Old 01-26-2010, 10:23 PM   #176
mylow53
mylow53's Avatar
Re: My 57 Pro Street
i like the booster location, but i'm wondering what kind of rod your going to use since the length may allow bowing of the rod during a panic stop. a heaver rod may effect the wear on the master cyl since it will be pushing down as you hit bumps and freeway vibrations... but yes it's easy to work on with the bed tilt. some of the guys are going with remote reservoir on the MC. Mount the reservoir where you can get to it and plum the oil to the mc....
my 2 cents
GT
keep the pic's coming
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 01-27-2010, 01:40 AM   #177
Kim57
Kim57's Avatar
my 2 cents
GT
I thought about using a remote reservoir but went with this because of the tilt bed. I'm going to use 3/4"x1/2" DOM to conect the pedal to the master.
It looks like it will be about 36" long. If that's not stiff enough I'll just go to the next size up.
Kim
Kim57 is offline   Reply With Quote
Old 01-27-2010, 04:33 PM   #178
hotrodsbyray
Instead of heavier rod - how bout figuring out a bushing / brace in the center to support it, kinda like the support they use for multi-u-joint steering shafts. And watching your build I know you are good at the "figuring out" part.
Also, I guess it would need some type shield or something to keep trash off the rod.
hotrodsbyray is offline   Reply With Quote
Old 01-27-2010, 08:15 PM   #179
Kim57
Kim57's Avatar
Thanks.
I was thinking of some kind of support at one time. The problem I see with that is the rod would need to slide back and forth through it. I would worry about it binding over time.
The DOM isn't real heavy in the shorter lenghts.
Kim
Old 01-27-2010, 08:34 PM   #180
stepside83
stepside83's Avatar
this truck is nice theres just one problem, ITS NOT MINE but no it looks good i like all the fab work that is done to the bed and frame and suspension, keep the pics comin and keep up the good work
stepside83 is offline   Reply With Quote
Old 01-28-2010, 01:32 AM   #181
nuke1
nuke1's Avatar
Kim, that set up is looking really nice, what booster are you using? i see the hydrobos, is that just a stock master cylinder on there?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-28-2010, 09:41 AM   #182
Kim57
Kim57's Avatar
It's a stock unit out of an 05 truck. I still have to figure out all the plumbing on it but that should'nt be to hard.
Kim
Old 01-30-2010, 02:15 AM   #183
CAL 58 GMC
CAL 58 GMC's Avatar
Nice job Kim! I have to ask and I'm sure there's a good reason, why did you place the master cylinder so far back?
CAL 58 GMC is offline   Reply With Quote
Old 01-30-2010, 09:09 AM   #184
Kim57
Kim57's Avatar
Originally Posted by CAL 58 GMC View Post
Nice job Kim! I have to ask and I'm theres a good reason, why did you place the master cylinder so far back?
Thanks CAL.
I placed it there for ease of maintenance. With the tilt bed it'll be easy to get to and solves the problem of a remote reservoir.
Kim
Old 01-30-2010, 11:28 AM   #185
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: My 57 Pro Street
Originally Posted by Kim57 View Post
Thanks CAL.
Kim
So you are making a Tilt Bed.
I wanna see that set up Kim!
I'm thinking of doing that to my '62.
http://67-72chevytrucks.com/vboard/s....php?p=3690881
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
Last edited by 1Bad62Pro/Street; 01-30-2010 at 11:32 AM. Reason: http://2tb6gq.bay.livefilestore.com/y1p4eEgwcgjxraDH48zBBaKsEcpAHsrRWb2_BhqN-pUxDwdYciigHjIPxAl3mHu1RDAl0c90oAdxkYK28k7CUr8yD
1Bad62Pro/Street is offline   Reply With Quote
Old 01-30-2010, 11:50 AM   #186
Kim57
Kim57's Avatar
Very nice truck 1Bad62.
Here're some pics of what I did. I built the frame out of 1x2 stock. I plan on using linear actuaters to lift the bed as the one I made isn't that heavy.
Kim
Old 01-30-2010, 12:08 PM   #187
1Bad62Pro/Street
I forgot about my fuel cell.
I don't think I could do it.
Old 01-30-2010, 01:35 PM   #188
Restrorob
The One And Only !!!
Restrorob's Avatar
Hmmm, Don't know how your bed is finished inside ? But, don't see why you couldn't add a bracket/something to the top of your frame rail to support a pivot point to clear your fuel cell ?
Crude pic but shows the idea.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-30-2010, 07:32 PM   #189
Kim57
Kim57's Avatar
I posted a reply in your build thread.
Kim
Old 03-03-2010, 01:46 PM   #190
blackdiesel
blackdiesel's Avatar
any updates??
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-03-2010, 05:19 PM   #191
Kim57
Kim57's Avatar
Originally Posted by blackdiesel View Post
any updates??
Haven't had a chance to work on it much lately as my mil is in the hospital with pneumonia and I've been there trying to help her. She's 86 and has alzheimers so its kinda touch and go.
Kim
Old 03-03-2010, 08:57 PM   #192
blackdiesel
http://www.sporttruck.com/featuredve.../photo_02.html
Every time I look at your biuld I think of this truck.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-03-2010, 10:14 PM   #193
Kabwe
Certified Car Nut
Kabwe's Avatar
Kim
I feel for ya, I lost my mom to alzheimers a year ago. Sorry to hear it man that's rough.
Kabwe is offline   Reply With Quote
Old 03-04-2010, 01:16 AM   #194
Kim57
Kim57's Avatar
Thanks Kabwe.
My mom past away December 26 of last year from it also. It's tough to see loved ones go through that disease.
My wife is an only child and it's been real tough on her.
Kim
Old 03-04-2010, 01:19 AM   #195
Kim57
Kim57's Avatar
That's a pretty slick truck. I do like the bed.
Kim
Old 03-04-2010, 08:52 AM   #196
estig70
estig70's Avatar
prayers for you and your family
Eric
estig70 is offline   Reply With Quote
Old 03-04-2010, 11:42 AM   #197
kustombrad
kustombrad's Avatar
I like the brake setup you have going! If you're worried about the DOM rod your using, you could go find a race car fab guy and snag some thin wall chromoly. It's way light and very strong! Victory Race Cars is up here by me and I've bought some from him before. Just a thought...
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 03-04-2010, 03:25 PM   #198
Kim57
Kim57's Avatar
Eric
Thanks Eric.
Kim
Old 03-04-2010, 03:26 PM   #199
Kim57
Kim57's Avatar
Thanks for the heads up on the chromoly. I'll have to check into that.
Kim
Old 04-13-2010, 01:45 PM   #200
Kim57
Kim57's Avatar
Just a small update on what I've been able to get done.
Spent some time cleaning up the frame and getting the hydroboost and pedal mounted. Ended up using some 3/4x1/2 DOM for the conecting rod. It's a straight shot so I don't foresee any problems with it flexing. This puts the reservoir behind the cab so maintanence should be easy with the tilt bed.
Kim
