Old 11-02-2014, 06:25 PM   #201
Advanced Design
Advanced Design's Avatar
Re: Loadmaster '47 COE
That was an early start! Truck looks good sitting like that.
Advanced Design is offline   Reply With Quote
Old 11-02-2014, 07:52 PM   #202
mud.man.rj
mud.man.rj's Avatar
The 47 is coming together real nice, glad also on the camera thing..
mud.man.rj is offline   Reply With Quote
Old 11-04-2014, 09:50 PM   #203
47 Fasttoys
47 Fasttoys's Avatar
OK, so I'm a little off track here but I stopped by a salvage yard Monday and picked a 60/40 bench seat from a '90 Chevy truck. I did a test fit and I think it will work fine if I set it up as a 40/60 meaning the long side on the driver side. I will also try and make it tilt at the front for engine access.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 11-04-2014, 11:31 PM   #204
99 to Life
99 to Life's Avatar
Gotta love chevy for that interchange aspect throughout all the years. I always go with late model benches for the fact of folding them down and utilizing behind the seat.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 11-04-2014, 11:46 PM   #205
Advanced Design
They do look right at home there.
Old 11-07-2014, 09:53 PM   #206
47 Fasttoys
I've been playing with the tranny mount. I think the idea will work but the plates that will be welded to the cross member are an odd shape and are talking a bit of time to figure out. To give that a little time to simmer I've also been building a tilting frame for the seat. When the 2 frames are complete the lower 1 will be welded to the original seat riser. Also you can see the supports are unevenly spaced. They are lined up the the modified slider system on the seats. When all the supports and side panels (under the seat) are welded in a large section of the floor will be removed for front engine access.
My '47 C.O.E build
Old 11-09-2014, 10:44 PM   #207
47 Fasttoys
A little more progress on the seat mount. Both modified seat tracks are welded to a sub-frame, that frame is attached to a lower frame via a piano hinge so it tilts at the front giving access at the engine. Both seats fully adjust fore and aft. I also put the '03 bed back on (needed the shop space) it gives you an idea just how much difference there is in a COE cab and an extended cab. How I will have a Silverado chassis with the looooong bed option
Rob
My '47 C.O.E build
Old 11-09-2014, 11:06 PM   #208
99 to Life
99 to Life's Avatar
diggin the seat. thats a nice bed, wish I had it! Love the back shot of the whole truck, really paints the picture on what you can do with it.
Old 11-09-2014, 11:29 PM   #209
Kim57
Kim57's Avatar
The seat came out real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-10-2014, 09:29 AM   #210
Advanced Design
Looks good. Will the steering column and wheel cause interference with the seat tilt?
Old 11-10-2014, 06:42 PM   #211
47 Fasttoys
Not sure about the steering issue yet AD. I will try and modify the tilt function on the 60 seat to make it like the 40 which folds flat. 99 if you really need a late model bed, I really need enough steel to build a 12 foot flatbed. I also have the complete extended cab body in great shape.
Rob
My '47 C.O.E build
Old 11-16-2014, 10:59 PM   #212
47 Fasttoys
Just about done with the seat frame. After adding some boxing plates I removed the center section for front engine access, I also modified the drivers seat (60% side) so it now folds flat. I started on the gas pedal mod. The donor has drive by wire and I really don't care for the looks of the pedal assembly so I'm building a box that houses the modified donor pedal on the outside of the fire wall. Now the stock pedal pushes the push rod which in turn pushes the DBW pedal.
My '47 C.O.E build
Old 11-17-2014, 12:02 AM   #213
99 to Life
99 to Life's Avatar
very nice
Old 11-22-2014, 07:25 PM   #214
47 Fasttoys
90% finished with the pedal project. I test mounted a steering column a friend gave me, I think it may be from a early Ford truck or Bronco. It has a 14" wheel and works well for seat clearance issues. I used the stock column location on the floor but moved it about 1" closer to the dash, still seems to work well for feel when seated. I also did a test fit of the master cylinder and booster, it's tight as far as the prop rod and hood support are concerned. I will need to build some kind of a lever system to operate the brakes. You can see I will need to shorten the column a few inches and rotate the rack mounts to allow for steering hook up. Like always, more challenges.
My '47 C.O.E build
Old 11-22-2014, 09:02 PM   #215
mud.man.rj
mud.man.rj's Avatar
One big challenge in general but your doing a great job.
Old 11-22-2014, 10:50 PM   #216
99 to Life
99 to Life's Avatar
nice progress, what is the reason the booster isn't straight on the FW or under the cab, seems like the off frame distance would allow room for it. always challenges. Something fights me hard just about every time I work on my stuff.
Old 11-23-2014, 08:57 AM   #217
47 Fasttoys
Thanks mud, good question 99. Straight on the fire wall doesn't work for 2 reasons: support rod in the way (easy fix) assembly to long by about 2 inches. Under the floor? I've had master cylinders under the floor before and I don't like not seeing the fluid level at a glance and maintenance is a pain. Not sure if I will still have room under the floor after the radiator is in.
Rob
My '47 C.O.E build
Old 11-23-2014, 09:28 AM   #218
T Hilde
I had a '74 Dodge van that had the master cylinder mounted that way. Looked and worked good.
T Hilde is offline   Reply With Quote
Old 11-23-2014, 10:39 AM   #219
47 Fasttoys
Yea, I've seen the Dodges done that way. I've been looking for one but have had no luck. I would like some measurements from the pivot area if anyone has one.
Rob
My '47 C.O.E build
Old 11-23-2014, 02:40 PM   #220
99 to Life
99 to Life's Avatar
yeah Im not a fan of under cab MC's either, I'v seen the 90* ones under dashes which looks like a cluster.
Old 11-26-2014, 09:40 PM   #221
47 Fasttoys
Made some good progress on the brake system today. fabbed up the booster and MC mount, mounted the pedal, and got a good start on the linkage.
Rob
My '47 C.O.E build
Old 11-27-2014, 03:23 PM   #222
99 to Life
99 to Life's Avatar
nice progress
Old 11-29-2014, 10:37 PM   #223
47 Fasttoys
A little more progress. Stopped for a local shop, great guy. Asked if he had any old ADs for parts. As a matter of fact he did, like 9 or 10 of them. Picked up a column with a descent wheel and a stainless inner window piece for $50. Yea, I'll be seeing him again. Anyway, I got the brake fab work sorted out for the MC and booster, also cut down the column and added a bearing. Need to start working on rotating the rack and pinion unit and then steering hook up.
Rob
My '47 C.O.E build
Old 11-30-2014, 12:10 AM   #224
chev3600
chev3600's Avatar
So awesome, you've got to be proud of this project! Great ingenuity.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 11-30-2014, 12:30 AM   #225
99 to Life
99 to Life's Avatar
ur making quick work of that. great score on the column, those horn buttons are 45 repop and the inner window trim for the door is 85 for non stainless so you scored big time.
