Old 11-22-2015, 01:21 AM   #176
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Spent a couple of hours in the blast cabinet on my hinges, a bit of paint and brand new. Upgrading the wiring to add a new panel. My dash didn't fair so well in the southern heat, recovering that and the door panels in black and adding black visors. Taking some blue out, add more black and silver.
Metaldoc is offline   Reply With Quote
Old 12-04-2015, 03:35 PM   #177
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Been down with migraines again, on average now 5 to 7 a day so not much happening in the shop. I'm going to a new doc. in the new year to see about an electrical implant to try and stop them. Damn headaches are messing up my shop time. I did find the rest of my wiring and it doesn't look to bad. It's hard to concentrate on detailed stuff with a headache. I just keep going and push on, I want a driver not a project waiting to be driven. How can you tell I've a couple of crappy weeks.
Old 12-04-2015, 06:35 PM   #178
Advanced Design
Advanced Design's Avatar
Re: 67 long box
Sorry to hear about your headaches! Wiring would be very tough to do with a migrane.
Hopefully the new Doc will help.
Advanced Design is offline   Reply With Quote
Old 12-24-2015, 02:30 PM   #179
Metaldoc
Metaldoc's Avatar
Re: 67 long box
A Merry Christmas to all my fellow builders and may Santa bring ya some new toys or parts for the build.
HO HO HO Derek.
Old 01-04-2016, 07:52 AM   #180
cleanfreak
cleanfreak's Avatar
Re: 67 long box
Just went thru the build quickly , very nice! I have a friend out your way , wanting some rocker work done on a real nice 68 swb , any interest in a little side work?
cleanfreak is offline   Reply With Quote
Old 01-04-2016, 10:13 PM   #181
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks I try not to take on other work due to health problems, but I'd be willing to talk to him or work him through the job. My shop isn't big enough to hold another truck either. Some times the rocker repair can be more involved than what's seen on the outside.
Derek
Old 01-04-2016, 11:17 PM   #182
cleanfreak
cleanfreak's Avatar
Re: 67 long box
Derek
No problem , thought I would ask. He has asked me , just a little to busy with my own fleet, and it's hard to find metal work of your quality up here.
Old 01-05-2016, 11:57 PM   #183
Metaldoc
Metaldoc's Avatar
Re: 67 long box
back at the wiring after a month sick, got the new used fuse block to add in. Did the headlight relays, alternator switch to internal, HEI wired, added another 10ga wire from the battery to more interior power. nice box of spare wire going on from old projects.
Old 01-17-2016, 12:35 AM   #184
Metaldoc
Metaldoc's Avatar
Re: 67 long box
adding in some wires, taming the hood seal to fit, I can't believe the change it's under gone
Old 01-17-2016, 07:26 PM   #185
mooseknuckles
mooseknuckles's Avatar
Re: 67 long box
looks nice!
mooseknuckles is offline   Reply With Quote
Old 01-18-2016, 09:10 PM   #186
Metaldoc
Metaldoc's Avatar
Re: 67 long box
repurposed the voltage reg. to a breaker holder. weather proof and looks stock. This will replace the fuseable links from the starter.
Old 01-18-2016, 10:04 PM   #187
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I tucked the wires across the floor edge and into it.
Old 01-19-2016, 02:07 PM   #188
Metaldoc
Metaldoc's Avatar
Re: 67 long box
found bulkheads for the washer hoses to move them off the firewall. Model airplane fuel tank fittings.
Old 01-19-2016, 06:05 PM   #189
Sicksty8
Sicksty8's Avatar
Re: 67 long box
That's a great idea with rc fittings! I wanted to clean up the routing as well. It's just weird that gm routed it so messy from the factory.
Sicksty8 is offline   Reply With Quote
Old 01-19-2016, 09:40 PM   #190
Metaldoc
Metaldoc's Avatar
Re: 67 long box
just add the newer fuse block and I'm feeling happy. Yup RC plane parts, I've taken most the clutter off the firewall.
Old 01-21-2016, 02:57 PM   #191
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Taking a break from wiring and put the washer through the cowl from the inside. Now to use the holes from the washer hoses on the firewall by adding two more holes to make 4 identical location holes to light up the engine bay. LED spot lighting. Started prepping for vintage air install to add wiring to my harness.
Old 01-21-2016, 10:53 PM   #192
Metaldoc
Metaldoc's Avatar
Re: 67 long box
almost ready to install again. too many wires, still have the alarm, electric door locks with remote open, power window wiring, stereo, usb charge ports. Now it seems like I'm just starting to wire. Sending unit came in and installed.
Old 01-21-2016, 10:59 PM   #193
Sicksty8
Sicksty8's Avatar
Re: 67 long box
Wondering where the fuseblock is from. I need one myself
Old 01-21-2016, 11:45 PM   #194
Metaldoc
Metaldoc's Avatar
Re: 67 long box
1980-87 chevy truck, van, monte, camero, most gm of those years. T
his one is 84 truck
Old 01-22-2016, 05:57 PM   #195
Metaldoc
Metaldoc's Avatar
Re: 67 long box
LED lights turned out perfect
Old 01-23-2016, 01:10 AM   #196
deejaaa1
Re: 67 long box
looking good.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 01-25-2016, 06:15 PM   #197
Metaldoc
Metaldoc's Avatar
Re: 67 long box
power window and lock relays controlled by momentary push button switches. No rocker switches, something different. Diodes to stop reverse ground flow to relays from alarm output and button to relay trigger.
Old 01-25-2016, 10:50 PM   #198
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 67 long box
Nice work! I really like how you are repurposing the voltage regulator
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-25-2016, 11:43 PM   #199
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Originally Posted by deejaaa1 View Post
looking good.
Thanks, that reg box holds the two breakers perfect and still looks like it could have been there from factory.
Old 01-26-2016, 02:20 PM   #200
Low Elco
Re: 67 long box
Nice work- All of this electrical, I'd have thrown up and passed out by now.
Low Elco is offline   Reply With Quote
