Old 09-24-2018, 02:33 PM   #1
chevyrick86
Suburban fuel neck
Does anyone know a supplier of stock suburban fuel necks for a 1968 'Burb? I know LMC and Brothers doen't carry them. The previous owner lost the key to the locking gas cap so he pried it off and ruined the fuel neck. May be cheaper to just convert to a fuel door?
Thanks in advance.
chevyrick86 is offline   Reply With Quote
Old 09-24-2018, 02:43 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Suburban fuel neck
AFAIK, it is not reproduced. I'd check around in the Suburban/Blazer parts area
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-24-2018, 07:34 PM   #3
notsolo
notsolo's Avatar
Sorry I probably don't have this either....Do you have a photo?...Any chance you could have the neck repaired? ..it's a separate piece from the fuel tank right....You might post a WTB...in the parts section.
notsolo is offline   Reply With Quote
Old 09-26-2018, 11:17 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
He can't post a "want to buy" unless he becomes a Premium member (name in blue).
LockDoc
Leon
Old 09-27-2018, 01:33 PM   #5
chevyrick86
The part number for a gas cap is the same for Suburban, Blazer, or Truck so I might purchase the fuel neck for a truck and splice the two together.
Old 09-27-2018, 02:10 PM   #6
1968k20
1968k20's Avatar
I have one just need some time to cut it out.
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 09-28-2018, 07:04 PM   #7
chevyrick86
I'll try to splice and if that doesn't work I'll weld in a fuel door off some later model and use its fuel neck.
Old 09-30-2018, 08:32 AM   #8
68 TT
Still plays with trucks
68 TT's Avatar
I would contact atvpro on the board here to get a good used one.
Randal fabricates fantastic 67-72 vintage 4-door crew cab truck cabs and uses Suburban donor vehicles for parts so he has a few select Suburban specific pieces in his parts collection that do not get used on the crew cab trucks.
Here is one of his builds
http://67-72chevytrucks.com/vboard/s...d.php?t=499490
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-02-2018, 12:42 PM   #9
chevyrick86
Thanks, I'll follow up on that lead and hopefully I'll be able to get a fuel neck.
