07-19-2017, 03:52 PM | #1 |
Choppin block help!?
Hey guys so i got a full choppin block for my truck and im going to document the install because for some reason knowbody has directions or anything! But does anyone have a bolt diagram? So im putting out the correct info? Some of them are straight forward and i have called bc fab, emailed cbchasis and called azperformance still no luck on getting a diagram. Bags werent labeled as well!! Any help is appreciated
07-19-2017, 05:05 PM | #2 |
Re: Choppin block help!?
Hi there. I recently did a Chopping Block kit myself. None of their stuff is labelled or comes with instructions. There is diagram for it. What do you need? I just found which bolts seemed to fit best and used those. once you start putting it together it will make a little more sense.
07-19-2017, 05:10 PM | #3 | |
Well i have the whole thing cut and mocked up and holes drilled. I have a general idea, where did you put the bolts that had a space after the bolt head before the threads ( dont know what they are called sorry) and how did you go about welding your axle brackets? As far as making sure they are setup so you can dial in your pinion angle? Thanks! |
07-19-2017, 05:32 PM | #4 |
Moderator
I might be misrepresenting (in my mind) here, but am I reading this correctly? - the guys who put this kit together just put everything in a box no labels no instructions and sold it that way? After the word got out more than one person said "that's what I want" ???
Just asking.
07-19-2017, 05:35 PM | #5 | |
07-19-2017, 06:21 PM | #6 |
So their kits do not come with any instructions. Most of it is straight forward, but it should have at least some basics.
Dwolfe I believe the large bolts with a long "shoulder" are most likely the bolts used for the four link ends (eight total). If they are thinner bolts, they may be for the battery mount. |
07-19-2017, 06:39 PM | #7 | |
07-19-2017, 06:48 PM | #8 |
As for the rear end and hangers, I tried to level the truck as best I could on jack stands. Then I placed the rear end on a jack and set it where I wanted it (centered up side to side). I then clamped the hangers onto the rear axle and connected the four links. I used a digital level to get the pinion angle to match the frames angle (no driveshaft yet). Once I had things lined up fairly well I raised and lowered the rear end with the jack to simulate suspension travel. Once I was happy with it I marked the rear end and sent it out for welding.
07-20-2017, 09:37 AM | #9 | |
07-20-2017, 09:41 AM | #10 |
Finally figured out bolts hers some pics of the rear choppin block! And the front - drop spindles , disc conversion new brake lines, ball joints, hubs, power steering conversion, and steering linkage
07-20-2017, 10:20 AM | #11 |
67-72 parts collector,…
Not running the Choppin Block front kit?
07-20-2017, 10:23 AM | #12 |
07-20-2017, 12:09 PM | #13 |
I adjusted all of the links in to their shortest position when I mocked it up. That way I could get maximum adjustment in either direction. I basically tried to match the pinion angle to the frames since the drive shaft should be close to the same. That being said, I am still making adjustments to the pinion angle to eliminate a vibration at around 2000 rpm.
When I first installed the kit and had things running I didn't have any vibration. But at that time the rear end was in a pretty straight line between the trans/center bearing/ rear end. Now that I'm sitting much lower, I'm getting the vibration at 2k. This is because the angles on the rear half of the two piece drive shaft are much higher than before. As I understand it, the more severe the angles the closer they have to match. I figure one or two more adjustments and I should be good. |
07-20-2017, 12:42 PM | #14 |
Stupid question but is a chopping block just a notched frame for air bags?
07-20-2017, 01:55 PM | #15 |
07-20-2017, 01:57 PM | #16 | |
Oh okay im getting what your saying so when you say match the frame angle are you talking the pinion on the axle like pointed down? Or? Also do you have any pics of your set up? Bc fab told me to weld the brackets on the axle paralell , but should i do that with the axle straight at 0 then i can adjust? Or have the axle down a couple degrees |
07-20-2017, 06:31 PM | #17 |
When they say parallel I think they are just referring to welding them both at the same angle on the rear end. When I matched the angle between the frame and the rear end, I used the rear face of the crossmember and the mounting face of the u joint caps on the rear end. This moved the rear wheels as far forward in the wheel well ass possible (I like them towards the front of the opening). If you have adjust the pinion angle up, just turn out the upper links. Need it pointed further down, turn out the lower links. I started as close to zero as I could get it. When I did the final install I had the pinion angled up a bit to start. It's much easier to adjust the pinion downward after its all together. I'll see if I have any decent pics to post.
Unfortunately I'm not the best at taking progress pictures. This pic is what the driveshaft angles were looking like when I first her together. As you can see the u joint angles were pretty small. I don't recall for sure, but I believe this was a lowered position (because the front inner fenders were still in at the time I couldn't get very low) Last edited by 1hihum; 07-21-2017 at 07:56 AM. |
07-22-2017, 02:49 PM | #18 | |
So degrees here ? To match this crossmember ? |
07-22-2017, 02:50 PM | #19 |
And here
07-22-2017, 03:00 PM | #20 |
Moderator
You might want o read this thread - http://67-72chevytrucks.com/vboard/s...d.php?t=608497
I'd probably measure it like this, but thats just me:
07-22-2017, 05:11 PM | #21 |
Some more updates used those angles ziptied the brackets and started attaching the bars. For some reason my kit might be updated because my upper bars have 3 different sdjusting holes in them. Think once i set the bars all to the shortest dial in the pinion close and make sure all the brackets are even and rear soacing. I can weld it all up.
07-22-2017, 05:12 PM | #22 | |
07-22-2017, 06:13 PM | #23 |
Moderator
So what degree will you set the rear end at if you have nothing to shoot for?
07-23-2017, 10:23 AM | #24 |
Well i plan on doing what 1hihim did and set the brackets and rear to the frame rails as fhe driveshaft will be close to that. Then when i set the drivetrain in there i can adjust the link bars to dial in the pinion. Setting the bars at the shortest distance will give me the most range of change as well so i can adjust. Sound correvt?
07-24-2017, 02:55 AM | #25 | |
In theory this means that the center bearing is positioned high enough to level the front half of the shaft and as such, the rear half of the shaft should be where your angles must match. But since you don't have the shaft in yet, you are just making your best guess, and in theory, that means the front half of the shaft should be parallel to surface #1 in my pic. So starting the rear end off at 90 degrees to this angle should be the best starting point given the adjust ability of the 4 link. Does that make sense? |
