was talking to a body guy that took over one of the buildings that Boyd was in after he died (he's doing my brothers truck). He told me that these old vehicles are like that. Some things fit nice and some are way off. My passenger side is way better than the driver side. I took some measurements this weekend and it looks like the cowl was installed almost a 1/4" low on the driver side. I'm thinking about cutting it where it is supposed to line up with the fender and raising it. It's either that or lots of body filler in that area which is what was there when I bought it. The driver door is also wider at the top than the passenger opening. I guess the guy on that side was having a bad day.
Kim
Old 11-24-2009, 03:10 PM   #155
Fat Mike
Fat Mike's Avatar
Can you show a picture of the graft of your subframe up close and the rear part of your cab. It looks like you shaved it. My rear cab is alittle beat up and I like the idea.
Fat Mike is offline   Reply With Quote
Old 11-25-2009, 01:41 AM   #156
Kim57
Kim57's Avatar
Hope these help. If you need any more just ask.
I used 16 gauge on the back of the cab.
Kim
Old 11-25-2009, 06:26 PM   #157
OrrieG
OrrieG's Avatar
Kim
Monday morning assembly vehicle...
OrrieG is offline   Reply With Quote
Old 01-03-2010, 03:25 PM   #158
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: My 57 Pro Street
Here is a little inspiration for your 57 Kim!
Yep... I finally found a video clip of the Beast.
1956 Chevy Truck - Double-Stacked Lightnin'
http://sporttruck.automotive.com/920...uck/index.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-03-2010, 04:28 PM   #159
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have seen this truck at the portland roadster show and it is awesome for sure..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-03-2010, 06:59 PM   #160
Kim57
Kim57's Avatar
That's a very cool truck.
Kim
Old 01-21-2010, 04:31 PM   #161
Kim57
Kim57's Avatar
Made a little progress on getting the brackets for the brakes mounted.
The pics are pretty self explanatory.
I cut the original mount for the pedal off.
I'm using 3/4"x1/2" DOM going through the frame to mount them.
I still have to weld everything in but it's raining and I don't like to weld with bad weather.
Kim
Old 01-21-2010, 04:34 PM   #162
Kim57
Kim57's Avatar
Here are a few more pics.
Sorry the last one is a bit blurry. You can see the access hole I had to cut in the cab mount to be adle to get the bolt in.
Kim
Old 01-21-2010, 04:47 PM   #163
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Good job Kim, keep us posted with your progress.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 01-21-2010, 05:43 PM   #164
Fat Mike
Fat Mike's Avatar
Thank you for posting these pictures! You have convinced me to purchase 78 chevy truck with a 350 combo and hydobrake set up on it. Really nice build.
Old 01-21-2010, 06:45 PM   #165
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
'78???
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 01-21-2010, 08:15 PM   #166
CAL 58 GMC
CAL 58 GMC's Avatar
Nice job Kim!
Old 01-22-2010, 01:09 AM   #167
Kim57
Kim57's Avatar
Thanks for the compliments guys.
Kim
Originally Posted by nickp51chevy View Post
'78???
I believe he is using as a doner truck for the running gear and brakes.
It has a hydroboost system on it.
Kim
Old 01-22-2010, 02:08 AM   #168
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
Kim
Hey Kim, yeah, isn't the weather here just wonderful. I've been having the same problem..... I do all my plasma-ing outside and every time I get ready to cut something it starts pouring! Damn the weather, at least it should clear up for weekend!
addicted2dunes is offline   Reply With Quote
Old 01-22-2010, 11:45 AM   #169
Kabwe
Certified Car Nut
Kabwe's Avatar
Great job Kim.
Kabwe is offline   Reply With Quote
Old 01-24-2010, 12:45 AM   #170
nuke1
nuke1's Avatar
looks great!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-24-2010, 04:29 PM   #171
my67chevytruck
Under Construction
my67chevytruck's Avatar
great progress Kim, keep at it...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-26-2010, 05:04 PM   #172
Kim57
Kim57's Avatar
Got a little more done on the brakes.
Welded the DOM in and mounted the power booster to see how it fit.
I still have to figure out the length of the tube that will conect the pedal to the booster.
Kim
Old 01-26-2010, 05:51 PM   #173
jjjmm56
jjjmm56's Avatar
Can I ask why you mounted your booster back so far, and is that a power brake booster or just a master cyl?
jjjmm56 is offline   Reply With Quote
Old 01-26-2010, 07:27 PM   #174
Kim57
Kim57's Avatar
It's a hydroboost unit.
I mounted it there for ease of maintenance. It sits just in back of where the cab ends. My bed is going to tilt so it will be easy to get to.
Kim
Old 01-26-2010, 09:27 PM   #175
nickp51chevy
Kim that'a a sweet set up your doing for your brakes, and the tilt bed; awesome!
Had;
