Old 12-29-2017, 04:56 PM   #1
moneypit1965
VIN question
So I have a 65 Short bed Step, BUTTTTT my Model/VIN is 1C1445Z1XXXXX
I know its a half ton short bed step born in Fremont...... but why is there a 1 in front??
I did look at the Drivers front frame rail to verify as well for the last 8 digits.
I swear I am not idiot but I just can not find the answer. I have looked at multiple decoders and they leave me with no answer.
Help?
1961 GMC 1000 series 4x4, flatbed, 350 v8, SM 420, Dana 44 front, HO35 rear, another work in progress
1965 C10 250 I6 Shortbed Stepside (currently flatbed) work in progress
daily driver 05 cobalt.
moneypit1965 is offline   Reply With Quote
Old 12-29-2017, 06:00 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: VIN question
Does the stamp on the top of the drivers side frame-rail at about the cross-member read the same last seven numbers?
Oh wow after looking at that, looks weird. Two different stamps and the numbers after 1C144 are not in order? Check the frame rail number and report. Please.
Old 12-29-2017, 06:22 PM   #3
moneypit1965
Re: VIN question
Yes the stamp on the front is the same as the last digits on the VIN.
If I knew how to add a photo on the mobile I would. But yes it is a 1965, flat windshield and the front suspension is not torsion.
Could it be a late 64 that was sold as a 65?
Edit: first is the frame.
Old 12-30-2017, 03:52 PM   #4
61K10
61K10's Avatar
Re: VIN question
What is on the pink-slip/reg.? shows as a 61 but Freemont (z) was not around (built) then.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-30-2017, 07:17 PM   #5
moneypit1965
Re: VIN question
Registration says 65. It is physically a 65, registered as a 65, but this 1 is throwing stuff off.
And yes I know what the decoders say.
Old 12-30-2017, 10:47 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
Re: VIN question
Those rivets on the vin tag look to be pop rivets, recent ones at that....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-30-2017, 11:07 PM   #7
moneypit1965
Re: VIN question
I thought about that buttttt I have seen others without the rosette style.
Old 12-31-2017, 10:21 AM   #8
oldusafmsgt
oldusafmsgt's Avatar
Re: VIN question
Looks like the VIN tag was replaced. Rivets are wrong, numbers don't add up.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 12-31-2017, 01:05 PM   #9
DPowers
One foot in front of the other
DPowers's Avatar
Re: VIN question
Interesting for sure.
DPowers is offline   Reply With Quote
Old 12-31-2017, 01:46 PM   #10
Re: VIN question
That is what my guess is, some plant was still doing the 60-64VIN, with the 65-66 also in there.
I know on the 67-72 the number on the SPID had the extra 1, wonder if the stamper got confused.
If it matches your title and your state allows those rivets (could have been done by body shop during a repair), your good I guess. Far as I know most all the 60-64 Vins were welded on, not held on with rosette rivets.
Old 12-31-2017, 03:23 PM   #11
The Rocknrod
Moderator
Re: VIN question
... Far as I know most all the 60-64 Vins were welded on, not held on with rosette rivets.
You can say that, it's not entirely correct but you can say it.
There is a thread/poll here recently - http://67-72chevytrucks.com/vboard/s...d.php?t=670947
http://67-72chevytrucks.com/vboard/s...d.php?t=539385
http://67-72chevytrucks.com/vboard/s...12&postcount=9
Old 12-31-2017, 05:03 PM   #12
moneypit1965
Re: VIN question
First off, I appreciate all the responses in regards to my predicament. I did find the build sheet, from behind the seat and the piece for the VIN is intact. Sooooo I'll try and do some more research.
Again, Thank you all for the responses!
Old 12-31-2017, 05:57 PM   #13
The Rocknrod
Moderator
Re: VIN question
Does it show a year and the VIN on the sheet? Can you scan and post for us, maybe we will all learn something.
Old 12-31-2017, 06:26 PM   #14
60-66
60-66's Avatar
Re: VIN question
Just to add to the Rivet mystery , I have pictures of a survivor 1965 K10 Suburban from the Fremont plant = Z , with One Rosette rivet and One Round rivet . It also has the same Font differences in size as the original post here. I believe your tag and possibly even the rivets are original.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-31-2017, 08:07 PM   #15
rideblue00
rideblue00's Avatar
Re: VIN question
ive been digging a little. the 1 seems to denote year?...1961
http://67-72chevytrucks.com/vboard/s...d.php?t=463671
rideblue00 is offline   Reply With Quote
Old 12-31-2017, 08:20 PM   #16
rideblue00
rideblue00's Avatar
Re: VIN question
i know you said its a 65, but that tag is weird. anything ive seen says that the first digit denotes year. My vin does not have a number before the c and ill bet most others do not either.
http://www.oeltd.net/doc/6066gmc/VINs/gmc-canada.htm
http://67-72chevytrucks.com/vboard/a...1&d=1202233538
Old 12-31-2017, 08:38 PM   #17
rideblue00
rideblue00's Avatar
Re: VIN question
http://www.47287chevytrucks.com/pg1.html
Old 12-31-2017, 09:14 PM   #18
1966 K10
1966 K10's Avatar
Re: VIN question
Here is my 66 tag. I do remember seeing repro tags on ebay with the model numbers pre stamped. There are blanks that pop up now and then.
http://www.classicdatatags.com/1965-...nd-trucks.html
1966 K10 is offline   Reply With Quote
Old 12-31-2017, 09:47 PM   #19
rideblue00
rideblue00's Avatar
Re: VIN question
Are repro tags even legal...
Old 12-31-2017, 11:38 PM   #20
The Rocknrod
Moderator
Re: VIN question
Probably not but I think the discussion is about the guys VIN (is it real etc) not the legality.
Then we will digress into posting laws from various states and making grand statements about what is legal.
Personally I'd like to stay away from that and discuss what is real, repoped,faked or whatever on this guys truck, but that's just me.
Old 01-01-2018, 01:05 AM   #21
moneypit1965
Re: VIN question
Recap:
The build sheet has been..... well mice and age. So I do not have much of it left.
It is from Fremont. It is a 1965 with a 1 in front. It appears to be valid. It is a Coil Spring front end. (61 had Torsion correct?) Which would indicate that since the frame number, build sheet, and VIN all have the same last 8 digits, it is correct(?).
Did they just run out of correct vin plates and said "good nuff"
Last picture is what it looked like when I got it in 06.
I will attempt to find the dealer (highly unluckily but I will give it a shot). And I may try the.... dmv.... I do not want to start the New Year with those people.....
Old 01-01-2018, 02:32 AM   #22
1966 K10
1966 K10's Avatar
Re: VIN question
Here is a pic of my old burbs tag
1965
Old 01-01-2018, 02:36 AM   #23
1966 K10
1966 K10's Avatar
Re: VIN question
all three together
Old 01-01-2018, 08:19 AM   #24
The Rocknrod
Moderator
Re: VIN question
Here is the VIN thread I was talking about earlier.
http://www.67-72chevytrucks.com/vboa...d.php?t=316902
On the vehicle in question - why again can't you show the entire VIN plate?
Old 01-01-2018, 09:19 AM   #25
rideblue00
rideblue00's Avatar
Re: VIN question
That 1 at the beginning is weird.
Do build sheets show the year of the vehicle? like 1965?
