Old 03-14-2012, 05:58 PM   #1
laynrockers
laynrockers's Avatar
6 lug to 5 lug adapters on 23" wheels on porterbuilt suspension
Hey guys,
looking to start building my 66 c-10. Have a set of Giovanna 23" 5 lug 120mm rims laying around the garage. Thought process here is to use these rims with the build till I swap them year or two down the road. (trying to save a few bucks now).
About to order my kit from Nate at porterbuilt he would take 1.5" out of the arms. The offset on the 23" rims is 6" plus 1.9"-2" for the 6 lug to 5 lug adapters ??
Just looking to cover my basis here, in-case you guys forsee a problem i don't.
Look forward to some in-sight..
laynrockers is offline   Reply With Quote
Old 03-14-2012, 09:47 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 6 lug to 5 lug adapters on 23" wheels on porterbuilt suspension
Forget the 6-to-5 adapter.
They are very scary looking as far as adapters go.
They have to be a 2-piece adapter since 1 hole in both lug patterns overlaps.
Use 6-lug rotors and 6 lug rear axles.
You are spending lots of money to get QUALITY parts from Porterbuilt,... don't screw it up with adapters.
I'd rather run 15" steel wheels with hubcaps before I tried to use an ill fitting wheel and installation process.
(my opinion)
Keith
Convert to disc brakes.
Old 03-14-2012, 11:34 PM   #3
YBNORML
YBNORML's Avatar
(my opinion)
I agree 100%, I have a set of 5-6 lug adapters. They were on a truck my uncle picked up. I would not use them for anything. Very Scary.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-15-2012, 01:03 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum laynrockers. I have to agree with these guys. If it were me, I would sell the wheels you have and buy what you want with the correct pattern and backspace. Its really not an economical advantage to spend time, and money just to install a set of wheel you don't really want.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-15-2012, 01:38 AM   #5
laynrockers
Guys,
I appreciate the advice. Tempting looking at those wheels everyday I started to look for a way to use them.
Old 03-15-2012, 06:16 AM   #6
andrewmp6
Yeah i have not seen any good come from adapters,I seen them where the lugs worked loose and just spun in the hole even a few that failed that's never pretty.
Old 03-15-2012, 11:05 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by laynrockers View Post
Guys,
We completely understand that, especially if you like the wheel. Most contemporary styled wheels for late model 6 lugs aren't going to have the right backspace. They might work with the adapters, but good quality ones aren't cheap. Add the cost of the adapters, plus other mods to make them work and theres not a lot of savings.
I would hit one of the Full Size GM boards and see if they will sell. Then you can afford new wheels with the correct pattern and backspace....win/win...
Articles-
"Refining Sierra"
Old 03-15-2012, 04:32 PM   #8
SevenOne
SevenOne's Avatar
I agree.Also having those pretty PB arms shortened may screw you u down the road.Your truck tho,post pics and specs if you do go through with it.
SevenOne is offline   Reply With Quote
Old 03-15-2012, 05:39 PM   #9
JON70CST
JON70CST's Avatar
You could probably get a decent buck on those rims by selling them... why not just sell them and pick out a nice set of six lug that you'll stick with? Just my 2 cents
JON70CST is offline   Reply With Quote
Old 03-20-2012, 12:49 AM   #10
mcmlxix
Collector of Projects
mcmlxix's Avatar
Welcome from Vegas...
Why are you taking 1.5" out of the arms? Is it for the rims you may not keep? Don't make the suspension fit the rims you will not be using in the end....
I agree with the others, get some cheap rims that fit without adapters. It may not be the perfect look now, but it will be safer and save probably save you money in the long run....
Rich
1972 K5 Blazer CST Click HERE
Old 03-20-2012, 12:49 AM   #11
mcmlxix
mcmlxix's Avatar
And lets see some pics of the truck...
