01-09-2019, 11:50 AM | #1 |
Floor pan coatings
Soon the floor pan of my Suburban will get sandblasted and epoxy primed. What is the best coating for the bottom of the truck? I posted a similar question on the paint section and Greg recommended Lizard Skin. From what I’ve read on another thread Lizard Skin is a latex paint with microspheres in it. I’m not as concerned with heat or sound as I am with protecting the metal.
Is a latex based paint my best bet? Thanks Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
01-09-2019, 03:14 PM | #2 |
Re: Floor pan coatings
Are you talking about inside the cab or underneath the truck? I know there are some coatings used on bridges and such that are arguably the toughest coating for the underside. Unfortunately the name escapes me at the moment. If this interests you I'm sure a search or two would revel the name.
Inside or out I don't know of any latex paint that would be appropriate. There are some water based paint systems out there for automotive use. There is a bit of a learning curve if you're not accustomed to using them.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-09-2019, 03:25 PM | #3 |
both of my burbs are 4x so I was planning to use bed lining coating in the pan and underside if I get to it..
garden hose and go.. I'm not really a 'carpet' guy in my trucks.. rubber floor mat is far as I'm going I did roll and brush some stuff out of a gallon can in the floor pans of our CUCVs, the k5 and 5/4t.. turned out great! something like herculiner [sp?] from pep boys I think it was.. our SKs went out and bought it for us.. peeled all the crap out of the pan, little scrapin' n sandin' and brush cut the edges and rolled it out.. return from the field, light garden hose, dry, and done.. no smell, rot, mold, etc. and looked great to boot! that stuff is really hardy if applied properly so I would think still a great undercoating even for topping with carpet, etc.. good luck!
I started out with nothing - and I still have most of it |
01-09-2019, 07:08 PM | #4 | |
Paul
01-09-2019, 07:51 PM | #5 |
UPol-Raptor urethane undercoating is what I like, 4 qt bottles in a kit, some kits come with the shultz gun. Also comes in a tintable version, I add extra urethane paint and reducer on the top side for a smoother finish, but not as glossy as paint alone, thinner version put on metal or plastic, with HVLP GUN 1.8 tip after mixing well.
01-09-2019, 08:01 PM | #6 | |
01-09-2019, 08:08 PM | #7 | |
https://nomorerust.com/store/17-finish-coatings
01-09-2019, 11:28 PM | #8 |
The Older Generation
I use 3M Body Schutz on the underside of all of my projects. Goes on easy, looks good, and dries quick. https://www.amazon.com/3M-08864-Schu.../dp/B000PEQGMM Just for reference, you can probably find it locally..... LockDoc
01-09-2019, 11:55 PM | #9 | |
Paul
01-10-2019, 11:11 AM | #10 | |
Yes, I did the bottom side of the wood floor too. I also did the inside of the panel truck a couple of years ago, the entire cargo area except for the floor. I bought a case of 6 for the panel truck. It keeps pretty good. Leon
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-10-2019 at 11:17 AM. |
01-10-2019, 11:42 AM | #11 |
A case of 6 at $34 each? Wow. Must be good stuff!
01-10-2019, 07:44 PM | #12 |
If I remember right I paid $28 ea. by buying the case. Hey, it's only money, right?....
01-10-2019, 08:16 PM | #13 |
I can’t seem to find it by the case. Do I have to use the official 3M gun at $120?
01-11-2019, 02:51 PM | #14 | |
I bought the case at my local Arnolds Auto Supply. I would think that any schutz type gun would work as long as it would screw on the bottles, but I can't back that up with any proof. I think that Dynatron, Astro, and 3M undercoating guns have the same size opening and threads. There may be others also. EDIT: This place has it by the case. https://www.goferauto.com/prfo3mboscru.html I don't know anything about them. Contact info says they are in Tennessee. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-11-2019 at 03:16 PM. |
01-14-2019, 03:27 PM | #15 |
Napa stores that carry Sherwin Williams paints have an epoxy that has been used on trains. So it should be very durable, it's not cheap though! I did the frame of my truck and the underside of the floor and wheel wells. Over the top of that I used Raptor bedliner on the floors. If you use epoxy what ever you are going to put on top of it do it in it's recoat window. The inside of my truck has Lizard skin. I am concerned about noise and heat. The metal is fully encapsulated so it should last longer than me!
01-14-2019, 10:47 PM | #16 | |
Paul
