11-15-2011, 09:18 AM | #176 |
Florida Edition
Re: Cheap Tricks
Not sure which part of this thread your dad is calling BS on but I'm glad he is reading it.
If its the magnets taking metals out of the water here is a link to an article about contaminates in our drinking water. http://www.water.siemens.com/en/appl...s/default.aspx If its about Coke pull one out of the fridge and try it. If its about my headlight/droplight here is a pic (actually I think this is a aftermarket droplight from the late 40's or early 50's) Hope this clears things up for him.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-15-2011, 12:18 PM | #177 |
Grandpa in the rustmobile...
Re: Cheap Tricks
We have sulfer well and cant drink it, I showed him the magnet thing and he said impossible ???
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-15-2011, 02:49 PM | #178 |
Florida Edition
Re: Cheap Tricks
The magnet trick would only pull out the metals, if you google up "Homemade water filter" you'll find some pretty cool charcoal filters that might work for you. I am thinking about building one for myself.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by RenoKeene; 12-05-2011 at 12:55 PM. |
12-05-2011, 09:00 AM | #179 |
Re: Cheap Tricks
Heres one I used over the weekend.
When trying to bend hard brake or fuel lines, use a coat hanger as a a template first. If you mess up, its easy to bend it back straight and try again until you get a good fit. Then you can use it as a pattern to make the bends on the actual line.
"Lifetime" 72 C10 Project |
12-05-2011, 09:12 AM | #180 |
Professional Crow Bar Tosser
Re: Cheap Tricks
Here's an easy way to set up trailer wiring.
Feed your wiring through a PVC pipe, and mount the pipe under the trailer frame.
Will My Beast "Big Nasty": '92 GMC Sierra K1500 Ext. Cab L31 Swap 4x4 Conversion: 2" Body Lift, 3" Skyjacker Suspension Lift, 9.5" 14-Bolt G80 Rear, 3:73 Gears, 350cid L31 Vortec 5700, 4L60-E Overdrive Automatic My Dad's Beast: CUSTOM '97 Chevrolet Silverado K3500 4-Door Mega Cab Project: 10.5" 14-Bolt G80 Rear, 4:10 Gears, 5.7L 350cid SBC Vortec, 4L80-E Overdrive Automatic "I'd rather PUSH my Chevy than DRIVE your Ford!" |
12-05-2011, 12:56 PM | #181 |
Florida Edition
Re: Cheap Tricks
Yep...thats pretty slick.
12-05-2011, 12:57 PM | #182 | |
Florida Edition
Re: Cheap Tricks
12-05-2011, 04:24 PM | #183 |
Re: Cheap Tricks
I keep a bottle of leftover STP around with an acid brush in it. I use to assemble stuff like universal joints and ball joints, pretty much anything that is pressed together. It is real slippery stuff.
12-06-2011, 06:00 PM | #184 |
GMC's n H.D.'s too!
Re: Cheap Tricks
Here is another thread that has some cheap tricks on it.
http://67-72chevytrucks.com/vboard/s...d.php?t=450644 |
12-07-2011, 12:30 PM | #185 |
I am a Referee of life.
Re: Cheap Tricks
I find the winders and lights from under the hood of a late model truck mount easily under any hood and are usually long enough to reach the back of the truck.I'm thinking of using one for a dome light in the back of the panel.
