Old 04-12-2010, 11:43 PM   #151
Captainfab
60-66 Nut
Re: My whole braking system - thinking out loud
You could use the Astro rotor with the brackets that I'm making, but use the '76-'78 Eldorado calipers that have a built in e-brake. The Cardone numbers for them are 16-4116 and 16-4117. The online price is $110.00 ea. plus a core of $24.50 for one and $13.50 for the other.
Originally Posted by lowdownstar View Post
So whats the deal here guys? I am looking for rear disk brakes but i need a E brake to make the state happy. How is this all working out? thanks for any and all help.
Thanks Ray
Old 04-13-2010, 06:40 AM   #152
lowdownstar
big guy
lowdownstar's Avatar
Thanks for the info captainfab. You have come up with a real nice system
Thanks Ray
lowdownstar is offline   Reply With Quote
Old 04-13-2010, 04:48 PM   #153
aggie91
I'm just glad to be here!
aggie91's Avatar
Captain,
What about this caliper...it is from a 1985 Cadillac Seville...this if from RockAuto.com: (price, core, total)
A-1 CARDONE Part # 164139 {Loaded; [Caliper w/Installation Hardware & Pad] Reman.}Rear Left; w/Casting #020L, #021R; OE Metal Piston;Semi-Metallic Pads ( $90.89, $30.00, $120.89)
A-1 CARDONE Part # 164138 {Loaded; [Caliper w/Installation Hardware & Pad] Reman.}Rear Right; w/Casting #020L, #021R; OE Metal Piston;Semi-Metallic Pads ( $90.89, $30.00, $120.89)
Would these work on your brakets? I have seen these on eBay for less than $150 for a pair minus the pads.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-13-2010, 10:12 PM   #154
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
ok i found out that my truck has a 12 bolt rear end today would these brackets still work? I would be totally bummed if they dont. I was really interested in doing this.
staggerd86c-10 is offline   Reply With Quote
Old 04-13-2010, 10:40 PM   #155
Captainfab
60-66 Nut
Those calipers are the 'Metric' calipers. They are sized for rotors that are in the 1" thick range. That is the style of calipers that I was using with the Lincoln rotors. The Astro rotors are 1.250" thick.
Originally Posted by aggie91 View Post
Captain,
Old 04-13-2010, 10:42 PM   #156
Captainfab
60-66 Nut
Yes they will work. They are designed to work with the 12 bolt truck differentials from '64-'81 and the 10 bolt truck differentials from '82-'87.
Old 04-13-2010, 11:14 PM   #157
Captainfab
60-66 Nut
OK, I received a Wilwood D52 dual 2" piston caliper from smashingchuck today.....thanks Chuck! I'm glad I waited to ship these brackets. It was nothing major, but this set of brackets are going to require a little bit of clearencing. You can see what I mean in the following pics. I will be updating my CAD drawings to reflect the needed change for the Wilwood dual piston calipers. Otherwise they fit well and look awesome.
I want to thank smashingchuck for allowing me to use this thread for developing these brackets.
Old 04-13-2010, 11:29 PM   #158
nlped
nlped's Avatar
SWEET!!! The dual piston caliper "shape" was my only concern. I really like that you followed up and already got an answer. You sir, are a true businessman!!! Good Job!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-13-2010, 11:43 PM   #159
lolife99
67-72 parts collector,…
lolife99's Avatar
Excellent work!
Do you have a source to powdercoat these brackets?
Keith
Convert to disc brakes.
Old 04-14-2010, 12:00 AM   #160
Captainfab
60-66 Nut
Thank you for the compliment
Yes I do......about 100yds from my shop. Do you have a color in mind?
Excellent work!
Old 04-14-2010, 01:23 AM   #161
lolife99
lolife99's Avatar
I would like satin black.
I'm in no hurry.
Send me a PM about additional costs,... or post them on here if you plan to offer them that way.
Thanks.
Keith
Old 04-14-2010, 02:11 PM   #162
aggie91
aggie91's Avatar
Thanks, I guess I missed that detail...
Karl
The LST Challenge:
Old 04-14-2010, 02:20 PM   #163
Alvin
Never Done?
