Old 02-09-2018, 11:34 AM   #1
indianpride77
indianpride77's Avatar
Tubular control arms
So i got a quote from cpp for my upper and lower control arms as well as drop spindles. with my discount i am look at around 1100 shipped. now is there any other company i should look at? i know ride tech but they are out of my budget.
indianpride77 is offline   Reply With Quote
Old 02-09-2018, 12:07 PM   #2
stacey_65
Re: Tubular control arms
Performance on line.com has them as well.
stacey_65 is offline   Reply With Quote
Old 02-09-2018, 12:16 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
What are you wanting to do with the control arms?
Static coil spring drop.
Bags?
Coilovers?
I remember CPP's lower arms having too small of pocket to use for air bags, if you decide that in the future.
Personally I like Porterbuilt products.
But everyone complains about the build times, (like its the last thing they need to complete their truck)
They are top quality and come ready to use in many forms:
Coil spring, coilover, bags.
Narrowed, 1" forward (to center the wheels in the wheel opening), or narrowed AND forward.
Give them a call.
www.pbfab.com
Here's a RE-7 or SS-7 Slam Specialties 2600 bag stuffed in a CPP lower a-arm,...
Keith
Convert to disc brakes.
Old 02-09-2018, 01:04 PM   #4
indianpride77
i plan on doing bags. they show that they have two different styles for the lower control arms. with or without bags.i like porterbuilt stuff too but unfortunately they are a little out of my price range
Old 02-09-2018, 01:23 PM   #5
lolife99
lolife99's Avatar
Here's a good thread to read:
http://67-72chevytrucks.com/vboard/s...d.php?t=431083
In my opinion you need a 2600 bag up front. (7" diameter)
Keith
Old 02-09-2018, 01:28 PM   #6
lolife99
lolife99's Avatar
Porterbuilt or Ridetech would be my choices.
I would static drop it or use stock a-arms to bag it until you get the money for quality a-arms.
Keith
Old 02-09-2018, 05:54 PM   #7
Bloodhound
I am planning on ordering CPP uppers and lowers (for coils, stock height), are there any vendors on here selling them?
Bloodhound is offline   Reply With Quote
Old 02-09-2018, 07:19 PM   #8
68longhorn
68longhorn's Avatar
Why do you want tubular arms? Is there a huge benefit to them?
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 02-09-2018, 09:01 PM   #9
Bloodhound
For me no not a huge benefit I'm sure, other than appearance. I am doing a frame off, for for the second time, and don't see a reason to put 37 year old stamped steel arms back on my '81 C-10 when these are available.
Old 02-10-2018, 12:25 AM   #10
funkatation
Go porterbuilt. Save money in the long run buying the best.
funkatation is offline   Reply With Quote
Old 02-10-2018, 12:53 AM   #11
indianpride77
Actually been in contact with choppin block out of California. Their arms look pretty dang good.
Old 02-10-2018, 09:39 PM   #12
riz
I bought Performance Online
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 02-11-2018, 11:39 AM   #13
travlinman
Im not a fan of potrorbuilt and there issues. I would check out mmw, Michigan metal works arms are top notch or chopping block arms. Im going to use mmw arms on my c-30
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 02-11-2018, 09:21 PM   #14
indianpride77
Yeah I was talking with choppin block and they have a new kit coming out. I may just wait for that. Just means waiting longer
Old 02-14-2018, 02:13 PM   #15
Bloodhound
Are MMW arms for bags only?
Old 02-14-2018, 02:27 PM   #16
travlinman
No, there built to order for whatever application u have.
Check there Instagram they post lots of pics and generally answer any questions u may have
65 Pontiac
69 swb-sold
71 lab sold
Old 02-14-2018, 02:31 PM   #17
Bloodhound
Awesome thanks.
Old 02-14-2018, 03:27 PM   #18
RADustin
I would highly recommend against a flat plate control arm from MMWs and the like.
RADustin is offline   Reply With Quote
Old 02-14-2018, 03:52 PM   #19
travlinman
MMW build both tubular and flat plate arms, its which ever u prefer
65 Pontiac
69 swb-sold
71 lab sold
Old 02-14-2018, 05:55 PM   #20
Bloodhound
You happy with them?
Old 02-14-2018, 06:38 PM   #21
bluex
bluex's Avatar
Why is that?
bluex is offline   Reply With Quote
Old 02-15-2018, 02:37 PM   #22
riz
Very.
RIZ
81 C10 short box
82 K5 Blazer
Old 02-15-2018, 03:32 PM   #23
RADustin
Originally Posted by bluex View Post
Why is that?
I'll try to explain with enough proof to make sense but without getting too far into the engineering.
A control arm by intended use, notably a lower control arm, needs to be resistant to bending in the vehicle's primary direction of travel and direction of jounce. As a way to judge a shapes bending resistance, engineers use the second moment of inertia. The natural shape of 'A' arms makes them very strong in the direction of travel, therefore I'm only really commenting on the direction of jounce.
I'll be very general here, but it makes the point-
For the flat plate arms, I think they are 3/4" thick. Let's assume they are 2" wide at the bushing. Their second moment of inertia (or area) is 0.0703in4.
As a comparison we could compare that to a 1.5"OD x .120" wall DOM tube. Many use 1/4" wall but that's overkill. The second moment of inertia (or area) for this tube is 0.249in4. Essentially ~3.5 times stiffer.
Second moment of area rewards height in the dimension parallel to the force. This is why a wood 2x4 holds more weight and is stiffer when its standing up vs laying down. Same with an I-Beam. Speaking of I-beams, we can also compare areas to see how efficient the flat plate arms are at getting their strength..
Comparing the areas(aka weights, assume same 'length' & density), the tube is .520in2 vs the flat plate of 1.5in2, nearly ~3 times less.
The argument could be made that the arms get wider than 2" towards the center and are stronger than I'm giving them credit for where it counts. Let's assume the 3/4" flat plate arms were wide enough to give them the same second moment of area as the tube, how wide would they be? 7". And keep in mind a tubular control arm usually has 2 tubes in it and some plate. That's comparable to 14" plus of flat plate and the weight is next to nothing.
I won't get into the performance benefits of lighter components vs heavier ones, but I figured I would touch on the strength/safety side of things. I'm sure the flat plate arms are suitable for mock ups and rolling around the shop, but I'd never put my families life on them.
Old 02-16-2018, 09:40 AM   #24
bluex
bluex's Avatar
Thanks RADustin, that makes sense. I was planning on some type of aftermarket arms on my truck but I redid my shock mounting and its nearly laying the crossmember on the factory arms. I don't see a need in changing them now.
Old 02-17-2018, 01:24 PM   #25
jkk
jkk's Avatar
Interesting
jkk is offline   Reply With Quote
