Old 09-17-2014, 08:51 PM   #1001
TowwDogg
TowwDogg's Avatar
Re: My 57 Pro Street
This is an awsome build. great job
TowwDogg is offline   Reply With Quote
Old 09-18-2014, 12:33 AM   #1002
Kim57
Kim57's Avatar
Thanks.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-18-2014, 08:41 AM   #1003
FarmerSid
FarmerSid's Avatar
I can appreciate the work you have done so far on the cab. I'm at the same stage with smoothing seams. Great build.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 09-19-2014, 03:56 PM   #1004
RockinKees
RockinKees's Avatar
Spent a few hours reading back your whole build...did someone allready said you are a true Craftsman???
I learned a lot only from looking at your pics!
It's like a book you must have when you have a TF truck!!
So, keep building, so I can read it with pleasure!!
Great truck!!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 09-19-2014, 04:01 PM   #1005
Kim57
Kim57's Avatar
Thanks.
I wish I was better at body work.
What takes me hours I'm sure a pro could do in no time.
Great truck!!!
Thanks.
When I go back and look at what I have done I can't believe it sometimes myself.
There's no way I could do it again.
Kim
My build thread
Old 10-06-2014, 08:10 PM   #1006
hydrojunkie
hydrojunkie's Avatar
Originally Posted by Kim57 View Post
Working on the bottom of the cab i got tired of having to straighten the door sills out. My originals were toast and my new ones kept on getting banged up as they seem to be a weak spot.
This is what i did.
Took some 1"x2" rectangular tube and cut out a couple of braces.
Got them welded in and now my sills can hold me.
Kim
I need to do that. Fantastic idea bud. Truck looks great.
Magic happens with a welder and a grinder.
My custom tubular c10 laying rockers.
http://67-72chevytrucks.com/vboard/s...78#post5970778
hydrojunkie is offline   Reply With Quote
Old 10-06-2014, 11:14 PM   #1007
Kim57
Kim57's Avatar
Thanks.
Kim
My build thread
Old 11-04-2014, 10:56 PM   #1008
Kim57
Kim57's Avatar
A little up-date.
Been getting into the body work.
I have the cab tilted on its back so it's a little easier to work on the roof.
I welded up the over hang and filled it in.
Then to the roof itself. It was in pretty decent shape.
A couple pics after epoxy and a little sanding. You can see it needs a little work.
Kim
My build thread
Old 11-04-2014, 11:03 PM   #1009
Kim57
Kim57's Avatar
I got some Slick Sand.
This stuff is really thick but makes it easy to get the whole surface covered.
I hit with some 80 grit and then used dry guide coat. This stuff went on real easy and gets into the finest of scratches.
A lot more sanding and then another couple coats of epoxy and it looks pretty good.
Will have do do a final sanding and then seal before paint.
Kim
My build thread
Old 11-05-2014, 12:20 AM   #1010
oldman3
oldman3's Avatar
Really taking shape, nice work. Who makes slick sand..Jim
oldman3 is offline   Reply With Quote
Old 11-05-2014, 12:21 AM   #1011
Stepside Jim
Ahhh, I remember those days, priming, sanding, priming, sanding........
Looking good, carry on. Jim
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old 11-05-2014, 07:43 AM   #1012
rgunlock
rgunlock's Avatar
Looking really good Kim. Just a question because I'm at a similar state on my build, but why more epoxy over the slick sand rather than go straight to sealer? Jim - I'd hope you remember those days, you've been living them for quite some time now haven't you
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is online now   Reply With Quote
Old 11-05-2014, 08:29 AM   #1013
RockinKees
RockinKees's Avatar
Right on!
Good to see an update again Kim!
Hope all goes well now?
Cheers!! Kees.
Kool Guyz CC
Old 11-05-2014, 09:33 AM   #1014
Kim57
Kim57's Avatar
sand..Jim
It's made by Evercoat.
I found it on Amazon for $60.00 a gallon with the hardener.
I had a couple of spots on the edge where I got back down to bare metal as I didn't have a heavy coverage of the Slick Sand and it will be a while before I get to the actual paint.
Right on!
Thanks for the positive comments guys.
Even though this part of the build can be tedious I'm motivated to stay with it.
Kim
My build thread
Old 11-05-2014, 09:37 AM   #1015
ricott
Good looking progress on your roof. I love SlickSand - I'm just a couple of years away from needing it on my project! Have you decided on a paint color?
ricott is offline   Reply With Quote
Old 11-05-2014, 04:36 PM   #1016
OrrieG
OrrieG's Avatar
I have been using Urofill, not as thick a build up as Slickcoat, but thicker than regular primer, and compatible with 2K sealer.
Old 11-05-2014, 08:04 PM   #1017
Kim57
Kim57's Avatar
Thanks.
Right now I'm leaning toward a light metalic blue that chevelle's were painted in the mid 60s although that may change.
This stuff is pretty thick and I still need a little practice spraying it but I like the results so far.
Kim
My build thread
Old 11-06-2014, 12:16 PM   #1018
blue57
blue57's Avatar
Glad to see you are back at it. Looking good.
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline   Reply With Quote
Old 11-20-2014, 12:16 PM   #1019
Bernman72
Wow.....you do some amazing work man!!
Bernman72 is offline   Reply With Quote
Old 11-20-2014, 01:19 PM   #1020
Daze57
Daze57's Avatar
kim
looking real good !!!
Daze57 is offline   Reply With Quote
Old 11-20-2014, 03:14 PM   #1021
Kim57
Kim57's Avatar
Originally Posted by Daze57 View Post
kim
Thanks guys.
Not much to report other than just trying my best at body work.
Kim
My build thread
Old 01-04-2015, 02:08 AM   #1022
TACwelds
TACwelds's Avatar
Kim, I am glade to see you are making progress, thank you for your comments on my project. I see you are using a dry guide coat are you wet or dry sanding and can you do both?
TACwelds is offline   Reply With Quote
Old 01-04-2015, 10:47 AM   #1023
Rude Dude
Rude Dude's Avatar
Looking good I hate body work!
Rude Dude is offline   Reply With Quote
Old 01-04-2015, 11:54 AM   #1024
Kim57
Kim57's Avatar
I'm just dry sanding at this point.
Not sure how wet sanding would work with the dry guide coat. It may just rinse it off.
As you can tell I'm new at this part of the build.
It isn't the most fun part of the build but it keeps me out of trouble.
Waiting for the weather to get a little warmer so I can get back at it.
Kim
My build thread
Old 01-06-2015, 12:49 PM   #1025
Kabwe
Certified Car Nut
Kabwe's Avatar
Kim there is no need to wet sand before painting. I also use the dry guide coat and it works great. Finish off your block sanding with 600 grit (solid and less transparent metallic colors you can get away with 400 grit but 600 grit is safe) before applying your base coat and you will be fine. You can save all your wet sanding and buffing once your finished painting to get rid of any imperfections.
Another point about block sanding that can lead to mistakes is this. Let the sand paper do the work. In other words don't muscle and push down hard while sanding. Just let the black guide across the panel in an x pattern. Applying pressure will lead to problems.
Kabwe is offline   Reply With Quote