Alvin's Avatar
Sweet! Although I won't be purchasing a set of brackets it was fun to see the process and finally reach an end product. It looks really good. Great work Captainfab!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 04-14-2010, 09:50 PM   #164
N2TRUX
Happy to be here
N2TRUX's Avatar
So when do you start work on a 13" kit...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-14-2010, 10:10 PM   #165
staggerd86c-10
my truck is an 86 so I assume its an 86 12 bolt, so it will work?
Old 04-14-2010, 11:48 PM   #166
Captainfab
60-66 Nut
First I'll need to find some 13" 5x5" rotors. So far the only OEM 13" rotors I've found are 6x5.5"
I thought someone was making them after that deal ScotI was working on a year or so ago.
Old 04-14-2010, 11:54 PM   #167
Captainfab
60-66 Nut
Your brackets are at the powder coaters. They should be done by the end of the week....hopefully. I will be posting the cost once I find out how much they will be.
I'm in no hurry.
Thanks.
Thanks for the compliment Alvin
Earlier you stated that you're truck had a 12 bolt. 86's didn't come with 12 bolts, they came with 10 bolts. Has someone changed the rear end to a 12 bolt? These brackets will work on truck 10 bolts up thru '87 on the trucks and thru '91 on the Suburbans.
Old 04-14-2010, 11:59 PM   #168
staggerd86c-10
so how did my truck end up with a 12 bolt? the old man that had it kept it mostly stock. it wasnt an option that truck was a heavy half truck
Old 04-15-2010, 12:03 AM   #169
Captainfab
60-66 Nut
I don't know. I have never seen a truck newer than about '81-'82 with a 12 bolt from the factory. Are you sure it's a 12 bolt? Either way these brackets will fit.
Old 04-15-2010, 12:05 AM   #170
staggerd86c-10
yup i just got the rear end gasket changed and the bolts i had broken in there taken out and tapped again. so its definately a 12 bolt, now how it got back there its a mystery. Its a good thing though right, supposedly its stronger then the 10 bolt or am i wrong again?
Im just glad your brackets will work.
Old 04-15-2010, 12:16 AM   #171
lolife99
lolife99's Avatar
[QUOTE=Captainfab;3920998]Your brackets are at the powder coaters. They should be done by the end of the week....hopefully. I will be posting the cost once I find out how much they will be.
Thank you.
Just let me know how much I owe you.
Keith
Old 04-15-2010, 12:31 AM   #172
Captainfab
60-66 Nut
Yes typically the 12 bolts are stronger than the 10 bolts. The 10 bolts will withstand a fair amount of abuse though.
Old 04-15-2010, 12:35 PM   #173
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I will be going to the garage hopefully tonight to pick up my spindle and front brake stuff and I will take a picture of the stuff I'm playing with.
As far as the front rotors, the Dodge Ram stuff im using only requires redrilling the lug pattern. its 13.1" forgot the thickness, will check alldata, and a difference that I can tell from autozones website is the overall depth of the rotor, front to back is about .25-.5" deeper. anyway, I'll post some pictures tonight.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-15-2010, 02:32 PM   #174
skeeterbug
skeeterbug's Avatar
I guess since i have read this very interseting post everyday since it was started by chuck, that means i have turned my wants into needs. captain fab sign me up for a set of the brackets powdercoated in satin black please. i am currently working on my braking system now anyways, do you know what prop. valve i will need, i have to replace mine anyways.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 04-15-2010, 09:02 PM   #175
87chevy.com
this is the front rotor setup I was mentioning earlier..
I must have been in a hurry and didnt double check the spacing in the autocad file becuase I drilled the frist patten to 5.25.. lol... these rotors are at minimum anyway, but the second pattern (shoulda been the 1st) was spot on.
and with the rotor turned upside down, you can see how it fits perfectly onto the stock replacment rotor and already has a bevel. For those who will notice the studs dont stick out much.. the stock rotor was not turned into a hub yet so the Dodge rotor was sitting down on the stock rotor surface.. I think the studs will need to be longer anyway
Weather permitting, I will be going to the pick and pull for a spindle nut and washer... Ace hardware didnt have a 3/4x20 nut, or castle nut... plus they want 5 bucks anyway.. then I will be able to snug everything down and start working on the caliper adapter bracket
clint
