Old 01-12-2016, 12:32 AM   #176
Joe Pass
Joe Pass's Avatar
Re: Used Parts Build
Amazing amount of work.....how did problems with the tig welder end up working out ?
I bought the Synchrowave 250 with the tig runner (water cooled torch)...I see in your welding class they were in use. I think the space shuttle has less things to switch on
Joe Pass is offline   Reply With Quote
Old 01-12-2016, 02:30 AM   #177
tinydb84
tinydb84's Avatar
I ended up sending it back. It was a bad fitting and bad torch. I ended up replacing it with a CK9, the air cooled version of the CK20 I was used to running in class. Everything works great now.
I really like the Syncrowaves. My buddy has one and its all I used in class. They had ones that were probably there since the school opened. They have been serviced but all worked great.
Interestingly, my welding instructor is the weld inspector for a local company that produces submarines. He can tig weld over head with the peddle between his knees...Goals!
David
Instagram: myfabguy
Old 01-12-2016, 02:33 AM   #178
DblTrbl
DblTrbl's Avatar
I'd set myself on fire for sure...
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 01-12-2016, 02:49 AM   #179
tinydb84
tinydb84's Avatar
Ive done that and I wasnt even welding...
David
Instagram: myfabguy
Old 01-12-2016, 03:09 PM   #180
slotard
The biggest problem I have with TIG is doing really delicate work with no gloves and shocking myself. Always fun. I think I've done so 3 times in the last 3 weeks...
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-13-2016, 03:25 AM   #181
tinydb84
tinydb84's Avatar
I havent had that pleasure yet. I always wear gloves though. It gets hot enough with the gloves on.
David
Instagram: myfabguy
Old 01-13-2016, 03:26 AM   #182
tinydb84
tinydb84's Avatar
Started filling in some of the wholes in the bed that were used for the camper
Here is what I decided to do with that pinch. I ended up cutting it out and moved it up 1/8 of an inch or so and welded it back in. After looking at it for a while it seemed like it would be the easiest way to fit it. If it doesnt line up perfectly I deal with it later.
David
Instagram: myfabguy
Old 01-13-2016, 04:26 PM   #183
slotard
That's part of why I like tig brazing, you don't need anywhere near as much heat. If I'm doing more than tacking I'll usually throw on a pair of latex or nitrile gloves, they're about as thin as it gets.
1973 C20, 350/350
Old 01-18-2016, 01:59 AM   #184
tinydb84
tinydb84's Avatar
Took some measurements to start my four link
Started working on my driveshaft hoop/4 link mounts crossmember
Wanted to make it look like it fit with the notches so I matched one of the angles
Decided I was going to TIG it all. Mostly because I wanted to get more practice
That is all I got for now.
I patched a bit of my inner fender and took a lot of pics because someone was asking about patching in the body work section on another board.
ignore the fact that I cut the patch too small....
TIG'ing it in
Filled and DA'd
David
Instagram: myfabguy
Old 01-19-2016, 03:53 AM   #185
tinydb84
tinydb84's Avatar
Did some some more work to my crossmember/trans hoop/four link mounts
Welded up and where about it will sit
Making some gussets
Mocking up my lower tabs
For those of you running bag on bar, how far apart are you bars? I am looking at 46'' from centerline to centerline of the bars.
David
Instagram: myfabguy
Old 01-19-2016, 06:41 AM   #186
Gary V
Active Member
Gary V's Avatar
Excellent work David!
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 01-19-2016, 10:41 AM   #187
slammed427
slammed427's Avatar
Looking good!
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 01-22-2016, 04:22 AM   #188
tinydb84
tinydb84's Avatar
Thanks Gary. I have been following your build. Hopefully I'll have skills like that one day.
Originally Posted by slammed427 View Post
Looking good!
Thanks man. Slowly chipping away at it.
Got a bit more work done to it tonight.
Going to cut the ends off and cap them. I'll extend the caps up and tie them into the outer link tabs.