Rich
Old 03-21-2012, 11:28 AM   #12
Tony@Roadstershop
I agree 550%... dont compromise the geometry to make a set of wheels fit...
Tony@Roadstershop is offline   Reply With Quote
Old 03-21-2012, 12:15 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Meh, what would you know about suspension...
Articles-
"Refining Sierra"
Old 03-21-2012, 05:56 PM   #14
502ms
502ms's Avatar
Yes, but some steelies on it, sell the 23s and enjoy life
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 03-21-2012, 06:04 PM   #15
lolife99
lolife99's Avatar
Welcome to the board, Tony.
We need some more pics of the Orange and White truck!
Keith
Old 03-21-2012, 11:14 PM   #16
laynrockers
Appreciate the heads up, def wont be considering adapters ever again. Been looking for wheels, problem is the ones i like arn't cheap. Attached pics of the two projects.
Old 03-22-2012, 01:59 AM   #17
mcmlxix
mcmlxix's Avatar
Check out COYS C-5 or C-55 for a less expensive option.... the website is having a sale right now too...
http://coyswheel.com/index2.html
Rich
Old 03-22-2012, 07:22 PM   #18
laynrockers
The price is so tempting. Who else that you guys are aware of make wheels similar the the above??
Thanks for the tip!
Old 05-20-2012, 09:37 AM   #19
hungarian1964
What are wrong with Wheel adapters!!! I put a set of High Quality 2PC 6 to 5 Lug Adapts on my 68 and Never had a problem, even spaced my wheel out 2" to make my Cragars fit better. Dont let these guys "Scare" you to death, $130- took 45 Min. Done, wheels went on and I went driving down the road, I almost forgot I had them on there.
hungarian1964 is offline   Reply With Quote
Old 05-20-2012, 10:19 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by hungarian1964 View Post
What are wrong with Wheel adapters!!! I put a set of High Quality 2PC .
If all wheel adapters were made the same we wouldn't need to warn him away from them. There are many high quality precision machined adapters on the market that will do the job just fine. There are just as many that are pure junk and are not safe to run on. Price motivates buyers away from the quality billet or steel adapters toward the lesser quality cast or poorly machined units.
Combine all of that with the fitment issues the OP was facing, and it was not a practical choice for him.
Articles-
"Refining Sierra"
Old 05-21-2012, 01:32 AM   #21
andrewmp6
What it cost for good adapters you can buy new rims almost.The garage i use to work for wouldn't work on anything that had adapters or thick spacers on it for legal reasons.Ever since i bought a wheelrite i never had to worry if my math is right if a wheel and tire will fit.If you don't know what a wheelrite is its a tool that lets you test first any rim and tire combo http://www.summitracing.com/parts/PHP-01201
Old 05-21-2012, 01:51 AM   #22
mud.man.rj
mud.man.rj's Avatar
Just seem goofy to take some off the arms and run spacers for temporary rims that as most will be changed sooner or later, then what?. Just sell them don't compromise, get what you want the first time. So one with spacers will want them, haha.
mud.man.rj is offline   Reply With Quote
Old 05-21-2012, 11:03 AM   #23
tubbedII
needs more $$$
tubbedII's Avatar
Thanks for the tip!
Another cheaper alternative with that wheel style is the BOSS 338's
http://www.bossmotorsports.com/wheel...d=1920&cat=466
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 05-21-2012, 12:43 PM   #24
belowme51
belowme51's Avatar
welcome from a fellow vegas board member, if you need any help let me know.
-mike
belowme51 is offline   Reply With Quote
Old 05-22-2012, 02:30 AM   #25
laynrockers
Well like always, I learned a few things during this process. Turned out with the Disc brake conversion I am running the fronts don't need to be modified and will fit perfect. The rear axles I had a machine shop convert for $170 and will pick up tomorrow.
I am gonna use the 23"s for now cause to be honest there great rims and new tires later on down the road i am leaning towards the boss 338's.
Thanks fellas.
