03-18-2010, 11:34 AM | #1 |
How-to-dress-metal
How-To-Grind-Metal Ok, there seems to be alot of confusion on how to grind metal, I am gonna try my best at helping everyone out some, I still have more to add, but this will be a start. FIRST: THE TOOLS NEEDED. :Sanders, 6" Dynabrade for my finish work, this does finer swirl marks in the metal, creating a more uniform appearance. 6" Dual Action sander, AKA,"THE KNUCKLE BUSTER" if you know the meaning of this, you have used one. used for medium sanding 8" Mac sander/grinder, used for initial knockdown and leveling.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
03-18-2010, 11:36 AM | #2 |
Re: How-to-dress-metal
:Grinders, there are several, this is what I use
Bosch 4.5" electic grinder with either a flap disc or grinding stone, or cut off wheel. This is my favorite. El Cheapo air grinder for all of my Carbide bits, these are used for corners and any place I can not grind with a stone Air tool for my cut-off discs and 3" grinding stones Mac 90 degree grinder for my ROLOC discs, ranging from 36 to 80 grit, also comes with abrasive pads and surface pads.
03-18-2010, 11:37 AM | #3 |
:Safety Equipment, A MUST HAVE!!!!!!
proper gloves, I use tig welding gloves face shield ear muffs 3M particle mask Safety googles
03-18-2010, 11:39 AM | #4 |
SPOT WELDS.
So you have a spot weld you want to grind down, what now, do I just hit it with a hard stone till it is beyond flat and heated the metal along the way, NOPE. stop right there, you never want to heat the metal when grinding, especially when it starts turning blue, bad, very bad, you just warped your metal and now have more work to deal with. First thing to do is grab a 3" hard grinding stone, or one on the elctric grindre and slowly, I mean slowly, grid down that weld, get it close to the surface od the original metal, without touching the original metal. It takes practice, I know. Once you have it close to the bottom, switch over to your ROLOC disc and start smoothing it out, never put too much pressure on the metal itself, just let the grinder do the work for you, nice and easy does it. This will take some getting use to but once it is mastered, you have won half the battle. Now you have some marks either in 36, 50, or 80 grit leftover from the grinder, what now, leave it, nope, depending on how bad you have cleaned up that weld, you can now use your sanders and smooth them out, I always use 80 grit on my pads to do this. Sand it for a bit and you are done, 8 out of 10 tens, no mudwork is needed. You have jsut mastered the spot weld grinding.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 Last edited by nuke1; 03-18-2010 at 11:40 AM. |
03-18-2010, 11:42 AM | #5 |
More
03-18-2010, 11:43 AM | #6 |
STITCH WELDS.
This is where it gets tricky. Lets say you have a weld 10" long, well that is a major heat source waiting to warp. Time must be taken to do this.Patience will prevail. Well which tool should i start with? For a weld this large I either start with my 3" air grinder or my Bosch 4.5" hard stone grinder. Depends on what you have and how you feel, Now remember to go slow and let the stone do the work for you, nice and easy, remember not to rush into things, or it just gets messy. Grind a small section at a time or go back and forth over it slowly. Never sit in one spot too long or you just heated the metal and causes more work for you. Since you have now ground down the majority with the stone, I swithch over to my Bosch grinder with a flap disc in 36 grit normally, this allows me to remove material quickly without pressure and does a nice smooth job. I never go to hard with this one either. Start at one end and go back and forth over the metal, these flap discs do an amazing job on leveling the weld and vreating a nice uniform surface, if you still feel wearily about getting too close with an electric grinder, then just finish it up with you ROLOC disc and smooth it out. Now that I have gone this far, I will normally take my 8" MAC sander and smooth over the whole surface with 120 grit. After this is done, I use my D/A sanders and finish the job, nicely ground down and sanded, nothin lookds better than this.
03-18-2010, 11:45 AM | #7 |
Some more
03-18-2010, 11:46 AM | #8 |
OTHER TID BITS.
