Old 08-11-2012, 10:26 PM   #201
Brandon_70
Re: How about some pics of Static Dropped C-10's
6/7 on 20's
Brandon_70 is offline   Reply With Quote
Old 08-12-2012, 01:20 AM   #202
jlsanborn
jlsanborn's Avatar
Killer! Gonna add a marker light in the bedside? Throw up some more pics!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 08-12-2012, 11:11 PM   #203
Brandon_70
Thanks, actually going to shave the front markers too just haven't had a chance to do much work to it lately
Old 08-17-2012, 12:41 PM   #204
made2drag
made2drag's Avatar
thats a sweet ride!
made2drag is offline   Reply With Quote
Old 08-17-2012, 09:39 PM   #205
1971sierragrande
1971sierragrande's Avatar
Brandon that is AWESOME truck. love the stance.
1971sierragrande is offline   Reply With Quote
Old 08-17-2012, 10:57 PM   #206
Brandon_70
Thank you for all the compliments. Work in progress, hoping to bag it one of these days
Old 08-19-2012, 03:36 PM   #207
Big Block 454
Big Block 454's Avatar
Cool. No airbag hassles. So, 5" springs and 2" blocks rear? And how 'bout the front?
Big Block 454 is offline   Reply With Quote
Old 08-19-2012, 06:11 PM   #208
Brandon_70
The rear is actually a leaf spring set up instead of coils. So there is a flip kit in back with shackles. Front is 3" spindles and springs. I just ordered the ac system so I'm saving up for the bag setup now.
Old 08-21-2012, 11:14 PM   #209
gjones138
Originally Posted by droppedgmc View Post
pics of my old 68'...i'll get her back one day
4.5"/ 7"
20x8.5"/ 20x10"
255/40/20 295/40/20
Is this just Hugger Orange or something else? I love the look of your truck!!
gjones138 is offline   Reply With Quote
Old 08-23-2012, 12:12 AM   #210
69SCSS
69SCSS's Avatar
At what point do you have to notch the back? I was gonna go for a 3/5 but I didn't want to have to notch it. Looks like it will hit the bump stop before the rail, but only 1/2" difference?
Just got my '69 and it needs all new springs and shocks... figure I'll set it up right from the beginning.
69SCSS is offline   Reply With Quote
Old 08-23-2012, 01:52 AM   #211
mongoose
mongoose's Avatar
still can't leave the driveway.. so kinda sucks for taking pics but i do what i can!
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 08-23-2012, 07:33 AM   #212
gringoloco
A guy with a truck
gringoloco's Avatar
Cool picture! Nice ride height, too...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-23-2012, 04:18 PM   #213
Brandon_70
I think with a 5" drop u won't have to notch the frame. Mine has about a 2 1/2" notch with a 7" drop and I never bottom out
Old 08-23-2012, 04:45 PM   #214
gringoloco
A guy with a truck
gringoloco's Avatar
5" is safe for no notch, 6" is about 50/50- some people have no issues, others are not so lucky...
-Chris
Old 08-23-2012, 05:04 PM   #215
Jarwood
Jarwood's Avatar
I have a 5 inch in rear and do bottom out sometimes if I have a few hundred pounds in the bed....
Jarwood is offline   Reply With Quote
Old 08-23-2012, 05:22 PM   #216
Brandon_70
I do not carry a load in mine but if I did I'm sure it would bottom out as well.
Old 08-23-2012, 05:54 PM   #217
69SCSS
69SCSS's Avatar
Sounds good, was gonna order 5" drop springs for the rear and I won't be carrying large loads... maybe a couple hundred pounds at most. I may go for helper bags if I wind up towing with it. Thanks!
Old 08-28-2012, 06:32 PM   #218
454C10CHEVY
454C10CHEVY's Avatar
hey guys so im in the process of droppin my big block in. i just baught the front disk brake conversion for it with drop spindles and want to lower it more. i was thinking a 4.5/6 im going to be running 22x9.5 with 5.5b/s that got donated. is that a good drop that wont have many issues with rubbing or what would you recommend ??? what would be the best way to lower the rear?
454C10CHEVY is offline   Reply With Quote
Old 09-01-2012, 04:54 PM   #219
1978steven
1978steven's Avatar
Originally Posted by BlueEK9 View Post
Here's a few with the 20's on it.
Love the stance, if you don't mind what are the drop specs?
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 09-02-2012, 12:18 AM   #220
jlsanborn
jlsanborn's Avatar
That big window '67 is the coolest truck on this site. I liked it better with the ralley wheels, but it is still bad a$$!
Old 09-03-2012, 05:21 PM   #221
1971sierragrande
x2!!!!!! on the 67'
Old 09-16-2012, 10:30 AM   #222
chevyrestoguy
chevyrestoguy's Avatar
Here's my '64:
Front: '79 Suburban front suspension, Bell Tech spindles, 1 coil removed. Lower control arms moved forward 3/4" to gain additional caster, 1-ton sway bar
Rear: Narrowed 12-bolt ('79 Suburban unit, narrowed a total of 4"), CPP 5" drop springs, ECE Super Track Bar, shock relocators, flipped front trailing arm mounts, 5-way adjustable shocks.
Wheels/tires: '60s vintage E.T. Supers, restored to original. The fronts are 15x6, the rears are 15x8.5 with a 3.0" backspace. The center caps are original, new oval ET Super caps (hard to find). The front tires are BFG 215/60-15 (to be changed to 225/60-15), and the rears are BFG Long Trail T/a Touring in 265/70-15.
These pictures are about three weeks old. It's currently undergoing surgery to gain additional ground clearance and to center the front wheels in the openings. Also, many of the dents have been removed and the fuel door access panels have been filled. The original patina is being saved, and we'll blend the paint on the repaired areas and distress it to look original.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-16-2012, 10:45 AM   #223
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by chevyrestoguy View Post
Here's my '64:
SUPER COOL truck.
Great attention to detail and the wheel choice is perfect.
Thanks for the detailed suspension drop.
Today we are seeing more and more people throw on just a set of drop springs and complain because it rides like sh#t.
You are definitely "doing it right", the first time.
Love it.
Keith
Convert to disc brakes.
Old 09-16-2012, 10:52 AM   #224
502ms
502ms's Avatar
Great looking trucks guys! Brandon - love the stance! You will love it when you bag it, though! #speakingfromexperience.
1978steven, love your truck...got some of that on my instagram (same name @502ms)
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 09-16-2012, 04:46 PM   #225
chevyrestoguy
SUPER COOL truck.
Love it.
Thank you for the kind words, Keith. I've been a real fan of your stuff for a long time, and used your disc brake link as guide when I did my swap. I've always been a person who likes them low, but they HAVE to ride good. The difference between a truck with a crappy ride and one with a nice ride is sometimes just a shock or spring choice away. Some guys don't get it, and won't listen to advice.
I will be posting more stuff on my '64 link very soon. The last 2 weeks on that truck have been super-busy, and a lot of stuff got done. Ironically, it was pretty timely, considering all of the recent activity on the site concerning ground clearance on lowered trucks. I just want to wait until I get the chassis paint touched up before I start posting.
My build threads:
