#2226 |
Grandpa in the rustmobile...
Re: The Blue Goose
Ok
It fits the block timing chain cover area good, but the oil pan is too big or something for it..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#2227 |
Junk Yartist
Re: The Blue Goose
maybe the wrong pan... there are several different pans. ones for left side dipstick, ones for right side dipstick, pre 86, post 87...
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#2228 |
Re: The Blue Goose
There are two different gaskets depending on the radius of the curved portion of the oil pan under the timing cover: thin 2 1/4", and thick 2 3/8". That could be it.
http://67-72chevytrucks.com/vboard/s...84&postcount=4 Other than that, the gasket surfaces must be clean as a whistle and flat. If it is a Felpro kit, read the instructions thoroughly. Torque all the bolts with a torque wrench. It's a long and tedious job if you are crawling underneath.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 Last edited by bollybib; 01-16-2012 at 01:56 AM. |
#2229 |
Re: The Blue Goose
Thanks guys...
I got the wrong gasket like jim said Ok, nother one for yall... The oil pan is dimpled between the bolt holes (facoty or some sort or another? Should I try to straigthen them? Do you think autozone will let me return the gasket they gave me (wrong one)..
#2230 |
Re: The Blue Goose
The sections between the holes are part of the sheet metal stamping and should be left as is. The area surrounding each hole is usually distorted from overtightening the bolts, so these should be carefully hammered back flat again. Check the flanges with a good straightedge, they should be flat front to back and side to side.
Can't say about the return. In most cases, once a gasket package seal is broken, they are yours forever. Won't hurt to try to return it, sometimes those guys have a heart. Good luck.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#2231 | |
Re: The Blue Goose
This [pan] is like mine. ![]()
project: "my happy mess" Last edited by litew8; 01-16-2012 at 02:01 AM. |
#2232 |
Re: The Blue Goose
Ok, I got the 10T this AM. My pan only has 1 spot for the dipstick NOT DUAL DIPSTICKS
So will the 10T gasket work?!?!
#2233 |
Junk Yartist
Re: The Blue Goose
pull your pan, take a pic of the bottom of the engine, and the pan.
#2234 |
Re: The Blue Goose
I'd recommend sticking with rubber/one piece if you can.
Maybe this is the one you need - summitracing ![]()
project: "my happy mess" |
#2235 | |
Re: The Blue Goose
Says it's for "marine" engines Keith.
The 10T is correct for two side provisioned dipstick blocks/pans. He needs the one side only, if I'm understanding correctly. Quote:
#2236 |
Re: The Blue Goose
If you measured your pan and found that it takes a "thick" gasket, the one you have should be ok.
I assume you mean by "10T" that you have this gasket ----> http://www.summitracing.com/parts/FEL-OS34510T/
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 Last edited by bollybib; 01-16-2012 at 09:46 PM. |
#2237 |
Re: The Blue Goose
#2238 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: The Blue Goose
Your pan has the Left Hand dipstick (only).
#2239 | |
Re: The Blue Goose
I mis read your post as "his".
#2240 |
Re: The Blue Goose
np, Keith
![]() If you only have the one side dipstick pan John, personally, I wouldn't use the 10T. Check post 2236 (thick) or OS34509T (thin). . Am I the only one that dislikes the "driver's side" dipstick location? ![]()
project: "my happy mess" Last edited by litew8; 01-16-2012 at 10:08 PM. |
#2241 | |
Re: The Blue Goose
He needs the driver's side version (LH).
#2242 |
Re: The Blue Goose
What do you recommend?
#2243 |
Re: The Blue Goose
Thick front seal. Driver's side (LH) dipstick:
http://www.summitracing.com/parts/FE...n/?prefilter=1 Thin front seal. Driver's side (LH) dipstick: http://www.summitracing.com/parts/FE...n/?prefilter=1
#2244 |
Re: The Blue Goose
My mistake on the 10T, the Summit pic wasnt clear to me. Maybe Felpro doesnt make the kit in the thick version ?
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 Last edited by bollybib; 01-16-2012 at 10:27 PM. |
#2245 |
Re: The Blue Goose
project: "my happy mess" Last edited by litew8; 01-16-2012 at 10:32 PM. |
#2246 | |
Re: The Blue Goose
Then yes, Keith's links (post 2243) are correct. You need to determine if you need "thin" or "thick" John. Check RockAuto for better prices.
project: "my happy mess" Last edited by litew8; 01-16-2012 at 10:39 PM. |
#2247 |
Re: The Blue Goose
What year is your engine John?
What is your measurement in the pic above that Jim suggested? Is it 2 3/8? Looks more than 2 1/4. If yes, go with "thick".
project: "my happy mess" Last edited by litew8; 01-16-2012 at 11:01 PM. |
#2248 |
Re: The Blue Goose
The 10T is on the truck, drove it home, few small drips probably from the 09 it soaked the frame..
I'll keep you guys posted, hopefully its just excess from the frame dripping off, IDK i'll purple power it and hot water pressure wash it wednesday or so.. Looking for the flat inspection cover for a manual trans (3spd) thanks
#2249 |
Re: The Blue Goose
I needed thick front, with driver dipstick, but could only get thick front seal with BOTH? dipstick spots..
#2250 |
Re: The Blue Goose
Where do you think the drips are coming from? The passenger's side?
You're Autozone doesn't carry (or can get) the one Keith posted? I don't like auto part stores much. ![]()
