Old 01-12-2009, 08:28 AM   #1
pbeguy
pbeguy's Avatar
My 57 - 58 S10 Swap
I picked up a 1957 Step Side on Craigslist, The truck was mostly complete. It was sitting on a 1966 SWB frame that had been modified I sold that to a local guy and picked up a nice rolling S10 frame. I picked up a 1958 clip for a very good price and may go that route.
I used to buy and sell S10 parts and have most of what i need for this project. I want to chronicle my project here.
I am going to stretch the S10 frame to fit the wheelwells exactly.
Here are a few pics to start.
I also included a pic of my last project which was not surprisingly an S10.
I spent the last 25 years in Paint and Body and call it my passion.
pbeguy is offline   Reply With Quote
Old 01-12-2009, 08:56 AM   #2
pugs
pugs's Avatar
Re: My 57 - 58 S10 Swap
how much do you have to stretch the chassis to make it work for ya
keep the pics coming
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 01-12-2009, 08:58 AM   #3
pbeguy
pbeguy's Avatar
About 7 inches.
Old 01-12-2009, 01:59 PM   #4
pugs
pugs's Avatar
on my s-10 frame I took 9" out to fit the wheelbase
Old 01-12-2009, 07:24 PM   #5
BOHICA
BOHICA's Avatar
pbeguy, that's a nice looking Blazer.
I'm very interested in how you stretch your frame because I'll be using a Bravada frame and have to stretch it 7 inches as well.
BOHICA is offline   Reply With Quote
Old 01-16-2009, 12:22 AM   #6
pbeguy
pbeguy's Avatar
I got some work done today.
In the pics you can see that the S10 frame is actually a 2 piece unit. The front half is the same on most trucks.
The back half is added depending on what is being built by GM.
I took my grinder with a thin wheel and seperated the front runners from the upper and lower channels.
Then I cut verticallly just inside the factory welds. It takes some patience to make sure you don't hack the hell out of it to get it apart.
Once apart i just add the space needed and prepare to tack it this weekend. I happened to have a couple of frame sections
from an old build that I am going to weld in so that it looks factory
I got the 4wd 3.73 posi added also. With the extra 4 inches the 4wd offers,
I have a little over 50 inches to work with between the wheels.
Old 01-16-2009, 01:57 AM   #7
nuke1
nuke1's Avatar
very nice, can not wait to see this build, i have a picd of that blazer in a calender at work in the paint room, go figure. what are your plans for the truck?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-16-2009, 08:30 AM   #8
pbeguy
pbeguy's Avatar
I bought the Blazer from Maxwell and spent 10 months finishing it. We were both happy House of Kolor chose it to be a calender truck.
This build is going to be old skool with some new tricks.
Old 01-19-2009, 10:29 PM   #9
pbeguy
pbeguy's Avatar
Got some things accomplished this weekend.
The frame is welded up and smoothed out. I am completely happy with the results. I still think I will box the frame in for strenght.
I installed a brace that was on the back of an old Blazer for support.
I also took a DA to a fender and was surprised to find good metal to work with.
Old 01-19-2009, 10:59 PM   #10
watahyahknow
watahyahknow's Avatar
nice project ...
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-24-2009, 11:06 PM   #11
pbeguy
pbeguy's Avatar
Got the front bags finished. I decided to set the cab on and see where I was.
To my surprise the rockers planted themselves on the concrete when I let the air out.
It will have about 5 inches at ride height when I am done
I was surprised because it still has stock spindles, sway bar and 29 inch tires.
It might be possible to put 22's on the front without a lot of work.
The extra Blazer crossmember I put on at the rear fit the bed perfectly.
I am going to start on the rear system during the week after I decide which way to go.
I have all the parts to build a 4-link or I might just put on blocks and a c-notch.
Old 01-28-2009, 09:15 PM   #12
pbeguy
pbeguy's Avatar
New pics.
I had to set the body on to check for fit.
I still have to bag the back.
Old 01-28-2009, 10:41 PM   #13
watahyahknow
looks like its drooping a bit in the middle both the cab and the bed
Old 01-29-2009, 09:08 AM   #14
pbeguy
pbeguy's Avatar
The cab and bed are just sitting on the frame. I am going to fab the mounts up to level it out and use some factory rubber spacers.
Old 03-28-2009, 07:45 PM   #15
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
i would like to see how you do that....nice project!
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 03-28-2009, 08:33 PM   #16
GRIMSS
GRIMSS's Avatar
Is the front a 2wd s-10? Are you doing anything about the width if it is?
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 03-28-2009, 10:30 PM   #17
57ToyBox
57ToyBox's Avatar
Lookin real good there PBEGuy
I'm subscribed to your threat. Keep those pics cum'n
I'm just courius, what is the measurement on your wheel base? centre-to-centre
57ToyBox is offline   Reply With Quote
Old 03-29-2009, 09:40 AM   #18
71'tahoe
71'tahoe's Avatar
GRIMMS, from what I can tell from alll my years of messing with the s-10's,his frame pic in the #6 post looks like it is a 2wd frame. He said he was using a 4wd rear axle for the width in the rear,its 4" wider. I could be wrong but thats what it looks like to me. Hope this helps until he can chime in. Going to be a cool project.
71'tahoe is offline   Reply With Quote
Old 03-29-2009, 10:29 AM   #19
GRIMSS
GRIMSS's Avatar
The s10 front end is very narrow under these trucks. Here's what i'm getting at. this pic is a burb I cut up that has a 2wd axle close to center under it. Are you doing anything to widen the front?
2001 GMC SIERRA
1968 Camaro
Jared
Old 03-29-2009, 02:48 PM   #20
joeys66pickup
Dr. Frankenstein
WOW that is skinny...geez with some proper front runners it would look 10 times worse!
I Wanna Go Fast!!
Old 03-29-2009, 04:59 PM   #21
watahyahknow
hmmm he might be able to get longer a arms for that .
nathan from porterbuild should be able to make him sumtin that works
Old 03-29-2009, 05:28 PM   #22
57ToyBox
57ToyBox's Avatar
SURE !!! That'll do it Longer A arms and a nice set of wheels with the proper off set. That'll get ur done
Old 03-29-2009, 10:27 PM   #23
pbeguy
pbeguy's Avatar
I am going to run 2" spacers on the front to widen it up.
It is a stock 2wd short wheel base frame.
I did use a 4x4 rear because it is wider than 4x2.
Old 03-29-2009, 11:29 PM   #24
GRIMSS
GRIMSS's Avatar
Thanks, that's what I was wondering about.
2001 GMC SIERRA
1968 Camaro
Jared
