03-26-2014, 09:48 PM | #151 |
Re: 68 C10 Project FROSTBYTE Extreme Dropmember
UPDATE! Look what came in while I was on vacation! I was actually excited to get back to open it up! haha After doing some thinking about where I wanted to go with this project, I decided I wanted to go with a 4L80E instead of a 700R4. It'll be a stronger transmission, and I'll have more control over it. It has a 2200 stall converter, which will be plenty for me.
I'm still deciding on which transmission controller I'm going to be going with, I've looked at just about all of them, any opinions on them would be greatly appreciated! I'd like to get one that is compatible with an IPAD because I'm going to be controlling everything else on the IPAD. No pictures of progress of the rest of the truck, just been cleaning up the cab a little bit seeing how much rust I'm dealing with. It's the typical places for rust, small pinholes in the cab corners and a little bit at the rockers near the kick panel. The drip rails don't look bad either. We'll see how bad everything really is once it's completely stripped down.
Rick 1968 Chevy C10 Shortbed, 383 w/4L80E, Extreme Dropmember, Accuair I-Level, Bonspeed Big Blocks |
04-13-2014, 10:28 PM | #152 |
No updates, just a couple pictures. Pulled it outside to get some sun! This is at ride height. Of course I couldn't resist to throw the front fender on there real quick. Can't wait to get moving on this, works' been keeping me real busy lately...
04-13-2014, 10:41 PM | #153 |
Looks great, did you get that big ole 4l80e installed yet. Just wondering if you have to modify the floor any to get it to fit. I really want one for my truck eventually.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
04-13-2014, 10:46 PM | #154 |
nice!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
04-14-2014, 10:35 PM | #155 |
Thanks! I haven't installed the 4l80E yet...I'm wondering the same thing! lol I did get a high hump to get me part way there, but I'm thinking I'm going to have to extend it back and up a little bit more. I'll make sure to let you know when I've got it installed and the floor modified.
04-14-2014, 10:36 PM | #156 |
04-15-2014, 12:34 AM | #157 |
I've got the mild drop member with the 4L80E and I've got a ton of room. I know the extreme is an additional 2" but I'd test fit before just cutting your floor. I did cut the big "ears" off the bell housing for header clearance though. Love the direction your truck is taking. Very nice!
Wade |
04-16-2014, 10:12 PM | #158 | |
05-07-2014, 05:41 PM | #159 |
Truck looks awesome man! I am staring at my bare frame right now and it is just begging for some Porterbuilt/Accuair love..LOL
Brandon
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
05-08-2014, 10:23 PM | #160 |
Thanks Brandon! Pretty much any frame looks a lot better with Porterbuilt/Accuair products! haha
05-08-2014, 10:34 PM | #161 |
Awesome
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=602142 |
05-11-2014, 09:27 PM | #162 |
Well I finally have a little bit of progress to report! My dad and I were able to get the transmission installed along with the high hump, which looks like it's going to fit perfectly! We also ended up cutting out the dash, I'm looking at getting a custom dash made up, so it had to go! No turning back now! The cab and doors are hopefully going to get media blasted this week and then it's off to the body shop! Can't wait!
05-11-2014, 10:02 PM | #163 |
Hey Rick I thought i had enough room too but when I started setting the 4-5* trans hit the high hump...Not tryin to spoil it but make sure the rear drop is right....May just have been me!!!...........Update ....just realized your using sbc instead of ls....may be the difference....my bad.............jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
05-11-2014, 10:17 PM | #164 | |
05-11-2014, 10:27 PM | #165 |
Really nice build! Excellent wheel choice!
05-11-2014, 10:34 PM | #166 | |
05-11-2014, 10:49 PM | #167 |
Alright, sounds good, I'll let you know. Thanks a lot!
05-12-2014, 06:35 PM | #168 | |
With the sbc/700r4, no clearance issues w/the high-hump cover. Once the 6.0/4l80e was swapped in, there was definite interference. With some adjustable conversion plates, I might have been able to pull the motor farther forward but I was worried about clearance farther up front between the radiator/fan & accessory drive. I had to trim extra sheet metal when setting it up for 3-5° drivetrain angle. It also might be compensated for w/the correct DM LS style mounts....
05-12-2014, 10:12 PM | #169 | ||
When you guys were measuring the 5* slope of the transmission, where were you taking it from? The back of the tail shaft? Maybe I'm taking the measurement at the wrong spot... Everything seems to look right and after checking my other angles for the drive shaft, those seem to be pretty much spot on as well... Let me know if you could. Thanks!
05-12-2014, 10:25 PM | #170 |
67-72 parts collector,…
Back of the trans with the frame level.
Not setting on its wheels.
05-12-2014, 10:32 PM | #171 | |
05-12-2014, 10:35 PM | #172 |
Thanks Keith! That's where everything was at, so it looks like I'm in good shape.
05-12-2014, 10:38 PM | #173 | |
05-12-2014, 10:47 PM | #174 |
Sears is where i got mine.....and I forgot .....Keith is right....frame level............
05-18-2014, 08:52 PM | #175 |
Hey guys. You can download an app by Tremec. It's free and works really well. If something is off. It also tells you what you need to do to get it within the acceptable parameters.
Tags |
accuair, cpp, dropmember, mmw, porterbuilt |
