Old 04-19-2018, 11:46 PM   #176
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Columbus..the 1957 IH 4x4..
thanks Doug. ...very busy...just doesn't seem like anything is getting accomplished.
...when I got the bed reblasted I told them not to blast the underside because i had lizard skinned it. ...from the previous blast when I had (wrong) primed the bed and then sprayed the underside with lizardskin....and at the time I talked to lizardskin and they said it should be ok...in the meantime the bed has been on sawhorses in my buddies shop and i havnt seen the underside in good light...
after I got the bed back from the blaster and on the rotisserie and flipped over out in the sunlight I am now seeing rust coming thru the lizardskin...its been indoors and has had no direct water contact other than maybe some humidity...so now i think its going back to the blaster to do the underside......seems like I can't win...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-20-2018, 06:34 AM   #177
Advanced Design
Advanced Design's Avatar
Ugh ...sorry to hear that. You’ve had more than your share for two forward and three back.
Hopefully your folks aren’t suspicious yet!
Advanced Design is offline   Reply With Quote
Old 04-20-2018, 07:04 AM   #178
mongocanfly
Post Whore
tell me about it.....I don't think they know but its hard to keep stuff hidden at my shop....ive been slipping stuff in and out so I can work on it....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-20-2018, 07:32 PM   #179
BlueJeep
BlueJeep's Avatar
Originally Posted by mongocanfly View Post
well its time for a small update....got most all the body work done on the front fenders, hood, grill.....ready for high build....got the bed tailgate and rear fenders back to the blaster today...they'll be getting epoxy tomorrow. ....
the ol brown truck been on a regular schedule as of late....got the nv4500 last thursday,,, along with all the connect point A to point B goodies from AA......as well as the new wheels from us mag.... (black stock rims).....they only come in black...I was wanting white. ...will have to see if the black grows on me or not
Those tires and wheels are going to look great on the old binder! I think black was the original color IH used on the wheels.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 04-20-2018, 08:16 PM   #180
mongocanfly
Post Whore
thanks blue....the original color for the wheels was white on one truck and red on the other...
I read somewhere that the rims were painted the predominant color on the truck...
I'm still torn over leaving em black. .or pc em white and ad hubcaps...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-21-2018, 03:01 PM   #181
jjzepplin
jjzepplin's Avatar
This thing is going to be amazing. I can't wait. Seems I have put my projects on hold to watch your come along. HAHA!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-21-2018, 03:27 PM   #182
mongocanfly
Post Whore
thanks Zepp....don't wait on me though...if I keep going backwards ill have the thing tore all the way down to nothing but a pile of bolts....seems like I can't get anything to go my way sometimes....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-21-2018, 03:29 PM   #183
mongocanfly
Post Whore
got all my new glass in as well...hope it all fits.....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-22-2018, 03:20 AM   #184
mongocanfly
Post Whore
well I made another late night run and brought the frame/cab to my shop for disassembly...hour and half later and it was ready to go back into hiding...with cab removed
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-22-2018, 08:41 AM   #185
Advanced Design
That was fast cab removal!
Old 04-22-2018, 09:58 AM   #186
mongocanfly
Post Whore
yeah ....the 2 post lift sure makes things like this alot easier...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-22-2018, 07:15 PM   #187
mongocanfly
Post Whore
busy stripping down the frame this afternoon. ..thought I'd share this ...I knew this was there but never could get a good pic of it....
hows about a 4x4 ,in and out ,indicator switch...and in the late 50s...its a simple lever switch hooked to the 4wd shift lever...and yes there is a light on the dash...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-22-2018, 07:19 PM   #188
mongocanfly
Post Whore
also this curiosity. .wood blocks drove into the frame...right over the rear axle....both trucks have these blocks...I don't know if its a factory thing or a old farmers trick but odd that both trucks have them....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-25-2018, 04:36 PM   #189
mongocanfly
Post Whore
getting ready to mock up the mounts for the power steering box and thought I'd go ahead and reinforce the frame rails...for some unknown reason they narrowed the frame rails down to 1in wide on the top side over the axle and right where the motor mounts will be....
some 1/4×2 flat bar did the trick once I hammered it around to fit the frame contour.....
now I got to figure how to mount the steering box.....the IH frame is 7in wider than the gearbox donor frame...so itll need recessed into the frame a little.....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-27-2018, 08:58 PM   #190
mongocanfly
Post Whore
carried the frame and all the attached brackets to the blasters today...so while I'm waiting on that I worked on project mini-me....got the body sandblasted and primed...even had to do some "mini" body work on the cab...also shortened the bed...and in my sleep deprived mind i cut the rear bed section on the wrong mark so its 1/4" shorter than I meant...if it looks to bad short ill just get another bed and redo it...still have to shorten the frame...then it'll go to (mini paint jail)...haha
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-01-2018, 04:09 PM   #191
mongocanfly
Post Whore
got the frame and all the dodads back this morning from the blasters...and got it in epoxy....
will get a few coats of paint tomorrow. ...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-01-2018, 06:46 PM   #192
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Really liking this build!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-01-2018, 08:03 PM   #193
mongocanfly
Post Whore
thanks Clyde...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-01-2018, 08:33 PM   #194
Advanced Design
Clean and primed parts are always exciting...looks good.
Don’t know if your folks can see your shop from their place. If they can, I keep imagining the following...Mom looking out kitchen window toward your shop in the late evening. Says to your Dad...”Honey, do you have any idea why Greg is sneaking parts in and out at all hours? What is he up to anyway?”
This is a very nice thing you are doing for them.
Old 05-01-2018, 09:08 PM   #195
mongocanfly
Post Whore
thanks Doug..
yeah this sneaking stuff around is part of the fun of this truck build...they live 1/4 mile down the rd from me and off on a dead end rd...we cant see each other for all the trees..[thankfully]..and my place is 250yrds off the rd with a lot of trees between me and the rd....
I did the frame behind my shop so they couldn't see it if they drove by...and I had my truck hid so they wouldn't know I was there..
ive got so much stuff torn apart around my place im not sure theyd know what the frame was for if they did see it..all the body is at my buddys shop..
it was funny last week, when I left with the frame...dad was mowing the peoples yard across the rd from my driveway...I went sneaking up to the rd and waited til he was going away from me and I took off...he never saw me...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-01-2018, 09:38 PM   #196
72 tigger
72 tigger's Avatar
Looking great! Thanks for the updates
72 tigger is offline   Reply With Quote
Old 05-01-2018, 10:35 PM   #197
mongocanfly
Post Whore
thanks tigger
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-02-2018, 03:13 PM   #198
mongocanfly
Post Whore
and now we finally got some color going on...sprayed all misc parts and frame today with semi gloss black...now it looks like some progress going on...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-02-2018, 06:17 PM   #199
Clyde65
Clyde65's Avatar
Your dad is gonna freak! Wish I could do this for my dad...
Clyde65
Rebuild of Clyde
support our troops!
Old 05-02-2018, 08:18 PM   #200
mongocanfly
Post Whore
fingers crossed Clyde....fingers crossed
Mongo...aka Greg
RIP Dad
RIP Jesse
