Old 06-26-2012, 01:54 PM   #151
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Project: LS1ick68
+2 For AN fittings. Keep at it!
John
1999 Toyota Tacoma 4x4
Old 06-26-2012, 09:16 PM   #152
BigDan3131
BigDan3131's Avatar
If you do the power steering lines those are specific hose and fittings do not just use regular AN.
BigDan3131 is offline   Reply With Quote
Old 06-26-2012, 09:32 PM   #153
5150
C10 Club Tennessee
5150's Avatar
You have less then 4 weeks before the show, so you'd better hurry!!
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-27-2012, 07:37 AM   #154
68Stepbed
68Stepbed's Avatar
Yeah, I knew that, but thanks for the tip.
Calm down, B!
I fired her up last night. It was late and I wasn't able to get a video. Sorry. Man, does she have a rowdy idle, too!! With the open headers, she sounds MEAN!!!!
I have an issue, though. It sounds like something is rubbing or hitting somwhere. There's a grinding noise, mostly noticeable when I shut it off or rev it up a little. The trans is bolted up, but the torque converter is not. At first, I thought the converter had vibrated against the flexplate and that was causing the noise, but the converter is still sitting snug against the trans. I looked for anything that may be rubbing or hitting anywhere, but there's nothing visible. I'm thinking maybe the starter could be the culprit. It may not be fully disengaging.
Anybody have any ideas?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-07-2012, 01:29 PM   #155
68Stepbed
68Stepbed's Avatar
New upper and lower hoses, belt, trans lines, Lokar trans dipstick, temporary steam line, and other tidbits installed. Trans fluid and coolant put in. Reached in, turned they key to "ON" position, let the fuel pump prime, turned the key with eager anticipation............"click"................Battery is dead!!!!!!!
It's hotter than #$&* outside with high humidity today, and I'm sweating like a.............well I'm sweating pretty bad, so I hooked up the charger and came inside for a little while to cool off while the battery charges. Figured I would post a quick update since I'm inside.
Matt
Old 07-07-2012, 01:51 PM   #156
5150
C10 Club Tennessee
5150's Avatar
Ok, it's been 20 minutes. Get back out there and start that thing!!!!
You sound like someone else I know whining about the heat.
Bryan
www.gmtruckshow.com
Old 07-07-2012, 02:49 PM   #157
68Stepbed
68Stepbed's Avatar
Tried, and nothing. Tried jumping it off with 2 vehicles, and still nothing. The battery is a few years old, so it's probably time for a new one anyway. Back to the parts store!!
Matt
Old 07-07-2012, 05:27 PM   #158
68Stepbed
68Stepbed's Avatar
Matt
Old 07-07-2012, 05:46 PM   #159
gringoloco
A guy with a truck
gringoloco's Avatar
Schweet!!!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-07-2012, 07:27 PM   #160
Kim57
Kim57's Avatar
Sounds great.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-07-2012, 08:13 PM   #161
VA72C10
VA72C10
VA72C10's Avatar
Niiiiiice! Sounds great which is saying a lot for an internet clip....most sound atrocious...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-07-2012, 09:27 PM   #162
68Stepbed
68Stepbed's Avatar
Thanks all! This has been a frustrating, yet satisfying day.
Yeah, I figured with it being inside the garage, it wouldn't sound too good. That's why I walked around to different positions. That was completely untuned with the #3 timing pill installed. I set the idle and mixture screws later, and the idle improved, then I put in gear. It has a great sounding idle in gear!! I'll try to get another vid when I have someone besides a 9 yr old to help out.
The open headers are fun, but I can't wait to get the exhaust hooked up. I'm hoping to take it Wednesday.
Matt
Old 07-12-2012, 08:15 AM   #163
68Stepbed
68Stepbed's Avatar
Got the headers connected to the exhaust yesterday.
I'll try to get a better video, but for now, this is all I was able to get. You will have to turn up the volume to hear it good. There's alot of background noise going on at the muffler shop.
Matt
Old 07-12-2012, 09:55 AM   #164
gringoloco
A guy with a truck
gringoloco's Avatar
Such a clean truck- hope you get it all sorted out soon
-Chris
Old 07-16-2012, 08:49 AM   #165
68Stepbed
68Stepbed's Avatar
I finally got a few things taken care of and it finally stopped raining here long enough, so I took her for the first test drive on Saturday. The engine feels very strong, but I still need to set the correct timing curve and tune the carb.
The first obstacle before fixing all that is getting the trans working right. It won't upshift. It stays in first gear. The guy that built it is planning to come check it out on Tuesday night. He said there's a valve that tends to stick closed after they have sat for a while that will keep it from shifting. He said he may have to remove the valve body to release it manually.
Matt
Old 07-16-2012, 11:13 AM   #166
funkytechmonkey
funkytechmonkey's Avatar
Matt... think you could make it to our meet next month at my restaurant? info is in my sig
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 07-16-2012, 11:58 AM   #167
68Stepbed
68Stepbed's Avatar
Brian, I'll see if I can do that. The fam and I are planning to attend an ADRL event in Charlotte the first weekend in Aug, so as long as we've recooped from that, I should be able to attend.
Matt
Old 07-16-2012, 02:53 PM   #168
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Do you have a cable and a laptop to load the MSD software, so you can connect with your MSD box? Just an FYI is you hadn't already heard...the MSD box will add/subtract timing based on what's in the MAP table...sensor or not.
So if you have a MAP...connect to tune your own vacuum advance curve.
If you don't have a MAP...0 out ALL values in the MAP table.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-16-2012, 03:37 PM   #169
Bennett68C10
Bennett68C10's Avatar
Truck sounds awesome Matt, good luck with tuning it hopefully it doesn't give you too much trouble
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-16-2012, 05:43 PM   #170
68Stepbed
68Stepbed's Avatar
No laptop, but a friend is bringing one over. I already have the MAP curve figured into the initial tune. Thanks for the FYI, though.
Thanks, Keith. It shouldn't be too hard to tune. It's mainly just carb and timing. I've been doing that long enough to do it in my sleep. The biggest difference is setting the timing with a computer instead of weights, springs, vaccum advance, and twisting a dist. while holding a timing light.
Matt
Old 07-19-2012, 12:27 PM   #171
68Stepbed
68Stepbed's Avatar
Some semi-completed pics. Really all I have left is some re-routing of some plumbing, and some minor detailing.
Matt
Old 07-19-2012, 01:08 PM   #172
gcburdic
Restoration Virgin!
gcburdic's Avatar
That looks fantastic Matt!!!....What's the plan for the rearend??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-19-2012, 03:22 PM   #173
68Stepbed
68Stepbed's Avatar
Well, Geoff, I need to start buidling some funds back up first. I'm going to get new axles, and new Eaton LSD, and a new seal and bearing kit for it, and get it all assembled. Then, of course, I'll have to pick up some wheel spacers since the backspacing won't work with the early rearend width.
Sometime eventually, though, I'll just order a new set of wheels with correct backspacing.
Matt
Old 07-19-2012, 04:14 PM   #174
nibs
JRods Garage
nibs's Avatar
Damn clean man! I hope to get mine installed and looking that good. This is really giving me the itch!
Orange Julius-My dropmember'd, LS'd, SWB street machine...
nibs is offline   Reply With Quote
Old 07-26-2012, 12:24 PM   #175
bchaney
bchaney's Avatar
Awesome job! You really have a clean a$$ truck! i wanting to do the same swap to mine doing my best to save up for it.
bchaney is offline   Reply With Quote