Wire wheels on the electric grinder work great for that cleanup of alot of stuff, such as , seam sealer, old greae and grime, gutters..... I also have a Hard grinding disc for my MAC 8" air grinder and this works gret for many many welds that need smoothing, pinch weld seams, stitch welds, frames...... The carbide bits are a god send in my workd, you can use them for just about anything, from cleaning up a wled in a hard to reach area to smoothing out that corner that nothing else can get to, to creatinf a nice radius in a transition area. Keep all of you old 3" air grinder hard discs around, you never know when that one that is almost worn out to nothing will be used next, but it could be the right diameter for a job that you are tring to get a smooth grind in or transition. Even worn out ROLOCS come in handy, when they wear out, they tend to bend,well this is perfect for when you are trying to blend in a radius or doing a corner, they hardly bit and more pressure can be put on them. Flap discs for the electric grind have their purposes also, new ones are great for tight 90's, and much more, but sometimes that old used one works better for edges, jsut trim it down some on the edge and you have a brand new, but smaller flap disc! I hope this helps some ppl out in the hobby world, there is so much more yet to learn, but this is a start. Later and happy grinding James
03-18-2010, 11:59 AM | #9 |
Nicely done nuke1 ! Always good to go over the basics. I am old enough to know better but still find myself "in a rush" screwing up the base metal.
Thanks for a great thread !
"I feel the need for speed!"... as soon as I am done with my nap. |
03-18-2010, 12:13 PM | #10 |
Thanks for taking the time to right that up. Excellent info.
68 Camaro - 327 Original Red on Red Car 69 GMC LWB - Built 350 a Blast To Drive 69 GMC LWB - "Green Machine" One Family Truck 70 Mercury Marauder - Future Project |
03-18-2010, 12:14 PM | #11 |
Awesome wright up nuke1 great info to know if not familiar with this type of stuff, sheet metal can be a pain and this helps out alot thank you for the time you spend and great write up.
03-18-2010, 12:45 PM | #12 |
Great write up!
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
03-18-2010, 01:14 PM | #13 |
283 Drama Queen
Wow.
Great info. Mac.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
03-18-2010, 01:48 PM | #14 |
Thank you on metal dressing 101! I really thought it was very helpful and learned a few new things!!!
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
03-18-2010, 03:59 PM | #15 |
Great write up and thanks for sharing.
03-18-2010, 04:33 PM | #16 |
great write-up... I'm gonna see about having this placed in the FAQ area...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-18-2010, 05:54 PM | #17 |
Once you get this where you want it, you should make it into a pdf. Thanks for the nice write up. Using the grinding stone to take down the welds does make great sense. I mostly need a huge dose of patience.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
03-18-2010, 08:45 PM | #18 |
more ideas than money
Thanks for this post! I could never figure out why I couldn't get everything looking as good as some of the pictures I see here, but now I know the correct way.
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
03-18-2010, 11:03 PM | #19 |
Right on the line, baby!
Wow. Very thorough.
I PDF'd it. It's too big to post (1.4 Mb). If anyone wants it, PM me your email and I'll send it.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
03-20-2010, 10:23 AM | #20 |
excellent write up man! ill start my body work next winter so this is a lot of good to know tips.
03-20-2010, 11:58 AM | #21 |
GEARHEAD
Wish I had read this the other day...
It's ok, I did alright so far. And I was mostly doing work that will be hidden by the door panel anyway. Looks like I have more stuff to buy.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
03-20-2010, 12:30 PM | #22 |
Under Construction
James, thanks for the write-up......
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-21-2010, 11:16 PM | #23 |
Todd saved the how to above as a pdf and I have hosted it on my google docs. This week I will work to lower the file size.
Link to Google Docs.
03-22-2010, 08:19 AM | #24 |
Cool guys, glad this helps some of you!
03-22-2010, 05:52 PM | #25 |
Great write up!
Thanks for the info.
