05-08-2018, 08:05 PM | #201 |
Re: New 64 Stepper Project
Are those hood hinges cad plated?.....gold looks nice..
05-08-2018, 08:10 PM | #202 |
You are crazy detailed on your build...I am impressed
http://67-72chevytrucks.com/vboard/s...d.php?t=765151 |
05-08-2018, 09:02 PM | #203 |
Moderator
Cadillac plating did the cad plating, they have a new plating now though.
Thanks for the compliment guys.
05-09-2018, 08:50 AM | #204 |
I'm just glad to be here!
Wiring for the park/turn signals looks nice and clean. That is the way I did mine that I tried to explain before.
Are you using a nylon washer under the head of the bolts? Looks like something is between the bolt head and the inner fender where they bolt to the firewall. Very clean and detailed build!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
05-10-2018, 09:14 PM | #205 |
Moderator
Watch out for your hood sponges. I bought a set from LMC and a set from I think The Truck Shop and the Truck Shops were narrower, same thickness though.
05-10-2018, 09:16 PM | #206 |
Moderator
Also I put my dome lamp in. Waiting on the courtesy foot-well lights to finish the wiring.
05-12-2018, 08:04 AM | #207 |
Moderator
Okay I installed the hood running/turn lamps, they are LED, new housings, plug, fasteners. I clear coated the housings and plugs masked where needed of course.
05-12-2018, 08:07 AM | #208 |
Moderator
Received the courtesy lights and installed them wired except for the passenger side. Going to work on the when I get a glove box that I will get when I get an air conditioning unit. Want the wiring to be nice so running it will all be together.
05-12-2018, 08:12 AM | #209 |
Moderator
I bought a dash speaker from retro-sound I think, anyway one of the brackets didn't line up so I did some modification to the location and bracket. Lines up now.
I'm not big into stereos, so I will have one but the boom-boom thing isn't mine. People try to "school" me on what is boom-boom and what is not - I cant tell the difference. Other than the green items you see I got from an original bracket and the rubber piece too, the rest came with the speaker.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-12-2018 at 09:18 AM. |
05-12-2018, 09:43 AM | #210 |
I am with you on the Boom Boom Thing! My hearing sucks and all I need is some Music, besides I would rather hear my wife and the exhaust note when I am cruising. Thanks for the updates I really like the way your truck is taking shape.
05-12-2018, 11:34 AM | #211 |
Moderator
Thanks I'm tryin.
I still want to install foam around the speaker and put some black material on it before I install it for good. So I'm going over today and look for that stuff locally.
05-12-2018, 04:20 PM | #212 |
Moderator
Okay here is my plan on the front seat. Cream and Red with material, not sure which of the two materials on the right yet.
05-12-2018, 06:04 PM | #213 |
That is one sharp truck, if you were a little closer I would stop by and see it in person. Nice work
05-12-2018, 06:10 PM | #214 | |
How did you get the wires to the front of the hood? Under the bolt on brace ? Mine is just wire tied and exposed, yours looks really clean.
05-12-2018, 06:17 PM | #215 |
Moderator
Pretty much thats how I did it. Thank you for the kind comment, I wish you were closer too you could stop by once in a while.
05-14-2018, 12:39 AM | #216 |
Moderator
Installed the speaker, cant even tell it's in there. And The cowl leaf/trash screen is in there also.
05-14-2018, 08:16 AM | #217 |
That worked well...nice idea
05-14-2018, 08:57 AM | #218 | |
Would you mind sharing the part numbers from SMS for those two fabrics? Keep up the great work!
05-17-2018, 02:07 PM | #219 |
Moderator
So I installed the gauge panel after finishing the wiring behind it. Have everything else ready to plug in when I get the rest.
05-17-2018, 04:27 PM | #220 |
1962 C-10
Looking beautiful! Very clean...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
05-17-2018, 07:52 PM | #221 |
Wow, you must be a perfectionist because that looks like a really nice build.
Everybody has to believe in something. I believe I'll have another beer. |
05-17-2018, 08:03 PM | #222 |
Moderator
Thanks guys.
05-17-2018, 09:48 PM | #223 |
I just read through your thread, this is gonna be one heck of a truck...
can I ask how / what you attached under the cowl as the trash screen? |
05-17-2018, 11:08 PM | #224 |
Moderator
Thank you, I hope it will be.
I purchased a roll of 1/4" X 1/4" screen and formed it ever so carefully almost wire by wire to fit in the underside so that it would support itself. Then I read recently where one of our members here used some hot glue ensure his stayed a few years ago (still works) so I used some too.
07-13-2018, 12:10 PM | #225 |
Moderator
Back when the local trailer guy brought my truck home from the painter - 1 year, 1 month, 1 day after I let them have it.
In your "wildest" dreams - what do you think the cost was, all new sheet-metall before the painter got it.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 07-13-2018 at 01:03 PM. |
