Old 11-28-2016, 06:22 PM   #1901
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Kabwe's aka Bam's build
There IS nothing he can't do. Hence the nickname. Give him a job to do and "BAM" it's done! Lol
Hey Bam, I don't know if you've seen my thread lately but I'm replacing my dash with a '55-'56 car dashboard like you have done. I looked at your thread for details but didn't see much. I'm wondering if you have any in-process pictures?
Also wondering if it's as easy as it would SEEM to be?
1. Locate the spot welds and drill out.
2. Pry dash loose carefully
3. Center new one in the space.
4. Rosette weld it in place?
Are there any "hidden" welds that could help this go easier? Other considerations i haven't thought of yet? Any/all help or advice is appreciated. - Dan
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 12-05-2016, 12:39 PM   #1902
Kabwe
Certified Car Nut
Kabwe's Avatar
Got the engine, trans, and torque converter mated up, next is to get it between the frame rails.
Kabwe is offline   Reply With Quote
Old 12-05-2016, 12:49 PM   #1903
solidaxel
solidaxel's Avatar
Great power plant !
What torque converter did you use and what stall?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-05-2016, 01:44 PM   #1904
JML55
JML55's Avatar
Looking good Bam
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 12-05-2016, 06:06 PM   #1905
oldman3
oldman3's Avatar
Engine, trans combo looks great...Jim
oldman3 is offline   Reply With Quote
Old 12-05-2016, 08:21 PM   #1906
Kim57
Kim57's Avatar
Looks real nice Bam.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-06-2016, 04:20 AM   #1907
RockinKees
RockinKees's Avatar
That is going to look really nice between the framerails!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-06-2016, 07:44 AM   #1908
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
It's going to look great in your truck!
ChuckDriver is offline   Reply With Quote
Old 12-06-2016, 03:16 PM   #1909
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks guys I really appreciate the comments.
Old 12-16-2016, 12:09 PM   #1910
VDOG
Grand PooBaa Member
VDOG's Avatar
Engine and trans looks great. Think im going to need you to set me out about 8 car lengths when we race. LOL
VDOG is offline   Reply With Quote
Old 12-16-2016, 02:56 PM   #1911
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks man, but there will be no racing here. I just need enough get up and go to pass some of these Los Angeles drivers who wont let you get over.lol
Old 01-02-2017, 01:46 PM   #1912
VDOG
Grand PooBaa Member
VDOG's Avatar
Now that's true, got to be able to get away from bad drivers. Guess I need an engine upgrade also.
Old 01-02-2017, 01:58 PM   #1913
bajabob
bajabob's Avatar
bajabob is offline   Reply With Quote
Old 01-04-2017, 06:24 PM   #1914
BAM55
BAM55's Avatar
I forgot to post these. Its the new 15 inch 55 Belair steering wheel. I think it will look nice with my transplanted 55 car dash.
Before the clearcoat was applied
After the clearcoat
BAM55 is offline   Reply With Quote
Old 01-04-2017, 06:26 PM   #1915
Kim57
Kim57's Avatar
That looks fantastic.
Kim
My build thread
Old 01-04-2017, 07:02 PM   #1916
ChuckDriver
Looks nice!!
Mine flex's so much when turning that it blows the horn! I finally had to pull the fuse.
Old 01-04-2017, 07:14 PM   #1917
hotrod1
56 - autocross
hotrod1's Avatar
I air tested everything alone the way. Next step install the Torque Converter and bolt her up to the engine.
Hey Bam. Hope u are doing well.
How did u test the trans with air? Would like to learn.
hotrod1 is offline   Reply With Quote
Old 01-04-2017, 07:21 PM   #1918
iajonesy
I've been following your build for quite a while and am quite impressed with the amount of talent and drive you have. It is the true model for a 55-59 build.
I have a question for you. Is rounding the bed corners as daunting a job as it looks? I want to try it but keep having second thoughts. Where did you get the tubing for the job?
Keep posting and I'll keep watching.
Mike
iajonesy is offline   Reply With Quote
Old 01-04-2017, 07:22 PM   #1919
BAM55
BAM55's Avatar
Originally Posted by ChuckDriver View Post
Looks nice!!
My buddy has one in his car and he does not have that issue. That is the reason I bought it, I like the way it looked in his car. You have the Impala one right? That is a really nice steering wheel, one of the best looking in my opinion. I have a friend with one in his truck I'll have to ask him about the horn issue.
There are ports on the transmission components that you blow air into and you can see the clutches move. You can find Youtube videos to show you how to do it. Its really simple
Old 01-04-2017, 07:27 PM   #1920
BAM55
BAM55's Avatar
Mike
Actually the rounded bed corners is a pretty simple mod. I bought a 16 gauge 1 5/8 u-bend exhaust pipe from jegs. One pipe will doboth rear corners. Just cut them in half to make them j-bends.lol
Here is a link to the pipe:http://www.jegs.com/i/Patriot-Exhaus...H7015/10002/-1
Here are some pics that should help
Old 01-04-2017, 07:36 PM   #1921
ChuckDriver
I have the Belair wheel, maybe I got a weak one!
Old 01-04-2017, 07:40 PM   #1922
Daze57
Daze57's Avatar
bam
looks great !!!!!
Daze57 is offline   Reply With Quote
Old 01-04-2017, 07:42 PM   #1923
RockinKees
RockinKees's Avatar
That steering wheel is a piece of Art!
It will look fabulous with your dash!!
Cheers!! Kees.
Kool Guyz CC
Old 01-04-2017, 07:48 PM   #1924
BAM55
BAM55's Avatar
Oh man I thought you had the Impala wheel to match that dash. I really like that Impala steering wheel also. I just did not think it would match my build, but I think it is one of the nicest.
Well if I have that horn issue I will deal with it like you have.lol
Old 01-04-2017, 10:39 PM   #1925
JML55
JML55's Avatar
Pretty nice
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
