Old 11-13-2019, 07:57 PM   #1
Chev1171
1960 Apache door glass install
Replaced the rollers on my door glass regulator . Can’t re-install glass on rollers .
Need help/ advice. Thanks
Chev1171 is offline   Reply With Quote
Old 11-13-2019, 10:10 PM   #2
jrusher
Re: 1960 Apache door glass install
I just finished rebuilding both doors/windows/vent windows on our 61 . I had too remove the track from the bottom of the glass , slide track onto rollers , then lower window down and install track with the two odd shape screws
Also should mention make sure you snap in those window anti rattle pieces in before you install glass as they can’t be snapped in place once your window is sitting in the track unlike my 65 I was still able to install those with window in the track if I remember correctly
jrusher is offline   Reply With Quote
Old 11-14-2019, 11:04 AM   #3
verdell
verdell's Avatar
Just replaced glass, weatherstrip, rebuilt vent window, anti-rattles, etc. on my '60 Apache last month. Jrusher is absolutely correct...Another set of hands would be a big help as well...
verdell is offline   Reply With Quote
Old 11-14-2019, 05:14 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
There is a link with the repair manual - http://67-72chevytrucks.com/vboard/s...d.php?t=578824
