04-06-2018, 08:22 PM | #1 |
Hood distorted?
Was checking my hood out today with a straight edge and noticed there’s a high spot on each side of the hood directly above where the hood hinges attach. It’s basically at front of the structural brace that goes across the rear of the hood.
Wondering if this should be nice and flat or if they all have a high spot there? |
04-09-2018, 07:12 PM | #2 |
Re: Hood distorted?
I spent days blocking my hood and it looks very similar to yours. I would describe it more of an arc from front to back rather than just a high spot. And that arc was pretty much consistent across the entire hood.
04-09-2018, 07:55 PM | #3 |
Moderator
Re: Hood distorted?
Yep.
04-09-2018, 08:49 PM | #4 |
Re: Hood distorted?
Thanks for the reply Yankee, glad to hear it’s nothing out of the ordinary. I did find a chunk of black foam between the brace and the hood (only on the passenger side) that I removed and that made the high spot less severe.
04-09-2018, 08:54 PM | #5 |
Re: Hood distorted?
That strip of foam is supposed to be there. Removing it might allow the hood to flatten a bit but it will also keep it from possible oil canning.
04-09-2018, 09:01 PM | #6 |
Moderator
Re: Hood distorted?
And you'll be replacing that foam soon.
04-09-2018, 09:14 PM | #7 |
Re: Hood distorted?
Well there’s the foam strips between the removable braces that should be there, as it is, but this was a different density foam stuck between the hood and rear cross brace. Only on the PS of the hood. I should’ve taken a picture I guess. Is there supposed to be foam there too?
04-09-2018, 09:33 PM | #8 |
Re: Hood distorted?
Ah, now that, I believe, is not factory. Quite sure.
04-09-2018, 09:35 PM | #9 |
Re: Hood distorted?
Okay right on, I couldn’t find any info on it so figured it was a “custom” mod by a previous owner.
04-09-2018, 09:52 PM | #10 |
Moderator
Re: Hood distorted?
No it's factory. This is the LMC catalog, it's also shown in the factory assembly manual that you should get.
Here is a great thread look through the whole thing. http://67-72chevytrucks.com/vboard/s...d.php?t=607123
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 04-09-2018 at 09:58 PM. |
04-09-2018, 10:26 PM | #11 | |
Re: Hood distorted?
04-09-2018, 10:43 PM | #12 |
Moderator
Re: Hood distorted?
When your driving around your hood will squeak and it will drive you mad trying to find it from bumper to bumper until you find you need the foam no one told you about.
04-09-2018, 11:00 PM | #13 |
Re: Hood distorted?
That makes sense, definitely spared me the headache. Will be adding the foam kit to my next parts order. Thanks again.
04-10-2018, 06:38 PM | #14 | |
Re: Hood distorted?
Thanks for the correction! |
04-10-2018, 08:43 PM | #15 |
Re: Hood distorted?
I've had the unfortunate pleasure of working on several gigantic hoods and I must say these truck hoods are pretty bad even straight. I would think you would have to completely disassemble and shrink the shi@out of it to get rid of the wonk. I don't think they cared much about the hood when they produced these. Not a jab just an observation and bonus that they can pass the body work test easier. Check out the build "sanford" you could tell he slapped that hood with a spoon for awhile. Yours looks beautiful to me!
11-09-2018, 10:22 AM | #16 | |
Re: Hood distorted?
I was recommended to use a dynamat material between the brace and hood instead of that cheap grey foam strips the vendors sell. Anybody tried this around here? I’m not sure how much shock absorption it’d do? |
11-09-2018, 07:27 PM | #17 |
Re: Hood distorted?
My hood is absolutely perfect when it’s up when you close it well now that’s another story The inner Hood brace flexes and pushes up on the inside of the hood from the tension of the springs
11-09-2018, 08:02 PM | #18 | |
Re: Hood distorted?
I hope that's not the case with my hood. I did all the body work and blocking on saw horses. No hinge springs were pushing up on it. It had a little bit of a curve/bulge even then. |
11-09-2018, 08:10 PM | #19 | |
Re: Hood distorted?
Damnyankee, ya I agree the material seems too dense for this purpose and prob wouldn’t be much for absorbing vibrations. |
11-09-2018, 10:19 PM | #20 |
Re: Hood distorted?
My plan is to use 30 pound felt paper not ticket enough to cause any more distortion but it won’t squeak
11-09-2018, 10:38 PM | #21 |
Re: Hood distorted?
That’s a solid idea for sure. That’d work great for the rear and front corner pads but not really sure about the long center braces. Let me know how it works. I just ordered the foams for $40 so I’m invested now, haha.
11-10-2018, 09:32 AM | #22 |
Re: Hood distorted?
I use the foam pads for the center support and the front But there was no room in the back where I planned to use the 30 pound felt the other pieces were installed before I block the hood out if I hadn’t known that the back support flex that much I wouldn’t have clearance it but it’s painted now lol
11-10-2018, 10:56 AM | #23 | |
Re: Hood distorted?
