Old 08-04-2020, 09:01 AM   #201
88Stanger
88Stanger's Avatar
Re: Forest's rebuild thread
Awesome job!!!
88Stanger is offline   Reply With Quote
Old 08-04-2020, 11:53 AM   #202
forestb
forestb's Avatar
Originally Posted by 88Stanger View Post
Awesome job!!!
Originally Posted by Moscowmule View Post
Man that is looking good
forestb is offline   Reply With Quote
Old 08-29-2020, 06:55 PM   #203
forestb
forestb's Avatar
Got my wheels sorted out. The only step I have left cosmetically is to get my headliner back up.
I only wish my paint was holding up.
Old 08-29-2020, 07:00 PM   #204
roll_the_dice
roll_the_dice's Avatar
I really like the push through caps with beauty rings and the chrome bumper on your truck.
roll_the_dice is offline   Reply With Quote
Old 08-29-2020, 07:11 PM   #205
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I've been so distracted lately, I hadn't checked in on your truck for awhile. Very nice!
66 C20 Service Truck:
Old 08-29-2020, 07:36 PM   #206
forestb
forestb's Avatar
Thank you both
Old 08-30-2020, 07:54 PM   #207
forestb
forestb's Avatar
I did a little corner carving in the mountains today and took a couple of photos.
Old 08-31-2020, 10:46 AM   #208
pdxhall
pdxhall's Avatar
your truck looks great.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 09-12-2020, 05:09 PM   #209
forestb
forestb's Avatar
Reinstalled my headliner for the first time sense last year with some VHB Velcro. Thanks jweb.
Old 09-12-2020, 08:23 PM   #210
cwcarpenter98
cwcarpenter98's Avatar
That looks great! It does a really good job of breaking up the white roof
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-19-2020, 04:22 PM   #211
forestb
forestb's Avatar
So I pulled the trigger. Literally the drill trigger. I have been trying to figure out how to best install my belt line fuzzies. I removed the clips and cut about an inch off of the curved part and started drilling Holes through the fuzzies and into the window opening and screwed some vary small screws and it worked. The passenger side works just as I would like. The driver side is almost as good. When the window is all the way up it pushes out the outside door skin a little bit. I think I still need to take the window out and readjust how it sits in the channel. Window down and window up. It scared me to death to try this because I didn’t want to mess up the paint. But I laid down enough layers of tape to protect the paint when the drill ran into it.
Old 09-19-2020, 04:33 PM   #212
forestb
forestb's Avatar
In other news someone almost plowed into the passenger side of my bed. I was making a left from a main street with no stop sign and he was making a left from the street I was turning onto which had a stop sign. It was one of those instances where as I passed in front of him and lost sight of him I was sure that we would make contact but we did not. I don’t know how we didn’t. Praise God.
Old 09-19-2020, 04:51 PM   #213
LostMy65
LostMy65's Avatar
Totalled stepside bed = insurance money = new fleetside bed.
Old 09-19-2020, 05:07 PM   #214
forestb
forestb's Avatar
That’s funny because I did think of that
Old 09-19-2020, 08:16 PM   #215
The Rocknrod
Moderator
The Rocknrod's Avatar
Well, glad it didnt happen myself. I like your truck.
Old 12-05-2020, 10:25 PM   #216
forestb
forestb's Avatar
I took the truck to the dyno yesterday. I went to Westech were they film Engine Masters. I even got to meet Steve Brule. They changed out my secondary metering rods to get a good mixture and they also messed with the transmission cable that connects to the throttle. Because he messed with that cable I took it to the transmission builder to make sure he didn’t mess that up. All and all I am happy with the experience but it was fairly expensive and now I have a bunch of extra Q-jet parts. I took video but it looks exactly the same as the photo except the wheels are spinning. He took it up to around 4250 rpm. He would have gone faster but the rear end started shaking like crazy. I think I need to fix the pinion angle. 197 hp at 4493 rpm and 246 ft pounds at 3710 rpm.
Old 12-05-2020, 10:38 PM   #217
forestb
forestb's Avatar
Also I was trying to figure out how much larger I would need to have the size of my window increased if was going to have a new one made and I think that the window I took out of the truck is slightly taller than the new one that I installed. It’s really hard to tell with the window installed.
Old 02-06-2021, 07:10 PM   #218
forestb
forestb's Avatar
I yanked out my kick penal speakers that I was vary happy with. The reason I had to do so was because I blocked off my vents the air pressure inside the cab when I shut my doors caused the bondo and paint in my roof to crack. Real bummer but I don’t want my paint cracking
Old 02-06-2021, 07:13 PM   #219
The Rocknrod
Moderator
That's a great pic on the dyno, looks cool.
Old 02-06-2021, 08:17 PM   #220
forestb
forestb's Avatar
thanks
Old 01-19-2022, 10:59 PM   #221
forestb
forestb's Avatar
It’s been a while sense I have posted on here. I had my exhaust rerouted today. I got tired of having my loud and smelly exhaust right outside my window in front of the rear tire. I wanted it to exit behind the bed. Because it is a 62 and has a under the bed gas tank it would have been vary difficult to have it go up and over the rear axle. So instead it was routed up and over my back tire and dump out behind the tire. I am not sure if I am happy. It has a little bit more of a drone than I like. It will take a little getting used to. Also you can see the pipe a little bit inside the fender so I might end up painting it black to hide it better. They also added an H cross over pipe.
Old 05-26-2022, 02:23 PM   #222
forestb
forestb's Avatar
My engine is toast
At least my heads are
My bottom end I have had for 22 years and who knows what the PO did to that.
So I think it is new engine time
Old 05-27-2022, 12:49 PM   #223
LostMy65
LostMy65's Avatar
Up and over the tire, or up and over the rear axle between the rear tire and frame?
How about something like this?:
http://67-72chevytrucks.com/vboard/s...05#post1948905
Old 05-27-2022, 12:50 PM   #224
LostMy65
LostMy65's Avatar
My engine is toast
What are you thinking of going with?
Old 05-27-2022, 01:04 PM   #225
forestb
forestb's Avatar
Up and over the tire. Between the tire and the fender.
