Old 11-07-2009, 12:38 AM   #1
dropped65c20
dropped65c20's Avatar
c20 to c10 conversion?
I am looking to change my c20 over to a c10 and was wondering if i have to change the whole front suspension over. I would think that the upper and lower control arms are the same, so i figure maybe i could just change out the drums and whatever else right there and that should be good right?
65 c20 - Shes's rough but she's a diamond in the rough
00 Mustang GT
07 Honda CBR600RR
dropped65c20 is offline   Reply With Quote
Old 11-07-2009, 12:50 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: c20 to c10 conversion?
Are you converting to disc brakes at the same time?
C20 lower control arms are different than C10 lowers.
The balljoint hole in the C20 lower control arm is larger.
(Upper and lower balljoints are also different)
Keith
Convert to disc brakes.
Old 11-07-2009, 03:31 PM   #3
dropped65c20
Naw, i was gonna stay with drums for now. I ended up getting a full suspension with the c20 from a 63 c10 when i bought it.
00 Mustang GT
07 Honda CBR600RR
Old 11-07-2009, 03:34 PM   #4
dropped65c20
Is it safe to say that i probally should change out everything when i convert over to 1/2 ton?
00 Mustang GT
07 Honda CBR600RR
Old 11-07-2009, 04:06 PM   #5
Ronm909
67GMC Slammed
Ronm909's Avatar
hey I got the stock sindle from that 87 suburban with brakes on it, I was going to use it but I ended up buying a drop spindle kit with all new disc brakes from CPP at the last pomona swap meet.. you can have it.. not sure how far you are from me,,,
Ronm909 is offline   Reply With Quote
Old 11-08-2009, 11:28 PM   #6
dropped65c20
Five lug or 6?
00 Mustang GT
07 Honda CBR600RR
Old 11-07-2009, 08:55 PM   #7
lolife99
lolife99's Avatar
yes.
Keith
Old 11-08-2009, 11:39 PM   #8
lolife99
lolife99's Avatar
63 C10 will be 6-lug drum brake.
The 5-lug 'burb suspension will require you to change to disc brakes.
(Master cylinder and porportioning valve also)
Keith
Old 11-09-2009, 10:22 PM   #9
Ronm909
67GMC Slammed
Ronm909's Avatar
its a 5 lug set up, got the matching master cyclinder with booster too..
Old 11-10-2009, 11:16 AM   #10
Mike Bradbury
Mike Bradbury's Avatar
Early Classics has a lower control arm ball joint that fits the C20 arm and the C10 spindle. I believe they have the tie rod end conversion as well.
I am doing the same conversion and am using all the C20 equipment but converting to lowered C10 5 lug spindles and disc brakes.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 11-07-2009, 01:30 PM   #11
Ackattack
Ackattack's Avatar
The outer tie rods are also different sized
Ackattack is offline   Reply With Quote
Old 11-07-2009, 03:14 PM   #12
Ronm909
67GMC Slammed
Ronm909's Avatar
I did this to my 67,,, bought a 87 suburban for $500.. swapped out everything. complete front crossmember with all suspension.. and axle,, instant 5 lug and dics brakes....
Old 03-09-2018, 05:53 AM   #13
lolife99
lolife99's Avatar
www.performanceonline.com sells 8-Lug drop spindle kits.
That’s the best option for disc brakes and a correct method to drop your truck.
Keith
Old 03-09-2018, 10:00 AM   #14
KevinK7
KevinK7's Avatar
Thank You for that link , ...looks like the path I will go
KevinK7 is offline   Reply With Quote
