Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-16-2018, 06:10 PM   #1
plowro8
Paint spray gun
So I am thinking about trying my hand at some painting and was looking for recommendations on a good, affordable sprayer that gets good results when properly used. Appreciate your thoughts.
plowro8 is offline   Reply With Quote
Old 08-16-2018, 06:49 PM   #2
notsolo
notsolo's Avatar
Re: Paint spray gun
Check the search function, and paint and body section. $100. HVLP spray guns are affordable and do a decent job. A good Respirator is most important. Also plenty of good videos on YouTube to get you started.
notsolo is offline   Reply With Quote
Old 08-17-2018, 10:23 AM   #3
jbarron
Re: Paint spray gun
Check out the gunman on youtube.
The harbor freight one use to be pretty good for a cheap gun, but they have made them even cheaper now and they are not worth it. Paint is too expensive to bother with these really cheap guns.
For an all purpose gun you will need a 1.8 and 1.4 tip for primer and color, or two guns.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 08-17-2018, 11:09 AM   #4
Lanman1972
Lanman1972's Avatar
Re: Paint spray gun
https://www.summitracing.com/parts/dvr-802343/overview/
I have had good results with this package.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 08-17-2018, 12:09 PM   #5
bs46488
Re: Paint spray gun
I am a rookie painter. I have had good results with these
http://www.tcpglobal.com/TCPG7000.html#.W3bydV5KiUk
I just stained both sides of 150' of fence with a cheap purple harbor freight gun. It did the job but it went to the trash after the hours long painting job.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 08-17-2018, 01:37 PM   #6
notsolo
notsolo's Avatar
Re: Paint spray gun
The set from TCP global is what I use 90 % of the time. Epoxy primer with 1.8 tip...base coat with 1.4... keep it clean as you go.
Old 08-17-2018, 03:27 PM   #7
jfnar
Re: Paint spray gun
I use the HF cheapies for a lot of things, especially POR15 or when I'm painting tractors or putting polyurethane on wood. I don't know about the quality being less than it used to be because I bought several one time when they were on sale for $7.99 ea and I still have some. After putting something like POR15 through one I just chunk it in the garbage when I'm done. I have a "good" gun that I use on vehicles but off the top of my head I can't remember the brand. I'm an amateur so I can't tell a big difference in the quality of the finish but the good gun has a much wider pattern so I can cover a lot of area quickly; as long as my compressor can keep up.
jfnar is offline   Reply With Quote
Old 08-17-2018, 07:31 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Paint spray gun
I have the purple HF unit; it has served me well. I painted my '68 Skylark and the roof of my truck with it. I also have an old Binks (which doesn't work). It's a leftover from the '60s. A lot of vehicles were painted with it- my '64 Impala convertible, '56 Chevy 210 wagon, '82 Buick Regal and others.
~Steven
Simi Valley, CA
Old 08-18-2018, 03:07 AM   #9
RedRider
RedRider's Avatar
Re: Paint spray gun
X4 for the purple Harbor Freight gun. It’s gained quite a good reputation in the painting community, especially for $10 (with 20% off of course)
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 08-18-2018, 03:25 PM   #10
tinydb84
tinydb84's Avatar
Re: Paint spray gun
I have used the HF purple gun to shoot a ton of primer. I would give it a shot if I was doing a quick paint job but I plan on buying something a bit nice when I finally paint my truck. I have a Sharpe in my Amazon cart but haven't pulled the trigger since I don't plan on painting for quite a while.
David
Instagram: myfabguy
Old 08-18-2018, 09:31 PM   #11
plowro8
Re: Paint spray gun
I also need a compressor, but they are expensive! I found this one, and I wonder if it will work for spraying a whole truck...
https://www.amazon.com/Rolair-VT25BI...ers-reviews-20
Old 08-18-2018, 10:24 PM   #12
tinydb84
tinydb84's Avatar
Re: Paint spray gun
You need double that. Get something with 12-15 cfm.
David
Instagram: myfabguy
Old 08-19-2018, 01:33 PM   #13
Macdaddy1
Re: Paint spray gun
Tractor supply has sales on 60 gallon 5 hp compressor at $499 which is way better for painting and any body work.
Macdaddy1 is offline   Reply With Quote
Old 08-19-2018, 07:53 PM   #14
franken
Re: Paint spray gun
The OP needs to start looking into air systems, which means a decent compressor (certainly not the onr in the link), air lines, filter, dryer, and a way to cool the air. Sure, you can try to paint w/ hot wet air and often no pressure, but expect poor results.
If you're going to go down the air road, you might as well go as big as practical on the compressor--you can never have too much air. That pretty much means 80 gallons, US made pump and motor turning at 1725RPM. Best to troll craigslist for a gently used one.
franken is online now   Reply With Quote
Old 08-20-2018, 09:10 AM   #15
jfnar
Re: Paint spray gun
I painted my '64 with a small compressor but I did it in pieces, not the whole truck at once. Might not work well to paint like that with metallics or pearls but for a solid color it works fine.
Old 08-20-2018, 11:02 AM   #16
Indian113
Indian113's Avatar
Re: Paint spray gun
I don't deny having the best equipment available is great but knowing your limitations can be a benefit. Just like welding - Practice/Practice/Practice !
Indian113 is offline   Reply With Quote
Old 08-20-2018, 06:25 PM   #17
72c20customcamper
72c20customcamper's Avatar
Re: Paint spray gun
I just pulled the trigger on a tekna 703566 pro lite (see what I did there) . My Sata wasnt cutting it anymore . It is almost 35 years old so i cant complain. I use cheap harbor freight guns for primer . But for base and clear a good gun is important. Now don't get me wrong a cheap gun can do good if you plan on cutting and buffing as most diy do. But I try to get it as good as possible so I may have a nib or two but very little orange peel to contend with. But I do have access to a state of the art booth for water born paints.
Now my absolute favorite gun is my binks7 . Uses more paint and makes a cloud of spray mist but it will do a glass shine . But if your painting one or two cars a year what's an extra guart of paint.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-20-2018, 06:36 PM   #18
72c20customcamper
Re: Paint spray gun
Also the pro lite uses the TE/10 and 20 air caps. The fan jets are much smaller than the true hvlp air caps. Very important if you using a smaller compressor. Using a smaller compressor has problems in of itself. The air is hot and holds a lot of moisture. I have put a coiled hose in a 5 gallon bucket with ice water prior to the air separator and a disectant dryer on the gun when I'm doing work at home.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