I save cardboard/aluminum tins(like Pringles/nuts etc. come in) for larger bolts and items that don't fit in the smaller containers.I gather a batch and paint them white with a rattle can,then I can label with a sharpie or Magic Marker. I haven't noticed the tip about waiting until the wife is gone to use the dishwasher for a parts cleaner.Use this one at your own risk. I hand wash and dry parts before painting.Small stuff in the sink with dish soap and hot water(unless the wife is gone and I can use the dishwasher).They dry quicker with the hot water and the part is slightly warmer for painting. I also set the rattle can in a pan of warm water to help it spray better.Don't forget to turn the can upside down and clear the nozzle or it won't spray well if at all the next time. I haven't used this one but it intrigued me.Guy used silverware trays in his toolbox.He had same sized wrenches stacked in each slot.(the ones to keep forks,knives and spoons seperate). Wrap foam pipe insulation around the upright supports(pipe ones) in the shop to prevent door dings and paint chips.Also helps when you're not looking and run into one.They will also work on some square ones. I use an old Craftsman bottom chest for a tool cart.It has 2 drawers and a ledge on the top to hold a plywood tabletop.It was already on casters.It was basically free since I had it when I upgraded toolboxes. Hope these help someone.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-07-2011, 12:44 PM | #186 | |
Re: Cheap Tricks
Posted via Mobile Device |
12-07-2011, 01:14 PM | #187 | |
Re: Cheap Tricks
A ford one was installed on mine already when I bought it. Its handy. |
12-07-2011, 04:55 PM | #188 | |
Re: Cheap Tricks
so - I got my own dishwasher AND electric stove in the garage. Somebody was pitching them and so I grabbed them from beside the road. They were gross, but shined up good as new (even the clock and the self cleaning features work). That way I can do whatever I want and she won't complain (not about that, anyway). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-07-2011, 05:36 PM | #189 |
Re: Cheap Tricks
What yall finding works best in the dish washer for cleaning solution?
12-07-2011, 07:45 PM | #190 |
Re: Cheap Tricks
Dish soap is a good degreaser but companies like "Hotsy" "Safety Kleen" and others also have solutons for automatic parts washers which are just industrial strength dishwashers.I always clean as thoroughly as possible first so a mild solution works for me and leaves less grease to "Catch ya"!
12-07-2011, 09:56 PM | #191 |
Active Member
Re: Cheap Tricks
My brother showed me this one. Use panty hose, super glue and epoxy to fix broken plastic.
Attach panty hose with a dab of superglue wrap or lay across attach with another dab of superglue, trim excess then coat with epoxy. Works really good on those plastic bossed that always break when you try to take a screw out.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
12-08-2011, 09:35 PM | #192 |
blood type; Retumbo
Re: Cheap Tricks
had a gasket fail and now there is oil in your coolant?
drain system. remove center of thermostat with wire cutters and reinstall. add 2 cups of Cascade dish machine soap and fill with water. run engine for an hour. flush with clean water (garden hose). remove block and radiator drain plugs. refill with correct coolant/water mix GM actually suggested this on Saturn 4 cylinders since they had problems with porous castings. it works pretty damn good.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
12-09-2011, 12:02 AM | #193 |
Re: Cheap Tricks
I never know oil in the coolant was a bad thing. I thought it helped lube up the water pump lol.
used this one the other day... I needed to siphon the gas out of my truck so I could pull the tank. It seems I can never get the line all the way to the bottom of the tank, so I put a nut on the line to weigh it down. I put cable ties on each side of the nut so it can't move.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
12-27-2011, 11:09 PM | #194 |
Re: Cheap Tricks
this is gonna keep me sane
thanks
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
12-28-2011, 12:41 AM | #195 |
Re: Cheap Tricks
for those cold mornings with frost on windshields
place a piece of cardboard on the windshield with the wiper holding it down,,,, ta da no ice
WITNESS Dont be like me be better than me |
12-28-2011, 01:52 AM | #196 | |
Re: Cheap Tricks
Or if I'm pretty sure it wont rain I'll take an old shirt and close my door on it while its wrapped around the mirrors.
"I feel the need for speed!"... as soon as I am done with my nap. |
12-30-2011, 09:52 AM | #197 |
Re: Cheap Tricks
If you hold the paint can upside down and spray until paint spray is clear your tip will stay clean.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
12-30-2011, 10:47 AM | #198 | |
Re: Cheap Tricks
12-30-2011, 11:34 AM | #199 |
Florida Edition
Re: Cheap Tricks
Some folks think this is "just a story"
12-30-2011, 12:42 PM | #200 |
Re: Cheap Tricks
Good thread! Everyone should own at least a few swivel sockets and the ball sockets. If you can't afford the Craftsman or Snap On just get the impact ones from harbor freight. Not quite as good but as long as you get the impact ones they work well. And are only like 2-3 bucks.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! Last edited by El Campo; 12-30-2011 at 01:02 PM. |
