Old 07-02-2008, 11:38 PM   #1
Luvlegs
Luvlegs's Avatar
GOT ME SOME BB Stttuufff!!!!
FINALLY picked up the brackets and pulleys I've been looking for!!!! - also got the shroud - it didn't fit in the truck it was in (or at least it didn't look like it did).... can anyone tell me if it is a 67-72 shroud? I just can't tell from any pics I can find...
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 07-02-2008, 11:50 PM   #2
Jcentsr6
Junior Member
Jcentsr6's Avatar
Re: GOT ME SOME BB Stttuufff!!!!
dont know about the shroud...but im getting rid of mine when the new radiator and elect fans go in.........if you are not in a hurry.
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 07-02-2008, 11:54 PM   #3
Luvlegs
Luvlegs's Avatar
hmmmm I have to get the 454 together now... well, finish the top end first and then this stuff and then the shroud.... funny, now I feel like I have more work to do.... keep me in mind
1972 C10 L6 3OTT
Old 07-03-2008, 12:17 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
The shroud is correct for a pre '72 bb truck. The pulleys and brackets look like the '73-'87 LONG water pump style. The pre '72 had a SHORT water pump.
Keith
Convert to disc brakes.
Old 07-03-2008, 12:28 AM   #5
Down south truckin
Down south truckin's Avatar
The shroud looks to be a 73 and up big block shroud
Down south truckin is offline   Reply With Quote
Old 07-03-2008, 08:52 AM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey luvlegs.....
Awesome man....glad you were able to get those BB parts you needed soooo bad, but didn't want to pay $600 for them, I'm sure this was a MUCH better deal!!!!!!!
I'll take that off my watch list for you....now hurry up and get that engine built....and of course....we need pictures!!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-03-2008, 10:49 AM   #7
Luvlegs
Luvlegs's Avatar
My block is a 73, and the donor was a long water pump - Looks like I got 1 vote for pre73 and one vote for post 72 on the shroud... anymore? Got all the stuff for less than 1/4 what the last guy wanted.
Engine :
454 bored .030 over
Keith Black KB203 Hyperutectic Pistons with 12cc Dome
Comp Cams Valve Springs with new retainers
Oval Heads were shaved just to true up and a valve job
Stock Crank turned .010 (I think)
New cam bearings and freeze plugs
High volume oil pump
Mallory oil pump shaft
Yet to go on:
Timing Chain Set - Double Roller w/ Torrington Bearing
Chromemoly Pushrods
Roller Rocker Arms
Comp Cams Magnun 286 cam
Hi-Rev Lifters
Edelbrock Performer RPM Air Gap Manifold
Holley 750 CFM Dual Line Double Pumper
As for pics, here's as far as I've made it...
1972 C10 L6 3OTT
Old 07-03-2008, 11:12 AM   #8
lolife99
lolife99's Avatar
Down South Truckin is correct. I was wrong. I should have looked before I spoke.
Keith
Old 07-03-2008, 11:28 AM   #9
lolife99
lolife99's Avatar
Here's the shroud on my factory 402 parts truck.
Keith
Old 07-03-2008, 11:40 AM   #10
Luvlegs
Luvlegs's Avatar
ah hah - now I can see the difference. Well, it was kinda like a lottery ticket - got to dream for a bit.. I might just try to "modify" it a bit and see what I can't make it look nice... that'll be several months from now most likely though... Thanks guys.
1972 C10 L6 3OTT