David
Instagram: myfabguy
Old 01-22-2016, 05:19 PM   #189
aggie91
I'm just glad to be here!
aggie91's Avatar
Fab looks good. How are you liking that AlphaTIG machine?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-22-2016, 05:34 PM   #190
tinydb84
tinydb84's Avatar
Thanks Karl. Initially I had some problems with it but after getting a better torch it has pretty much done everything I have wanted. The peddle sucks and I will probably replace it eventually but for $700 bucks I'm not going to complain.
David
Instagram: myfabguy
Old 01-23-2016, 06:02 PM   #191
tinydb84
tinydb84's Avatar
Capped the ends and tied them into the tabs:
Welding a bunch of transitions together
Pretty happy with how it came out
Probably going to cut out a half circle out of the boxing plate for looks. I'll start on the top mounts this weekend.
David
Instagram: myfabguy
Old 01-23-2016, 06:22 PM   #192
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: Used Parts Build
looks awesome dude keep it up
TrailerTrash is offline   Reply With Quote
Old 01-24-2016, 03:31 AM   #193
tinydb84
tinydb84's Avatar
Thanks Trailer.
Finished my link mounts. I wanted to tig weld the whole thing. Figured it would look better and give me more practice. Well 82 welds later....
Upper tabs on. Gusset designing:
Backside welded in:
Welding forever:
Frontside welded in:
Welding the fishplates on:
Done!
David
Instagram: myfabguy
Old 01-27-2016, 12:55 PM   #194
tinydb84
tinydb84's Avatar
Got the other bedside cut down and prepped for welding
David
Instagram: myfabguy
Old 01-30-2016, 01:48 AM   #195
tinydb84
tinydb84's Avatar
Spent some more time on the bed.
Ground down the weld on the bed floor
Rattle can primer to keep it from rusting
Welded up the second bedside
Cool little weld shot. Did a weave to fill a gap that was a bit to big on the bed
David
Instagram: myfabguy
Old 02-01-2016, 02:47 AM   #196
tinydb84
tinydb84's Avatar
Started working on my notch/used parts backhalf... I originally made my notch to lay out with the long bed taking into account the frame kicking up over the axle. So now my notches were too short. You can see what I am planning on doing below.
Leveling everything out
Removing all the crap from the frame and welding in some crossmembers
Laying it out
Cutting the frame and putting the notches in
It was windy as hell so I had to barricade myself in
Always gotta include a weld shot
then it got dark...
Welded in!
The rest of the frame that I will reattach higher up.
David
Instagram: myfabguy
Old 02-03-2016, 02:58 AM   #197
tinydb84
tinydb84's Avatar
Spent some time tonight removing brackets and what not from the rear of the frame. Drew up a quick template and cut the frame to fit the notch. The rear is a bit too high still and the driveway makes it look a lot taller than it is.
Tossed it up there
I am off by 1/2'' measuring across the bed. Not bad for not even fitting it up yet.
I am going to probably notch the side and bend up the bottom to meet the notch so it looks cleaner.
David
Instagram: myfabguy
Old 02-03-2016, 11:04 AM   #198
slotard
Those are really long steps on the weld, I'm used to seeing more like half that... I wonder if there's any real advantage/disadvantage to it.
Since you're linked/bagged and I assume not towing much, I don't imagine the frame needs to be all that beefy behind the bag mounts.
1973 C20, 350/350
Old 02-03-2016, 01:37 PM   #199
tinydb84
tinydb84's Avatar
Not sure if I follow you. Do you mean the distance between the scallops on the weld bead? I agree, they are a bit too far apart. I moved a bit too quick with not enough wire speed. That whole area is going to have a gusset and tied into the bag mount (and some other tubes that I haven't laid out 100% yet) but I wasn't too concerned with it as it is welded on both sides and 5 other welds. There is going to be a fishplate on there too.
David
Instagram: myfabguy
Old 02-03-2016, 02:26 PM   #200
slotard
Yeah, that's what I mean. In a well designed joint, even a poor quality weld won't be the weak point (not saying that is one), so it shouldn't be a problem, just didn't know if it was on purpose. Not sure I've ever seen a test comparing that to tighter spacing.
1973 C20, 350/350
