Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-07-2008, 11:09 AM   #1
Super73
Super73's Avatar
Engine Clean up
I was asked for pics of my set up. I looked as I thought I had posted them, but, no I can't seem to find them, so, here it is again..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-07-2008, 12:01 PM   #2
PA-IndianRider
PA-IndianRider's Avatar
Re: Engine Clean up
Now just drop that thing in my C10....ha!!!
Looks GREAT....anxious to see how it runs..... more videos PLEASE!!!!
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 07-07-2008, 05:04 PM   #3
chevy72blu
chevy72blu's Avatar
Re: Engine Clean up
Clean man, nice work.
Carbed LSX = 10 cool points
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 07-07-2008, 06:56 PM   #4
74 C-30
Dually Pride
74 C-30's Avatar
Re: Engine Clean up
they were here:
http://67-72chevytrucks.com/vboard/s...d.php?t=297043
btw that engine looks pretty sharp
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 07-07-2008, 11:21 PM   #5
Super73
Super73's Avatar
Re: Engine Clean up
I knew I put them somewhere on here.. Oh well..
Old 07-08-2008, 12:00 AM   #6
PA-IndianRider
Re: Engine Clean up
How much motor HP are you "guess-timating"?????
John aka "Milner"
Old 07-08-2008, 12:28 AM   #7
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Engine Clean up
Is the plate perimeter with a crossbar ? NX ? Setup single or dual stage ? Have you left on dope yet ? Which hits harder the crossbar or the flush ? looks like the only way it can spray is all or none .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-08-2008, 12:38 AM   #8
Super73
Super73's Avatar
Re: Engine Clean up
The motor makes 430 to the wheels. The first hit will be jetted for a 100horse hit and the second stage for a 200hit. I am hoping to use both stages at some point down the track.
I have not left on the bottle as I haven't made it back to the track yet. Truck is apart.
The plate in the pic is the perimeter+cross bar plate. I actually sent the plate back and they are sending me a dominator plate. This is pretty much the kit http://store.summitracing.com/partde...5&autoview=sku
Here is a better pic of the plate
Old 07-08-2008, 12:48 AM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Engine Clean up
Wow cool plate . Wait till you leave on a 100 shot . You'll be hooked . You get that thing to 60' under 1.50 and you'll get the rollbar speach .
opps , you already got that speech , I see it in your sig now .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-08-2008, 07:28 AM   #10
djracer
djracer's Avatar
Re: Engine Clean up
I have a speedtech plate for a dominator that I want to sell. Then add a fogger for the second stage.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-08-2008, 09:59 AM   #11
Couch
Daily Driver
Couch's Avatar
Re: Engine Clean up
whats the $ for the plate DJ, just wondering cause i might pic that up off ya
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 07-08-2008, 11:19 AM   #12
djracer
djracer's Avatar
Re: Engine Clean up
350 With solenoids and solenoid mounting plate and two short lines that go from the noids to the plate with jets up to a 500hp shot!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-08-2008, 11:23 AM   #13
djracer
djracer's Avatar
Re: Engine Clean up
this is what it looks like but it has the lines and jets.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-29-2008, 04:43 PM   #14
Super73
Super73's Avatar
Re: Engine Clean up
ok.. TB finally came in today.. Also, I switched out the 4150 plate for a dominator plate. Was like $19 more or so.. Also, NX's customer service rocks.. I mentioned I was using this in a 58psi fuel system (LS1) and they had me send the carb jets back and set me ones for my fuel pressure. Let's just say the NOS kit I was going to use, when I spoke to their cust serv department, I'll never order from them again!!!
Old 07-29-2008, 06:36 PM   #15
Super73
Super73's Avatar
Re: Engine Clean up
Thought I'd share a few more pics of the intake setup I am switching to.. I also marked on both the intake opening on the Super Vic and Vic JR that I have with the Felpro gasket to give you a better understanding of the port differences. Hopefully I don't loose too much bottom end. But then again, the 4,900 verter probably won't care..
What fuel rail looks better? The black one ot the Edelbrock one?
I know I need to do something about the valve covers..
Here is what the gasket looks like against my heads.. Also looking down the intake port while sitting on the motor:
Here is the height of this set up:
Old 07-29-2008, 06:36 PM   #16
Super73
Super73's Avatar
Re: Engine Clean up
Finally the Vic JR vs Super Vic gasket..
Old 07-30-2008, 09:35 PM   #17
PA-IndianRider
Re: Engine Clean up
Looks GREAT.... nice pics.
So WHEN is going to be the "Debut".... you have "all" of us anxious.... and PLEASE .... "IF POSSIBLE" ..... new videos !!!
John aka "Milner"
Old 07-30-2008, 10:49 PM   #18
Rodms
Rodms's Avatar
Re: Engine Clean up
How much is Alchy running out there?
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 07-31-2008, 03:00 AM   #19
Super73
Super73's Avatar
Re: Engine Clean up
No idea.. this is a pump gas motor when not on the bottle..
Old 07-31-2008, 07:07 AM   #20
djracer
djracer's Avatar
Re: Engine Clean up
how far are you from Montgomery? I can probably get you a decent deal.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-31-2008, 08:56 AM   #21
Rodms
Rodms's Avatar
Re: Engine Clean up
Man I'm 5 miles from Memphis but its high at mmp and speed shops around here all they sell is VP
Built chevy tuff!
Old 08-22-2008, 10:53 PM   #22
PA-IndianRider
Re: Engine Clean up
Was looking around here and came across this thread you started....
What is up with the engine, etc????
John aka "Milner"
Old 08-24-2008, 11:43 PM   #23
Super73
Super73's Avatar
Re: Engine Clean up
Not sure if I get what your asking.. But it's the same long block that was in it for the 11.95 NA pass and 11.28 small hit pass. It's just getting a new intake and a different N20 system.. Sill need to put it back together.. The intake required gasket matching the heads. So I pulled the valves out and opened up the first 3/4" of the intake port.
Old 08-25-2008, 12:37 AM   #24
tubbed 68
Re: Engine Clean up
what brand is that throtle body and were did you get thanks
tubbed 68 is offline   Reply With Quote
Old 08-25-2008, 02:28 AM   #25
Super73
Super73's Avatar
Re: Engine Clean up
Edelbrock, Summit..
