Old 05-27-2009, 10:53 PM   #1
planetcaravan03
1/3 of the way there on the 71
well its getting closer. i am however installing a th-350 in place of the original 3 speed and was curious about a crossmember? any suggestions would totally be helpful i am using my 83 c-10 as a donor so if anyone knows if that crossmember would work that would be cool
planetcaravan03 is offline   Reply With Quote
Old 05-27-2009, 10:58 PM   #2
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: 1/3 of the way there on the 71
You should be able to use the cross member out of the donor as I believe the frames are similar. If for some reason it won't I have the stock member out of my 72 burb that was replaced with a tubular unit that came with my front suspension. I'll give you the cross if you need it you'd just have to arange to get it or cover to have it shipped from 59804
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 05-29-2009, 12:54 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
The auto tranny crossmembers are sold here and on ebay all the time for $30-$40.
Frizzle Fry is offline   Reply With Quote
