#1776 |
![]() Join Date: Mar 2007
Re: 53 Surburban "Family Truckster"
A rubber one. Look closely at the fuel pump flange. It was not flat (where the lock ring and seal goes). I used sheet metal screws and I'm afraid it was not evenly apply down pressure to create a liquid tight seal. The new tank has a flat flange/mounting surface and has treaded holes to bolt the fuel pump and sending units down tight.
I also adjusted my watts link some too while I was add it. I added length to both parallel bars. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#1777 |
![]() Join Date: Mar 2011
nice looking tank...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1778 |
Sometimes its hard to get reliable products....Good job on your truck.
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
#1779 | |
Thank you
I took it to a fabricator friend yesterday to help me modify the angle of the filler neck. Once I get it back I can get it all reinstalled. Thanks Marc
#1780 |
I went over to my friend Zach's that is helping me modify my filler neck on my new tank. Like everything he does he took it over the top. My idea to modify the neck was quick and dirty. Zach's not so much. We cut out the existing filler. He then formed a new piece of metal and cut out the old filler neck in an effort to weld it in more straight up and down to match my previous tank. The tank will be wrapped up this week #nomoreleaks
I also started on the PITA headliner. My headliner will be made out of 1/16" black ABS plastic. I purchased a large roll of chipboard from Home Depot. This thick board used for wood flooring allows me to make templates of each of the headliner sections to use to cut the ABS. I got the rear piece cut, fine tuned and fit after a long fight. I will take pics of the ABS panel in place but this picture shows the chipboard to give you all an idea. 1 section down with 4 to go. Oh and the bonus pick is a bagged ACME chassis with a Don Hardy LS motor for a customer of Zach's he is building. Its for a FO$% truck. The rear rims are 24' x 15". I'm helping him figure out how much to shorten the rear-end. Thank you Marc
#1781 |
Marc, tank is going to look great with the changes. Nice chassis and engine set-up...Jim
#1782 |
Very cool seat belt idea!! Does the chip board bend easy? Could it be as a headliner or is it to weak?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1783 |
That work on the gas tank is rather nice! As for your headliner, I recently went through the same process on my build (Fargolet) using both ABS and hardboard. I used hardboard with vinyl glued to it for most of the interior (including the one piece headliner) and it was a PITA. I got hold of a sheet of 1/8 ABS to do a few remaining pieces as well as a firewall pad and I fell in love with that material. I will always use ABS in the future. You can always glue vinyl to that ABS if you want the headliner to match the rest of that gorgeous interior you have built.
You mentioned getting "a roll of chipboard" to make your templates. Is that the thick cardboard like material that they roll down to protect floors? And if so, how was that stuff like to work with to make templates for those overhead panels? |
#1784 | |||
Thanks guys Marc
#1785 |
The tank is done. Here are a few pics. I will touch up the paint with silver and then install. Here is a picture of 2 of the headliner panels in.
Here is a link for the ram board I used for templating. It was a must for this project. https://www.homedepot.com/p/Ram-Boar...202829135-_-N& Thanks Marc
#1786 |
Very nice...Jim
#1787 |
Thank you sir. I should be getting my tank back tonight. Looking forward to getting is reinstalled.
Marc
#1788 |
6>8 Plugless........
![]() Join Date: Sep 2007
That tank mod turned out great! The headliner is very nice too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#1789 | |
Marc
#1790 |
![]() Join Date: Feb 2020
Very nice work on the tank. Tig?
#1791 |
Thanks...I can't take credit. It is my friend Zach's handy work. He is a fabricator for Dutchboy's Hotrods. He did say he used brazing rod to eliminate any air pockets in the welds which might cause leaks.
Marc
#1792 |
Has the ABS went up like everything else? I had a dumb idea to try and make a headliner for my 40 Ford out of ABS.
#1793 | |
Marc
#1794 |
Just about have the interior wrapped up. On Sunday I finished the last (2) sections of headliner. This took all day. The last piece was especially challenging as it tucks under the front window trim. It is done and one of those projects that I'm glad to have behind me. I just need to remount my visors and give the interior a good cleaning.
Tuesday we are supposed to be in the low 40's so I'm hopeful to get me gas tank rinsed out and reinstalled. Thank you Marc
#1795 |
![]() Join Date: Sep 2017
Wow! That looks great!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#1796 | |
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#1797 |
Marc, nice job on liner...Jim
#1798 |
Thank you
Thanks, I was REALLY getting sick of looking at the unfinished headliner. Took 2 4' x 8' sheets due to the width. Thank you Jim, much appreciated. Marc
#1799 |
I am defiantly going to have to use abs sheet on a future build. Was it difficult to figure out the pattern using the fiber board?
#1800 | |
I will probably go in an heat the panels with my heat gun to relax and mold them to the shape. Not sure it is necessary but I figured that it cant hurt. The more I work with ABS, the more I like it. With the 1/16 thick you can score with a Utility knife and score and it snaps on the score when slightly folded. In a truck you could get really fancy and glue down foam and cover with material. In a Suburban not so much. Marc
