03-19-2018, 07:15 PM | #1 |
Re: My 52 GMC Build
Looking good there buddy...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-19-2018, 07:35 PM | #2 |
6>8 Plugless........
Re: My 52 GMC Build
Oh yeah! That looks so much better! TDI in the Jeep sounds sweet too!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-19-2018, 10:14 PM | #3 |
Re: My 52 GMC Build
cheaaaaahhhhh
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
03-19-2018, 10:15 PM | #4 |
Re: My 52 GMC Build
Always getting good ideas here. The playing card trick is a new one for me. Nice!
Truck looks really good....like it is lounging there on the lift. |
03-20-2018, 07:55 PM | #5 | |
Re: My 52 GMC Build
It's what it needed I think Quote:
Yes sir Glad to pass it on. Looks quite comfortable up there.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
03-20-2018, 09:04 PM | #6 |
Re: My 52 GMC Build
That looks Awesome! Shop is great also.
1950 3100 5 window |
03-21-2018, 03:03 PM | #7 |
Re: My 52 GMC Build
03-21-2018, 03:24 PM | #8 |
Re: My 52 GMC Build
So I have been working on improving the cooling of the motor over the past year. It never overheats just runs hotter than I like on the highway, due to the inter cooler blocking half the rad. I had made big improvements by blocking off gaps around the rad. So this round I cut out 4, 3" holes through the front cross member and sleeved them with pipe. Also cut down the angle iron that holds the bottom of the inter cooler. I figure I just gained 3" of unrestricted air to the rad.
Old pic New pic. Just has to be painted and front trans cooler bolted up.
03-21-2018, 04:08 PM | #9 |
Re: My 52 GMC Build
can you reposition that trans cooler to the frame side and direct air across it so it doesn't add heat and take away flow to the rad? some of the modern trucks have them behind the trans, in front of the axle
could you install some air directors in the holes you just made to direct air flow to the rad fins? how about just reshaping the whole cross member to still support the weight and stress but not be in the flow path? |
03-21-2018, 05:31 PM | #10 |
Re: My 52 GMC Build
Looks awesome Bob. Man that’s one sweet looking ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
03-22-2018, 07:50 PM | #11 | |
Re: My 52 GMC Build
Thanks Matt
03-22-2018, 08:39 PM | #12 |
Re: My 52 GMC Build
What do you have for a fan shroud? Maybe some vents in it covered with rubber or plastic flaps that open with air flow while driving down the road?
Alot of newer cars have flaps of somesort to increase flow
03-25-2018, 11:35 AM | #13 |
Re: My 52 GMC Build
So when will you test drive it to see the results
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
03-26-2018, 08:07 AM | #14 | |
Re: My 52 GMC Build
Weather looks good Wednsday, Thursday for a test drive, but I won't know until it gets above 20*C 70*f or so. I have put 10,000 mi on the truck in 2 summers, so I think it will do what I need.
03-26-2018, 09:02 AM | #15 |
Re: My 52 GMC Build
So another thing on the list was respraying the rear fenders due to the clear coat flaking off. I took off the fenders and scuffed them and flat cleared. Turned out good.
03-26-2018, 12:38 PM | #16 |
Re: My 52 GMC Build
Yes, those came out nicely. Nice lines too. Did you do those?
03-27-2018, 07:52 AM | #17 |
Re: My 52 GMC Build
No my pin stripper (Petts) did them before. I just scuffed over them so I wouldn't loose them.
03-29-2018, 07:54 AM | #18 |
Re: My 52 GMC Build
OH WOW the truck works better than ever!!!!!!
There obviously was a problem with my old hydro-boost because first time I hit the brake peddle I almost locked up the brakes and through my dog on the floor lol. The new front rubber having a taller side wall rides so smooth. My son and I took it out to an abandon building I have been eyeing up and got some pictures. Oh and did a few burnouts just to make sure.
04-20-2018, 08:22 AM | #19 | |
Re: My 52 GMC Build
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
03-29-2018, 08:29 AM | #20 |
Re: My 52 GMC Build
so the new season begins!!!! looking good
03-29-2018, 09:07 AM | #21 |
Re: My 52 GMC Build
New fronts and paint on the rears made a huge difference, looks great!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
03-29-2018, 12:08 PM | #22 |
Re: My 52 GMC Build
Love the new look......
03-29-2018, 05:03 PM | #23 |
Re: My 52 GMC Build
It looks just right now! That's nuts on the brakes. I bet your dog got a wake up call.
03-29-2018, 05:29 PM | #24 |
Re: My 52 GMC Build
Awesome. Looks really good.
03-29-2018, 08:16 PM | #25 |
Re: My 52 GMC Build
Let's see the burnouts lol
Tags |
bagged, build, diesel, gmc, hot rod |
