Old 05-17-2017, 03:14 PM   #1
Josephguzman
Gauge cluster
I was wondering what the two empty circles on a 60-66 gauge cluster were used for, having not come across a factory guage cluster with a tachometer. Thank you in advance
Josephguzman is offline   Reply With Quote
Old 05-17-2017, 03:26 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Gauge cluster
Vacuum, Tachometer I believe. On larger trucks mostly I would think. Since then however we are using them.
Old 05-17-2017, 03:43 PM   #3
ray_mcavoy
Re: Gauge cluster
Yes, the opening on the left was used for either a vacuum or air pressure gauge. The vacuum gauge was available in the medium duty trucks with vacuum assisted hydraulic brakes and the air pressure gauge was used in trucks equipped with air brakes.
The opening on the right was used for the tachometer which was an available option in everything from 1/2 tons up into the medium/heavy trucks.
ray_mcavoy is offline   Reply With Quote
Old 05-17-2017, 11:48 PM   #4
rvrfoot
Re: Gauge cluster
I seen someone put a clock in one before.
rvrfoot is offline   Reply With Quote
Old 05-18-2017, 09:31 AM   #5
The Rocknrod
Moderator
Re: Gauge cluster
You sure have.
Old 05-18-2017, 10:24 AM   #6
Nanook
Nanook's Avatar
Thumbs up Re: Gauge cluster
Love that cluster....
Nanook is offline   Reply With Quote
Old 05-18-2017, 10:35 AM   #7
chevylookin
Re: Gauge cluster
Originally Posted by The Rocknrod View Post
You sure have.
Hey Rocknrod, I am about to try a potentially expensive mistake and just go for it because I have dreams at night about a full gauge cluster in my 64 SFB and buy the aftermarket Classic Ind. produced Nova tach and clock and hope that with little alteration, I can make them fit into my stock gauge housing. I have a I6 230 and to my knowledge, Chevy didnt offer tachs for our trucks for the 6 but CI has the 6 cyl version. The Nova gauges look like they are almost indistinguishable from the trucks. Any experience or have you ever heard of this before?
http://www.classicindustries.com/pro...s/3863796.html
chevylookin is offline   Reply With Quote
Old 05-18-2017, 10:39 AM   #8
The Rocknrod
Moderator
Re: Gauge cluster
New to me but very interesting. Many people here would like to find out if they are. Also I had to have mine custom made to be a volt gauge and an sender type oil gauge. I also bought the electric limited sender for the temp gauge, so with my new fuel tank sender I should be "in the mix". Since I am wiring the truck as though it's a fiberglass unit using ground wire everywhere it should read well and the lights should be as good as they can possibly be.
Old 05-18-2017, 10:45 AM   #9
chevylookin
Re: Gauge cluster
Well, I am just going for it. I will definitely post an article on the trial of it. Looking at your minty gauge set up there, I see you had to run the the clock adjuster arm through the lense which you did precisely. I see you have a chrome grommet to protect the plastic lense which the adjuster rides through. What did you use? It looks very factory. Good job!
Old 05-18-2017, 10:54 AM   #10
The Rocknrod
Moderator
Re: Gauge cluster
Originally Posted by chevylookin View Post
... I see you had to run the the clock adjuster arm through the lense which you did precisely. I see you have a chrome grommet to protect the plastic lense which the adjuster rides through. What did you use? It looks very factory. Good job!
An artisan named Gerald did the work - impala1062@msn.com
Another member of this board TBONE1964 did the gauge change over work.
Old 05-18-2017, 11:35 AM   #11
LDO
LDO's Avatar
Re: Gauge cluster
Good morning Master Chief! Great looking gauge cluster!
LDO is offline   Reply With Quote
Old 05-18-2017, 11:50 AM   #12
The Rocknrod
Moderator
Re: Gauge cluster
w-Sup LDO you've been keeping a low profile as of late.
Old 05-18-2017, 02:54 PM   #13
LDO
LDO's Avatar
Re: Gauge cluster
Picked up an 85 for my son so we've been wrenchin on that for a bit. My 66 is in pieces waiting on time/money!
Old 05-21-2017, 11:58 PM   #14
Josephguzman
Re: Gauge cluster
The rocknrod, that's an amazing cluster!! It's blown me away!! Does the guy who did the work take orders?
Old 05-22-2017, 12:21 AM   #15
jocko
jocko's Avatar
Re: Gauge cluster
the 60's GM vac gauges (seem to be most common in Pontiacs, but other GMs had them also, just in different casings and with different works cover plates) are a good fit. Here's the cluster I put in a 66 I sold a while back. I made use of some of the other unused (i.e. med duty) openings in the dash as well .
Old 05-22-2017, 01:50 AM   #16
The Rocknrod
Moderator
Re: Gauge cluster
I put his contact info above so someone could ask him that question.
Old 05-22-2017, 08:48 AM   #17
Josephguzman
Re: Gauge cluster
Thanks The Rocknrod, and thanks everyone fir you're answers! Very helpful and great to see examples
Old 01-25-2019, 05:16 PM   #18
insulator37
Re: Gauge cluster
What is the correct color for the 66 cluster bezel ?
insulator37 is offline   Reply With Quote
Old 01-26-2019, 09:08 PM   #19
jocko
jocko's Avatar
Re: Gauge cluster
64-65: satin black
66: silver
Old 01-28-2019, 01:42 PM   #20
corvettejim1968
corvettejim1968's Avatar
Re: Gauge cluster
left side is for vacuum or air on the big c 50,60,80 right side for tach.
i bought a vacuum gauge and installed it in my 65 c10
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 01-29-2019, 06:10 PM   #21
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Gauge cluster
RPO U16 Tachometer in 10-20-30 light duty trucks.
RPO Z53 Gauges AMMETER ,OIL & THERMO
dash, guage, guage cluster, tachometer
